Thread Tools Search this Thread Rating: Thread Rating: 29 votes, 5.00 average. Display Modes
Old 09-27-2008, 09:28 PM   #201
//TRD power
My Ride: 3.0 | 200hp | 214trq
yeah remove the first duct, yank it out, and work around what else is behind it
//TRD power is offline   Reply With Quote
Old 09-28-2008, 12:28 AM   #202
kbmw
My Ride: BMW
To remove the air duct pull on it toward the right (toward the passenger foot area), a little bit up, and then forward toward the firewall. Pull hard, it will pop loose, and then wiggle it out.
(You did first remove the kick trim plate forward of the removed glove compartment, right?)
kbmw
kbmw is offline   Reply With Quote
Old 11-22-2008, 08:50 PM   #203
peddlerp
My Ride: 330i
Thanks for all of your information and pictures. I could not done this without you.
I bought my FSU from RMeuropean.com for $60.28, I added a wiper blade and the shipping was free. They delivered in two days. Great service.
Be careful not to drop the torque screws, I lost one in a cut in the firewall. A #10 x 3/4" will work as a replacement.
Also be careful with all of the plastic parts, in my 7 year old 2001 330i, there were lots of brittle pieces.
Does anyone know why BMW isn't replacing these FRU's for free? They should last the lifetime of the car.
Thanks again E46fanatics. A great site.
peddlerp is offline   Reply With Quote
Old 12-06-2008, 05:14 PM   #204
stolleee
My Ride: 2001 325
Well, I tackled this job today. I bought the FSU from Pelican parts. They offered 2 units (OE BMW or OE supplier). I bought the cheaper unit which was a Hella unit. What I pulled out was a Valeo from the car. The hardest part is not getting pissed off every time you hit your head trying to see what the hell you are doing because of the tight space. Outside of that it is an easy DIY. Make sure you have a T20 torx driver that is long enough before starting or you will have to drive with your dash apart to autozone to buy one ($4.99 Duralast). The job total was $65 against BMW wanting $300 to do it. Took about 1-2 hours however easy considering what you save in $.
Good luck to all..........
stolleee is offline   Reply With Quote
Old 12-14-2008, 07:14 PM   #205
John in VA
My Ride: 328i/325xi
Did mine today on the 10/99 328i - 2 screws and a clip held it in place. It was initially replaced with the modified/superceded unit (same as the one I put in today) in 2002 at 16K miles. I removed the glovebox door, glovebox shelf, air duct, and glovebox surround to get to it. Took <1 hr. It's nice to have heat fan control in the wife's car. I'm a hero!!
I got my FSR (as well as oil filter, brake pads, rotors & pad wear sensors) from www.SteveHaygood.com. Great pricing & logistical support (Steve's a professional mechanic as well as parts source). Give him a call: 706-647-0302.
John in VA
'13 328i xDrive
'06 330ci ZHP
'03 530i
'02 325xi
'00 328i
'86 535i
'85 535i
'85 325e - RIP
'74 2002tii
John in VA is offline   Reply With Quote
Old 01-10-2009, 11:20 AM   #206
dellop
My Ride: 2001 325xi
Did mine today, an E46 with manual AC adjustments. I would say the hardest part was pulling out the floor panel with the light and getting the glove box back in correctly. Also, the old FSU I pulled out had a part number, which realoem.com doesn't find, and when I do a Google search, it references an E39 FSU. Wonder what that is all about. (64118383835) Valeo part.
dellop is offline   Reply With Quote
Old 01-13-2009, 01:06 PM   #207
easyIsle
My Ride: 02 330i
hey guys, I have a clarification question regarding faulty FSR's.
Has ANYONE had a faulty FSR which caused the FAN DISPLAY to become erratic (not just the sound of the fan). My HVAC unit will sometimes go from 1 bar fan strength up to all 8 bars, and back again. This only happened once, but also my cabin air temp setting is WAY out of whack. i.e. set to 60F the cabin temp will usually be right around 72F.
I'm thinking the little draw fan for the thermistor in the HVAC system is broken, OR the whole friggin unit is dying on me.
Anyone with a bently manual, could you tell me if there are any other thermistors besides the ambient air outside one, and the one in the HVAC unit itself (behind the small grill opening)?? I am pretty sure one of them is bad somewhere
easyIsle is offline   Reply With Quote
Old 02-07-2009, 02:27 PM   #208
Demon Eyes Kyo
My Ride: 2001 330i
AC blower fan was sporadic all last week at 53200 miles and so annoying. Bought online for $83 and just changed my FSR in 1.5 hours this morning.
Not sure why people were writing that they needed 3 hands putting glovebox back. I just lined it up and pushed it back in (in like 3 sec) and it held in place for me to grab the 6 screws.
WARNING: do not insert a metal screwdriver in between the FSR wiring harness and the actual FSR. I used a flathead screwdriver to pry the wire harness off (stuck) and the AC fan turned on and I got a spark.
Also, buy a compact fluorescent work light (not an incandescent one) that you can prop in the passenger footwell to see things easier and it won't give off heat or burn you working in the tight glovebox space.
[SIGPIC][/SIGPIC]
Demon Eyes Kyo is offline   Reply With Quote
Old 02-07-2009, 11:38 PM   #209
John in VA
My Ride: 328i/325xi
Originally Posted by dellop View Post
...Also, the old FSU I pulled out had a part number, which realoem.com doesn't find, and when I do a Google search, it references an E39 FSU. Wonder what that is all about. (64118383835) Valeo part.
That's the larger heat sink, later style FSR that's been being used in place of the more troublesome earlier version - used in the E39s and X5s. Seems they need to do some more R&D on these!
John in VA
'13 328i xDrive
'06 330ci ZHP
'03 530i
'02 325xi
'00 328i
'86 535i
'85 535i
'85 325e - RIP
'74 2002tii
Old 02-18-2009, 12:17 AM   #210
jaedog
My Ride: 2001 325i
Just did mine as well
Thanks for your help everyone. My fan had stopped intermittently a few times in the prior year then just went out. I was afraid it was the blower motor as I did not have any erratic behavior. Figured I could spend $80 to get it diagnosed or replace this part for $65 and if it didn't fix it I knew what the other possibility was (lots of money or a quite a bit of money and a lot of work). I got a quote for $900 to replace the blower.... Luckily I popped in a new part from Pelican (Behr brand) in my 01 and the fan works again!
jaedog is offline   Reply With Quote
Old 03-03-2009, 08:33 PM   #211
sstrentzsch
My Ride: 2001 E46 325i
FSU N2 Pinouts & testing
The FSU DIY's been covered, but I couldn't find much on testing the FSU before blindly ordering the part, so I thought I'd add a few measurements.
My Bentley manual doesn't have a diagram of part "N2" - Final Stage Unit - but google will find one. The pinouts & measurements on my 2001 325i E46 w/elec HVAC are:
1 - GND to Blower motor, 0v
2 - +12v from fuse. WARNING: Live even w/key OFF.
3 - variable Control voltage from panel (~2.3 - 8.5v), increasing as you press fan ctrl up
4 - FSU ground 0v
5 - +V to Blower motor, should be around 12v.
I checked blower motor by jumpering 5-to-2, 1-to-4. Blows? Yes, Blower motor is good, FSU probably bad. No Blow? Sorry... not likely the FSU.
I tested FSU out of car: Put +12/GND on 2,4. Put 5v on pin 3. Check voltage across 1,5 with no load: 11.5v, about what I'd expect to work. BUT - test with a small load (I used a 10 ohm, 10w resistor) across 1,5 and re-check - - < 2v, and current thru load < 10ma, way off. My guess, blown output power semi in a PWM circuit.
BMW/San Antonio wanted $135.00 for part; I paid $65 at Pelican.
20 minutes out, 10 minutes in. Works great. Only removed 2 torx screws, but there are 3 holes - 2 thru both the FSU & the control motor, 3rd just on ctrl motor. Added.
Good luck!
sstrentzsch is offline   Reply With Quote
Old 03-11-2009, 04:50 PM   #212
mwilliams31
My Ride: 318i
fixed!
Many thanks for all who have posted advice in this thread, using your help I replaced the FSR on my UK (RHD) 2001 318i in about an hour, part cost 51 discounted from dealer. Climate fan suddenly had a mind of it's own on auto or manual and this was an instant cure.
mwilliams31 is offline   Reply With Quote
Old 03-12-2009, 05:00 AM   #213
cityjohn
My Ride: 2001 M3
Just did this today. Everyone's tips and pics were very helpful. Something I did that really made the work position comfortable was to take out the seat! Makes a big difference and it's not difficult...I was so relaxed I fell asleep under the dash.
I wore a headlight that made everything super easy to see handsfree.
cityjohn is offline   Reply With Quote
Old 03-12-2009, 07:24 AM   #214
Arby1028
My Ride: 2002 330i Sedan
This is the exact problem I'm currently having except that my blower motor will kick-on after about 5 minutes. Looks like I'll be ordering the FSR unit today.
EDIT: Just ordered from Pelican Parts - $65.50 including shipping.
Arby1028 is offline   Reply With Quote
Old 03-15-2009, 09:55 PM   #215
Botsy67
My Ride: 325i
Same symptoms on wifey 325i (erratic fan speeds) and I replaced it yesterday thanks to everyone tips and tricks on this forum, awesome group here. I am usually on the E39 and Rennlist 996 forum. I found my new part on Ebay from "deutschepartusa" for $47.49 + $10 shipping, and it's made from Germany (Hamburg-Technic), great deal... Now the fan speed is working great again. Looks like this FSU issue is extremely common for these cars and the E39 as well. I already replaced it on my E39 too. Cheers,
Botsy67 is offline   Reply With Quote
Old 03-18-2009, 10:20 PM   #216
Arby1028
Installed the FSU tonight and it took exactly 1 hour. Pulled out the heater duct, but dislocated a rod on some type of acutator for the heating/air system...I couldn't see this behind the duct. Rod went back in OK and onto the actuator. Re-installing the duct was much easier than pulling it out.
Like most said in previous posts this is a relatively easy DIY, but it helps to be a contortionist to do this.
Old 03-27-2009, 12:45 PM   #217
Chase94
My Ride: 2000 323i
I just changed my FSU on my 2000 323. The instructions helped me A LOT!! My question now is... I got all the screws back in but I could not get the plastic tab to hook back on to the new FSU. Its almost like it would not go all the way in. Anyone else had this issue??
Chase94 is offline   Reply With Quote
Old 03-27-2009, 05:09 PM   #218
jason330cic
My Ride: 2001 330cic
My final stage resistor just went out today at around 53000 miles I lost my fan speed control, just runs full blast. I ordered the part on eBay for only $49.75 shipped, it's made in Germany by Meyle.
I'm not looking forward to installing it
Jason330cic
jason330cic is offline   Reply With Quote
Old 03-28-2009, 10:25 PM   #219
leb17
My Ride: 2001 325i
Installed part I got from deutsche too but it arrived with a little plastic piece next to the metal rods broken off. They told me to try installing it before exchanging it and I did. Fan works fine, but does anyone else have a weird sound when the fan turns on initially. Never had the sound before.
leb17 is offline   Reply With Quote
Old 03-29-2009, 07:40 AM   #220
Arby1028
It took a little work to get the FSU to be held in place by the tab. I took a flat head screwdriver and gently pushed the tab back while pushing the FSU that last few milimeters into place.
