Thread Tools Search this Thread Rating: Thread Rating: 29 votes, 5.00 average. Display Modes
Old 06-20-2005, 09:24 PM   #21
krod328Ci
My Ride: 00 Steel Grey 328Ci
Very Cool
Glad it helped everyone.. My first DIY post.
krod328Ci is offline   Reply With Quote
Old 07-05-2005, 09:46 PM   #22
18jake18
My Ride: '01 White 325i
You just saved my cars life. I was convinced the ac was gone and it would be some 2000 dollar fix. If that was the case she was gonna get shipped out to the ol BMW parking lot in the sky. I love her but shes gotta do her part too.
If she could talk Im sure she would say thank you.
18jake18 is offline   Reply With Quote
Old 07-08-2005, 07:40 AM   #23
elwot
My Ride: 2001 330Ci
Send a message via Yahoo to elwot
Thanks for the great DIY! My FSR just went out last week and I just picked up the new one from the dealship yesterday. Cost $68.54 - that was with a CCA discount. Otherwise it was gonna be something like 100+. Happy to say that the CCA membership paid for itself....
GenV DDE's, UUC SSK, M3 Black Trim, Stongard, Euro Clears
elwot is offline   Reply With Quote
Old 07-08-2005, 09:58 AM   #24
323power
323power's Avatar
My Ride: '11 335i
My fan wouldn't "fireup" sometimes when it's at its middle speeds, but if i crank the fan speed up, it'll kick on all of a sudden, but if i lower it back down, it's a crapshoot if the fan will keep spinning or not. It makes a weried nose like its trying to start up, but it can't. Do i need to replace the FSR?
Jeff
323power is offline   Reply With Quote
Old 07-08-2005, 05:51 PM   #25
elwot
My Ride: 2001 330Ci
Sounds like the FSR to me.
In my situation, the fan speed works ok initially, then it suddenly goes to the highest setting (maximum blast) and there is nothing you can do to turn it down (aside from turning it off completely). Then, just as suddenly as it jumped to max speed, it then goes back to the initial speed I had it set on. It sporadically cycles between the set speed and the max speed for the rest of the drive. It can be really annoying when it comes on full blast and your in the middle of a call.
I'm planning on swapping out the defective resistor with the new one tomorrow. I'll let you know how it goes.
Old 07-09-2005, 11:38 AM   #26
elwot
My Ride: 2001 330Ci
OK, swap was a success. A real pain in the arse, but a success. It's really tucked up back and to the left of the glove box, which forces you into some pretty uncomfortable positions. Some comments:
1) There were no screws holding in my old FSR, just a plastic clip (I think someone else also mentioned this before). But the clip seems to hold it in just fine, so I just clipped the new one in as well.
2) I didn't unattach the stepper motor in front of the FSR, just let it hang there by its arm (wasn't sure how to disconnect it without breaking it). But after finishing, I don't see why you would need to disconnect it anyway.
Biggest inconvenience was reattaching the glove box door (could really have used a third hand - one to press against to door, one to hold a flashlight, and one to turn the screws).
BTW, he's a pic of the old and new. Notice the cooling fin redesign - 12 to 50, and its much smaller then the old one.
ID:	134247   Click image for larger version
Name:	Picture 178ss.jpg
Old 07-24-2005, 04:59 PM   #27
BmwBilal
My Ride: 2000 328ci
Send a message via AIM to BmwBilal
Just finished replacing my Final Stage Resistor
Well i got my new final stage resistor from the dealer for about $100 because I didn't want to wait. I'm not really good with working on cars but I wanted to replace it myself. This DIY here with the pictures is great if you follow it carefully. Thank you very much for your DIY and your pictures!!! My air conditioning works perfectly now!!! [/SIZE]
BmwBilal is offline   Reply With Quote
Old 07-31-2005, 04:06 AM   #28
aa240sx
My Ride: 2003 E46 M3 SMG
Send a message via AIM to aa240sx
final stage resistor - success!
Just wanted to say it worked for me too! I have a 2000 323I and while it was painful to get in, the pics and DIY was great. thanks a bunch! I can only say that will so many of us having this issue, I really think BMW should step up and consider this a recall item. Anyway, for those of you that need to do this job? My advice:
1 - take the ac tubing off first, it'll make things go a lot smoother
2 - be patient with the FSR, it's being held with a clip only so work it out gently.
thanks
aa240sx is offline   Reply With Quote
Old 08-10-2005, 01:00 PM   #29
TheRiddle
Sofa-king-what
My Ride: M52TUB28-Vert
just finished my DIY..
and I must admit that on a scale of diffuculty from 1 to 10 I rate this 7, not for what you've to do but for the position you must keep...
head into the footwell- feet on the headrest....
anyway... many thanks to those guys that add info to this DIY
TheRiddle is offline   Reply With Quote
Old 08-14-2005, 10:54 AM   #30
ccarrera
My Ride: '01 325Ci Coupe
It took me about 45 minutes all together to replace it. I ordered it from Fields BMW in Olando. For my '01 325Ci it was $86 + tax, which included the BMWCCA discount. I just went to the dealer and told them I needed a Final Stage Resistor and I was on the road.
The DIY is fairly good. My only extra advice is that you need a long T20 screwdriver in order to get to the top screw. I got one (6" long) at Sears for 7 bucks.
My AC is blowing again!! Yeahh!!!
ccarrera is offline   Reply With Quote
Old 08-14-2005, 11:37 AM   #31
Jeff323
Jeff323's Avatar
My Ride: 81' & 00' 323's
My fan is making a whistling noise on the lower speeds and it's really pissing me off. The HVAC system isn't doing anything else weird though. Someone told me though that the whistle could be the start of the FSR going? That seems a little odd to me, but I was wondering if anyone here had any experience with this? I'd really like to get this fixed.
My Toys.... Photo Sharing and Video Hosting at Photobucket '81 Euro E21 323i '00 E46 323i
Jeff323 is offline   Reply With Quote
Old 08-15-2005, 04:15 PM   #32
Brad330Ci
My Ride: '01 330Ci Cosmos Blk
I just completed my FSR replacement this weekend. I got the part for 107 with BMWCCA discount from Crevier. I removed the glove box in 2 parts (tray and the surround). It seemed easier to get back together when I finished.
If you get in there and remove the 2 screwes, the vaccuum device in front of the FSR kinda swings away, then you have to push a clip at the top of the resistor housing to free it and slit it out (kinda forcefully too). After connecting the new resistor and slipping it back in, everything goes back in with little fuss.
My job took maybe 2 hours since I did not have all my tools available and I was unable to leave the door open for easier access with more light.
I have a sore shoulder but can say it is completely fixed.
Brad330Ci is offline   Reply With Quote
Old 08-18-2005, 07:20 AM   #33
00zr2guy
My Ride: e46 328 (wifes car)
Send a message via AIM to 00zr2guy
thanks for the instructions krod! it took me about 25 minutes to R/R the final stage on my wifes 00 328i... the directions are spot on!
00zr2guy is offline   Reply With Quote
Old 08-31-2005, 11:09 PM   #34
myxr4
My Ride: 05 330i ZHP
Great pictures and instructions made this job easy. Nice to have my AC back again.
I was living with the crazy speeds for months, until it quit 99% of the time.
Thanks again for all of the help.
myxr4 is offline   Reply With Quote
Old 09-05-2005, 03:57 PM   #35
davidwarren
Halfway to 2L
davidwarren's Avatar
My Ride: 2010 335i
My AC just started acting up like the OP, with the variable fan speed regardless of the setting, but mine will not turn off, even when I turn the car off! I pulled the two blower fuses to get it off. I am going to get a new FSR Tuesday, but could it be anything else? Would a ac problem show up on a OBCDII scan?
You down with UCC? Ya you know me!
sowing the seeds of jiggery pokery
davidwarren is offline   Reply With Quote
Old 09-06-2005, 08:08 AM   #36
krod328Ci
Same exact problem I had. It was draining my battery. I replaced the battery before I realized it was the FSR. Good luck.
Old 09-06-2005, 11:56 AM   #37
davidwarren
Halfway to 2L
My Ride: 2010 335i
thanks for the confirmation, I am getting a new FSR after class
Old 09-06-2005, 06:57 PM   #38
davidwarren
Halfway to 2L
My Ride: 2010 335i
FSR replaced and everything is working again! Thanks for the DIY
Old 09-30-2005, 06:10 PM   #39
ajbmw311
My Ride: 2001 BMW 330ci
Mad props ... write-up was very useful.
- Aldo
2001 Jet Black 330ci
ajbmw311 is offline   Reply With Quote
Old 12-25-2005, 02:13 AM   #40
bmwboy
My Ride: A horse
Send a message via ICQ to bmwboy Send a message via AIM to bmwboy
ok my turn next, i will do it over the next week or so when i can get some time, i am going to hit up BMW head office about a recall, i am sick of the problems i have had with my car.
Rear Sub Frame went. (Free after long negoatiation, but off the road for 2 months over summer )
Door seals went (Free after making a scene)
fuel pump died ( got stuck had to wait for 4 hours then charged $400 for it to be fixed)
Lower Controll Arms (needed replacing due to poor OEM ones wearing out) about, $600 i think.
Now this, wow this car is a bag of laughs.
bmwboy is offline   Reply With Quote
