Old 05-05-2005, 11:03 PM   #41
vaio76109
My Ride: Race Cars
Originally Posted by Presns323i
hahah. watch out for the FULL CF e46 coming soon guys...
Its already been done. Some guy over at M3forum...
vaio76109 is offline   Reply With Quote
Old 05-06-2005, 11:01 AM   #42
JewManji
JewManji's Avatar
My Ride: a car
I wonder how many sheets I would need to cover my entire roof just like the csl. That would be pimp.
JewManji is offline   Reply With Quote
Old 05-06-2005, 11:13 AM   #43
Alan L.
TWC Alumni
Alan L.'s Avatar
My Ride: AW M-Sport
I've seen the one selling on ebay before. They are stiff sheets. I don't understand how you could wrap anything with them unless its flat
How flexable are these? Not just bending them but being able to wrap something that has curves?
2015 F15 M Sport |||More Photos of my X5 here||| -F85 X5M Incoming....
Alan L. is offline   Reply With Quote
Old 05-06-2005, 11:56 AM   #44
Seth_Horwitz
My Ride: 330ci, 911 Turbo X50
Carbon Fiber by definition is a carbon/cloth weave that is hardened with an epoxy and usually pollished to make it look nice. I wasn't aware that you could bend it at all once the epoxy had cured. It's like calling something a "bendy" fiberglass. Can this be done with decent results or will the strength of the carbon pull the 3M backing right off, or is the epoxy so thin that it will peel and fall apart over time. I'm not trying to be a hater, but I'm just curious as to how something known for it's incredible stiffness and rigidity can be flexible enough to wrap around anything. (They make formula 1 suspension rods out of carbon, and those aren't bending one bit!)
Seth_Horwitz is offline   Reply With Quote
Old 05-06-2005, 12:07 PM   #45
JCz04Bimmer
JCz04Bimmer's Avatar
My Ride: 2004 330Ci & 06 Z4MC
Send a message via AIM to JCz04Bimmer
I think its a completely different concept here. Instead of using an epoxy or resin, I think there is a substance that is more like a laminate being used. Imagine taking a fabric and laminating it in flexible plastic. Same idea, I think. The idea with these products is that its not being used for structural applications which WOULD require the hardening agents and the CF to be rigid. Instead, this is for cosmetic applications only which do not really require CF to be rigid. In reality, it makes ALOT of sense. Do you really need your interior trim to be impossibly strong? As strong as an F1 racer? No! You just want it to look cool and these sheets seem to accomplish that.
Again, alot is just speculation. So BimmerBlvd, feel free to confirm.
JCz04Bimmer is offline   Reply With Quote
Old 05-06-2005, 12:28 PM   #46
Hung@Fiber-D
Past Site Sponsor
Hung@Fiber-D's Avatar
My Ride: Car with Silver CF
Its hard to wrap stuff that have alot of 3Ds bent.... since the sheets are flat.. and made to do 2D bents only.
I experienced this myself. Good for flat surface if your looking for an alternative for quick CF.
Hung@Fiber-D is offline   Reply With Quote
Old 05-06-2005, 01:01 PM   #47
bimmerblvd
Past Site Sponsor
bimmerblvd's Avatar
My Ride: 2004 M3
Originally Posted by vaio76109
I doubt that its flexible enough to go around some of the corners/bends on the trim.
I also doubt that the pieces with be big enough to cover some of the pieces.
"otherside" only used 1 sheet to cover both his headlight trim with no problems. These sheets are really flexible. If you have any questiosn you can pm him
bimmerblvd is offline   Reply With Quote
Old 05-06-2005, 01:03 PM   #48
bimmerblvd
Past Site Sponsor
bimmerblvd's Avatar
My Ride: 2004 M3
It wouldn't look right to cover your entire roof because you will see the lines where the cf sheets cut off due to the size. I'm in the process of getting the sheets large enough to cover the roof.
Old 05-06-2005, 01:06 PM   #49
bimmerblvd
Past Site Sponsor
bimmerblvd's Avatar
My Ride: 2004 M3
you can easily wrap anything that curves, ask "otherside" if you don't believe me.
Old 05-06-2005, 01:10 PM   #50
bimmerblvd
Past Site Sponsor
bimmerblvd's Avatar
My Ride: 2004 M3
Old 05-06-2005, 04:05 PM   #51
budman
-not a mod-
budman's Avatar
My Ride: ..
I want a sheet for the roof.. that would be cool..
-Gunnar
budman is offline   Reply With Quote
Old 05-06-2005, 04:41 PM   #52
rayxi
My Ride: 2001 330xi
Just do a test wrap with construction paper. If you can do it without wrinkles or holes then it should work. Save the paper to use as the template for cutting out the CF sheet.
rayxi is offline   Reply With Quote
Old 05-06-2005, 04:45 PM   #53
tommiexboi
My Ride: 328i > 335i > M3 cab
Send a message via AIM to tommiexboi
smart man
[SOLD] "The OG M Parallel Master" =) ------------------------- [New] 2008 E90 335i "White Monster"
New Pictures 5/22
Window Regulator Write-up (DIY)
tommiexboi is offline   Reply With Quote
Old 05-06-2005, 05:22 PM   #54
rayxi
My Ride: 2001 330xi
Originally Posted by tommiexboi
smart man
I can't take credit for this idea. I saw the technique used on TV for custom body work.
Old 05-08-2005, 04:03 PM   #55
Born Again
Born Again's Avatar
Location: Tis quite a statement. Where do you live - where do we all live? in our minds? our souls? our bodies?
My Ride: She aint much 330ci
im curious to see how this works -
bump for a cheapo way to get carbon fiber-which-is-already-played-out
best mod to date : OEM grocery bag holder
Originally Posted by Zell View Post
E46Fanatics - the Honda community of gun owners. Keep staying classy, I'm sure you all are going to be excellent examples of how to keep gun rights from being infringed. :facepalm:
Born Again is offline   Reply With Quote
Old 05-08-2005, 11:50 PM   #56
///OSS
///OSS's Avatar
My Ride: "The.. 325CI"
Send a message via AIM to ///OSS Send a message via MSN to ///OSS
Its not an easy job, but with paitience you can do it.... I used a sheet of velum, traced the headlight trim, theres an area where obviously you would have to cut and make a seam, I carefuly used an exacto knife to cut and do it all, and it came out perfect....everybody thats seen it for real, has complimented it.... it was worth it, and you cant beat it for the price... it definitely not a job for everyone, but those who embark on it and take their time on each one will have a good chance of it coming out tight.... one sheet is enough for like 3 tries
good luck
///OSS is offline   Reply With Quote
Old 05-08-2005, 11:53 PM   #57
S2Krazy
A Flammable Plumber
S2Krazy's Avatar
My Ride: ****ED UP CL
Send a message via AIM to S2Krazy Send a message via MSN to S2Krazy
i`m sure if u add a litle heat to it , it would make it a lot easier to work with
S2Krazy is offline   Reply With Quote
Old 05-09-2005, 10:46 AM   #58
russ330
Mod Squad
russ330's Avatar
My Ride: Motorsport III
Send a message via AIM to russ330
Few more questions.
1.) Will there be sheets with different thicknesses available? I'd think that if there were thinner sheets it'd be even easier to work with.
2.) Can you post a pic of two different sheets side by side? I'd like to see how closely you can get the seams lined up between the different sheets.
3.) ETA on larger sheets? Perhaps sheets with a more rectangular shape?
Thanks.
russ330 is offline   Reply With Quote
Old 05-09-2005, 05:48 PM   #59
russ330
Mod Squad
russ330's Avatar
Old 05-09-2005, 09:45 PM   #60
bimmerblvd
Past Site Sponsor
bimmerblvd's Avatar
My Ride: 2004 M3
Originally Posted by russ330
Few more questions.
Thanks.
1. Only 1 thickness currently available
2. sorry no pics at the moment of the sheets side by site
3. no larger sheets at the moment
