Old 05-19-2005, 12:15 AM   #81
KillFox
KillFox's Avatar
My Ride: 2001 330xi
Send a message via AIM to KillFox
How would the CF hold up to heat? Could be an easy and cost efficent way to wrap engine covers
Sig by 325i-Vizon
KillFox is offline   Reply With Quote
Old 05-19-2005, 02:56 AM   #82
bimmerblvd
Past Site Sponsor
bimmerblvd's Avatar
My Ride: 2004 M3
Originally Posted by ininfinitum
Would it be possible to get different sized sheets? I only need something about half the size..
sorry but it only comes in 1 size right now
bimmerblvd is offline   Reply With Quote
Old 05-19-2005, 02:57 AM   #83
bimmerblvd
Past Site Sponsor
bimmerblvd's Avatar
My Ride: 2004 M3
not sure how it would hold up in the heat. ask "otherside" on how his is holding up to the headlight trim
Old 05-28-2005, 04:38 AM   #84
USCTrojanMan29
USCTrojanMan29's Avatar
My Ride: Beauty & The Beater
Send a message via AIM to USCTrojanMan29 Send a message via Yahoo to USCTrojanMan29
Very tempting, but I'm gonna stick to my "unique" theme of going NON-CF!
USCTrojanMan29 is offline   Reply With Quote
Old 05-30-2005, 06:40 AM   #85
Micro64
ACM3
Micro64's Avatar
My Ride: IRed/IRed M3
I AM UP FOR THE ROOF CARBONFIBERIZATION. As soon as you get larger sheets. The roof is flat enough. May be I am going to be a Test Lab Rat and buy one sheet and tryto warp something with it first.
SELLING MY IMOLA RED M3
SOLD!
Micro64 is offline   Reply With Quote
Old 05-30-2005, 11:54 PM   #86
JCz04Bimmer
JCz04Bimmer's Avatar
My Ride: 2004 330Ci & 06 Z4MC
Send a message via AIM to JCz04Bimmer
Any clue how large the roof is? I'm too lazy right now to go run out and measure it myself.
JCz04Bimmer is offline   Reply With Quote
Old 05-31-2005, 12:13 AM   #87
LewDog
My Ride: M3 Hardtop Cab
Send a message via AIM to LewDog
just curious... would these sheets possibly be a good alternative to buying CF interior trim? could the sheet be used to cover the existing trim and still fit in place and not fall off? if so i might just have to buy a sheet or 2 to cover my trim with...
LewDog is offline   Reply With Quote
Old 05-31-2005, 01:58 AM   #88
skylor318
My Ride: 135i
Send a message via AIM to skylor318
^ Not likely. I tried to do my headlight trim and had considerable trouble. I am going to research and see if there isn't some method to it that I am missing. While the sheet is flexible, it is only marginally flexible when you are going in 3D. It is fine for 2D, but will not stretch at all. You may get away with doing it on the front parts but I doubt it.
As far as heat goes. I held a hair dryer up to it on high for a considerable amount of time and had no problems with alterations in the material even though that was what I wanted to happen.
I used it on the rear reflectors and it worked okay. I still have to figure out how to get it to work well on the headlight trim. I can't seem to get it into the innermost corner by the grill. After I make another attempt I will once again give you my impressions.
I'm not sure if it would work on the roof either.
skylor318 is offline   Reply With Quote
Old 09-06-2005, 05:12 PM   #89
bimmerblvd
Past Site Sponsor
bimmerblvd's Avatar
My Ride: 2004 M3
Old 09-08-2005, 06:59 PM   #90
bimmerblvd
Past Site Sponsor
bimmerblvd's Avatar
My Ride: 2004 M3
Here is a picture of the silver carbon fiber sheet being used on another headlight trim. This one was done by "europass"
Thanks "europass" for the pictues.
Only 1 CF sheet is needed to complete the headlight trim
Old 09-08-2005, 09:25 PM   #91
DarXide
DarXide's Avatar
My Ride: Slammed on F2's
Send a message via AIM to DarXide Send a message via MSN to DarXide
1 sheet for both inserts? or just one side?
BTW do you have instructions??
FS 20'' Avus 3 piece wheels with tires 80% thread $2,000 + shipping
FS Brembo BBK 4 Piston 380mm front 345mm rear (silver) $3,800 + shipping
DarXide is offline   Reply With Quote
Old 09-09-2005, 04:53 AM   #92
bimmerblvd
Past Site Sponsor
bimmerblvd's Avatar
My Ride: 2004 M3
1 sheet will cover both sides. Nope I don't have a DIY, wanna make one?
Old 09-09-2005, 05:28 PM   #93
bimmerblvd
Past Site Sponsor
bimmerblvd's Avatar
My Ride: 2004 M3
Just found out that peopel wern't able to order because on site it shows item is out of stock. I have just updated that now and you guys can order with no problems now.
Old 09-11-2005, 10:26 AM   #94
europass
You ain't fresh AZIMIZ!!!!!
europass's Avatar
My Ride: 2003 325i, 2010 328i
No problem. Definately a great project to do. The results are not justified in pics and if you have Angel Eyes they show 10x better
Parts For Sale!!!
http://forum.e46fanatics.com/showthread.php?t=457935
europass is offline   Reply With Quote
Old 09-11-2005, 04:09 PM   #95
DarXide
DarXide's Avatar
Europass, you sticked this on the headlight trim and cut it to the edge? Is that it? Or you have to do something else...??
Old 09-11-2005, 07:05 PM   #96
BoostedBoogie
Banned
BoostedBoogie's Avatar
My Ride: facelifted e46
best way is to make a paper template of the headlight trim (that's what i did for my cf headlight trim) and then transfer it onto the cf. in my case i didn't use the cf sheets, but the same method will work just as well.
just as a tip for future DIYers, don't make the template all one piece. make it a 2-piece template taped together. one side for the inside of the headlight trim and the other for the bottom/curve. it's hard getting the paper to contour into that inner corner by the grill.
BoostedBoogie is offline   Reply With Quote
Old 09-12-2005, 03:04 AM   #97
VancouverEuros
My Ride: m
jesus christ. What's next, cf on a roll?
Then cf on a roll WITH a cf dispenser? wtf is this world coming to
VancouverEuros is offline   Reply With Quote
Old 09-12-2005, 01:56 PM   #98
DarXide
DarXide's Avatar
BimmerBlvd Are these sheets ready to stick them to the Headlight trim or they need resin and all the treatment??
Please let me know
Old 09-12-2005, 02:22 PM   #99
vaio76109
My Ride: Race Cars
Please let me know
Ready to stick...
vaio76109 is offline   Reply With Quote
Old 09-12-2005, 02:33 PM   #100
bimmerblvd
Past Site Sponsor
bimmerblvd's Avatar
My Ride: 2004 M3
looks good with the angel eyes
Please let me know
yes they are all ready to stick on. Nothing else needs to be done other then cutting them out to the shape you want.
