Old 05-06-2005, 08:28 PM   #1
mash20
Is not Persian
My Ride: '01 TiAg M3 Vert
LED Bulbs and Flickering Issues
I used to have LED bulbs in my rear turnsignals (before switching to OEM LEDs) and every now and then they would flicker. I guess the car was sending some current through them to make sure they were not burnt. From what I've heard, other people have had this happen too. Is there any way to avoid this, like a module or something you can hook up to stop this from happening? The reason I ask is that I'm probably going to switch my center brake light to the clear lens (convertibles only) and I was thinking about going with the LED one instead of the neon one. I don't want to get my computer reprogrammed to accept them because they're gonna charge me like $50 for it and was just thinking of throwing the load equalizers on it to trick the computer, but I dont want flickering. So, any way to stop the flickering?
mash20 is offline   Reply With Quote
Old 05-06-2005, 09:25 PM   #2
TravsM3
TravsM3's Avatar
My Ride: 05' 545i, ZSP
If you are going to but some LED's let me know, I am about to put together a group buy to save everybody 10%
TravsM3 is offline   Reply With Quote
Old 05-06-2005, 09:41 PM   #3
mash20
Is not Persian
this is for the center brake light though, not the turn signals
Old 05-07-2005, 07:12 PM   #4
mash20
Is not Persian
anyone?
Old 05-07-2005, 10:08 PM   #5
Alex323Ci
My Ride: M3 & 323Ci (sold)
Did you pull fuse #32? Do you have the fast blinker problem? I had to pull fuse number 32 and add some resistors inline. At start-up if you haven't seen the back of your car, it does three fast strobes. Then after that, it pulses every 30 seconds or so. Read this thread(click Link) and look at what I did on page 4. Mine work flawlessly. Hope this helps and ask me specific questions if needed after you read. I'm happy to help.
LED retrofit
Old 05-08-2005, 12:43 AM   #6
mash20
Is not Persian
oh snap! that thread helps a LOT! thanks a bunch, i'll try out the capacitor trick, but i wont be able to do it until the end of May (still in NY for college )
also, this is not for my blinkers, its for the center brake light for convertibles. i want to retrofit the clear LEDs but i dont want to pay a bunch of money to get my software updated
Old 05-08-2005, 04:50 PM   #7
Alex323Ci
I'm not sure if you'd need to do anything to the third brakelight. isn't yours already clear LED, mine are and they are stock, the Bentley manual also shows the third brakelight being LED. So even if they were a little different looking, the LEDs of the stock system would/should have the same resistance. Look at your third brakelight again, pretty sure you'll find it's already a LED bar. Keep me/us posted.
Old 05-08-2005, 05:12 PM   #8
mash20
Is not Persian
nope, i have a 2001 convertible M3. its a red lens with a neon tube. in mid 2002 i believe they changed it to a clear lens with a neon tube, then in about 2004 they changed it to a clear lens with LEDs. Heres how it is now and how i want it to be (steel gray is my sisters, hers is a 2004. titanium silver is mine)
ID:	125574   Click image for larger version
ID:	125575   Click image for larger version
Old 05-08-2005, 05:25 PM   #9
CynicalWry
Doesn't like PMs...Email me
CynicalWry's Avatar
My Ride: 00 323i-05 cbr600rr
Send a message via AIM to CynicalWry
Does that car give you a lights out error if the 3rd light goes out? If not, you won't have to worry about the flickering problem because the computer will not be looking to see if the bulb's out
.... just a thought
is your friend
Authorized Umnitza.com installer
301-825-5871
http://www.robinsNestChildCare.com - - - - - http://www.tntTint.net
CynicalWry is offline   Reply With Quote
Old 05-08-2005, 05:26 PM   #10
mash20
Is not Persian
.... just a thought
i was thinking that too. since its a neon tube, will it be checking to see if its burnt every 30 seconds? i really dont know, so i guess we'll just have to wait and see
Old 05-08-2005, 05:27 PM   #11
voon
My Ride: E46 330ci Coupe
Older cars (2001ish?) need their Lichtschalterzentrum (light module with the turn knob) exchanged, if you go LED, asfaik.
voon is offline   Reply With Quote
Old 05-08-2005, 05:30 PM   #12
mash20
Is not Persian
i have the new light module because i changed out my turn signals and everything about a year ago, so i dont think thats a problem. Like i said, i havent done this yet, im going to do it in about a month after i get back home
Old 05-08-2005, 05:39 PM   #13
CynicalWry
CynicalWry's Avatar
You'll also have to check to see if it's 12volts. The carpet isn't hard to take off, and unplugging the light is even easier (you'll need a torx head screw driver to remove some plastic under the trunk lid carpet before you can unplug the light.
is your friend
301-825-5871
Old 05-08-2005, 05:57 PM   #14
CynicalWry
CynicalWry's Avatar
check out this post for more information on the flickering. You could use the same wiring for your car
http://forum.e46fanatics.com/showthread.php?t=224984
is your friend
301-825-5871
