Old 05-14-2005, 03:33 PM   #1
Macario
My Ride: 325i
2001 E46 Radiator Hose Replacement
Hello all -
New to group here, and new to BMW. I want to replace upper and lower radiator hoses on my E46 but am unsure how to remove the clamps as I have only worked on American cars until now. Don't want to break anything. I know this is probably simple but I learn fast. If there is a DIY that talks about this just point me there.
Macario is offline   Reply With Quote
Old 05-15-2005, 10:05 AM   #2
kbsilver
My Ride: 2000 328i
I was told the hoses last almost forever
I was told the hoses last almost forever. Depends on your mileage. But I was told more than once BMW hoses will outlast the water pump and radiator, good for at least 120K miles. Now don't hold me to this, check with your dealer, but this is what I heard.
The plastic ends are molded to the hose. if you want to change them just pull the metal clips and they should slide off. Beileve they are sealed with O-rings.
kbsilver is offline   Reply With Quote
Old 05-15-2005, 01:00 PM   #3
Macario
My Ride: 325i
Thanks for the info. I have 55K miles on my E46 and unsure if the hoses were ever changed by the previous owner but they look fine. I am going to drain and refill with coolant/distilled water mix very soon. Thanks again.
Mac
Old 05-15-2005, 06:50 PM   #4
kbsilver
My Ride: 2000 328i
One word - Water Pump
One word - Water Pump. You look like you want to do some preventitive maintenance. Many mechanics recommend replacing the water pump on our cars every 60K miles as they can start failing at that point. You do not want to overheat the straight 6 as with the long cyllinder head, it will warp almost eveytime. Search the archives.
You going to spend nearly $30 on BMW coolent (which is what we all recommend), might as well spend the extra $55 or so on the pump. The water pump is sealed with an O-ring, not a gasket, so it's an easy change out.
At it turns out I'm all set for my 60K mile maintenance coming up in about a month. I have the new water pump, new belts, coolent, air fillter, and fuel filter ready to go. Got them all from the dealer (the one I use gives 25% off on Saturdays to BMWCCA Club members).
Old 08-07-2005, 01:34 PM   #5
Macario
My Ride: 325i
Thanks Silver
Old 08-07-2005, 02:34 PM   #6
Surk
My Ride: C Blk E46///M3
Good advice on the WP.. they are known\prone to go without notice... I'm at 65k miles on mine aand may just do it as prevent maint.. it feels good without play.. but you never know what road trip it fails on...
Here's a helpful WP replacement DIY from my buddy Mark (Canuck328i) to help anyone considering it..
http://www.tuningemotion.com/forum/s...ead.php?t=2094
Surk is offline   Reply With Quote
Old 08-07-2005, 03:53 PM   #7
///Mechanic
My Ride: None currently
Me - "Don't fix it if it ain't broke"
You - If you got the money to waste, go ahead
YOU BOUGHT A BMW, IF YOU CANT AFFORD TO MAINTAIN IT............SELL IT.
///Mechanic is offline   Reply With Quote
Old 08-13-2005, 02:39 PM   #8
Macario
My Ride: 325i
Surk thanks for the good DIY. I appreciate it.
Old 08-14-2005, 04:40 PM   #9
Surk
n\p
Canuck328i is the DIY Guru at our meets..
Old 08-15-2005, 10:22 AM   #10
munya
My Ride: 2012 Legacy GT
Send a message via AIM to munya
What about http://www.bavauto.com they have a replacment pump with a metal impellar.
Would this be a longer lasting solution?
josh
munya is offline   Reply With Quote
Old 08-15-2005, 09:05 PM   #11
kbsilver
My Ride: 2000 328i
Mine was metal from the factory
Just got around to changing the water pump on my 2000 328i at 62K miles. The original looked fine, had a metal impeller as did the replacement I purchased from the dealer. It took longer to drain the cooling system than it did to change the pump.
The pully was stuck to the pump and needed some force to get off. Be careful, the pully IS made of plastic.
Old 04-30-2006, 12:55 PM   #12
silverbeamr
My Ride: 325i
you don't have to drain the system to change the water pump!
Driving an automatic is like having sex with a blow up doll-- sure she's easy, but not nearly as fun, and she's nothing you'd go bragging to your friends about.
People who track their cars make a safer road environment for everyone else.
silverbeamr is offline   Reply With Quote
Old 05-08-2006, 01:53 AM   #13
Rdizzle
My Ride: '00 328Ci
Hello all -
It's actually really easy. There's a little spring clip on the ends of the hoses. Just use a flathead screwdriver to lift up the spring clip and put the hose out. I changed my upper radiator hose in like 15 minutes. I will do the lower one soon when I flush the coolant.
'00 328Ci Step + Sport & Premium Packages
Mods:
BMP Design Front Strut Bar | K&N 63 Series Intake | LED Interior Lighting | M3/H&R Sway Bars | OEM Bi-Xenons + CCFL Angel Eyes | Smoked Turn Signals | UUC SS Brake Lines | ZHP Shocks & Springs
Rdizzle is offline   Reply With Quote
Old 05-24-2006, 06:15 PM   #14
jansenw
My Ride: 2001 330i 4-door
Just replaced my 2001 330i upper hose assembly ($33). The pressure release plug was sheered off and not maintaining pressure (I could fill the reservoir up but coolant would come bubbling out of the plug hole). I don't know what could have sheered it off. The snap rings made attachment easy (15 min.) once you got everything aligned.
jansenw is offline   Reply With Quote
Old 05-24-2006, 07:29 PM   #15
generx
My Ride: scrapes
I agree on changing the WP, e46s (and e36s) are plagued with cooling issues when not maintained and as long as you're there, you may as well change out the t-stat and belts (BTW, belts are pretty much done at 50K, mine had chunks missing that were not visible, it's about $30+ for both) All very very easy to do since it's up top (WP is held on with 4 nuts, t-stat is held on with 4 nuts) Coolant was $20 from the dealer, in fact the t-stat, WP, and coolant all were really reasonably priced from my local dealer, besides I couldn't wait to do it at the time.
The WP that I removed at 47K had the newer composite impeller, looked new, worked fine, but for under $80 would rather replace. Already had a WP failure with my old e36 and that cost me a lot of $$$ (overheated, blew head gasket) It's alarming how quickly it happened too, temp just shot up, I shut it off but damage was already done. I'm paranoid now so I firmly believe in prevention.
The oldest water pumps are plastic (white impeller) then they came out with the metal ones (shiny metal impeller) and the latest ones are composite (looks like black plastic/composite) so get the newest one if you end up changing it.
generx is offline   Reply With Quote
