DDE Remote Activation Kit Installation - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-18-2005, 10:34 PM   #1
bimmerblvd
Past Site Sponsor
bimmerblvd's Avatar
My Ride: 2004 M3
Thumbs Up DDE Remote Activation Kit Installation
THIS DIY IS FOR THE DDE REMOTE ACTIVATION KIT WE SELL
DDE Remote
Kit Activation Installation DIY
(BimmerBlvd)
Written By
Tommiexboi
  1. The package comes with four things: The relay with a
    wire stuck to it, a grey wire, and a red wire with a fuse with it and a
    connector.
  2. This is how the Relay looks like with the wire.
  1. Unplug the wire from the relay and plug it into the
    back of the relay connector
  1. From that you plug the relay into the connector, be
    sure the wire in the connector is connected to the relay
  1. Open the ECU box
bimmerblvd is offline   Reply With Quote
Old 05-18-2005, 10:37 PM   #2
bimmerblvd
Past Site Sponsor
bimmerblvd's Avatar
My Ride: 2004 M3
Thumbs Up
  1. Get a coat hanger or some time a long rod and shove
    the wire through the firewall, on the inner side of the car, there’s a hole
    that leads inside your cabin.
  1. Now go inside your car and look under your steering
    wheel, you’ll see three screws and two plugs. (the plugs are located at 1.
    the middle side of the plastic and, one near the brake pedal. (Now unscrew
    everything)
8. Now that you unscrewed
everything, you might wonder… wtf? It’s not coming off, well there’s two clips
right under the steering wheel, where the gap is, slowly but with force remove
the plastic from the clips. (be aware it might snap off)
9. Now locate the dome light, it
is on the left side of the plastic. Find the wires that are connecting to it.
There is a wire that has a red stripe on it. That is the Positive of the
footwell light.
     10.     After you have located
the wires,  connect the red wire with the fuse holder to the grey wire.
Then using the blue t-tap, tap that into the red stripe wire which is the
positive of the footwell light. Then connect the end of the red wire to the blue
t-tap… Again let me apologize for the horrible picture.
And you’re done!!!!
Connect everything together, and
put everything back to where it was and your done!          Have fun with your
remote kit!
-Tommiexboi
Old 05-19-2005, 05:04 AM   #3
tommiexboi
My Ride: 328i > 335i > M3 cab
Send a message via AIM to tommiexboi
yay~
[SOLD] "The OG M Parallel Master" =) ------------------------- [New] 2008 E90 335i "White Monster"
New Pictures 5/22
Window Regulator Write-up (DIY)
tommiexboi is offline   Reply With Quote
Old 05-22-2005, 12:46 AM   #4
dj_esuna
My Ride: 2003 M3
On my car it looked more like a blue wire with a red stripe... took me forever to figure out which wire it was. In any case, I think we can all agree that it's *not* the orange wire.
Nothing to see here :)
dj_esuna is offline   Reply With Quote
Old 07-01-2005, 12:39 AM   #5
drummersam65
My Ride: 323i
I have a 99 323i, and there is no footwell light. What else should I connect it to?
drummersam65 is offline   Reply With Quote
Old 07-03-2005, 08:51 PM   #6
caMber156
loves M.J.
My Ride: II.V
^^hmmm
caMber156 is offline   Reply With Quote
Old 07-03-2005, 10:50 PM   #7
kilronan
My Ride: E46
DDE Remote install (if you don't have footwell lighting)
kilronan is offline   Reply With Quote
Old 07-04-2005, 12:17 AM   #8
drummersam65
My Ride: 323i
wow, thanks guys, this is going to be a bit harder now...
Old 11-14-2005, 10:33 PM   #9
Kits013
My Ride: 330i w/ZHP
sorry
i have a very noob question
i don't get the first step
so i have to unplug everything from the relay connection first?
( the black that used to install the DDE )
then plug it in to the new relay connection?
Kits013 is offline   Reply With Quote
Old 11-23-2005, 11:54 PM   #10
tilua
My Ride: 330Ci, X5, 335i Conv
Send a message via AIM to tilua
[QUOTE=bimmerblvd]
  • Unplug the wire from the relay and plug it into the back of the relay connector
  • From that you plug the relay into the connector, be
  • QUOTE]
    The first part was still unclear to me. I'm guessing we are only using 1 relay for the whole DDE setup with the remote on function? And using the positive node of the dome light to activate the relay.? That same connector on the relay is also connected to the (RED/Yellow with WHITE dot) in the ECU box. Please clarify.
    tilua is offline   Reply With Quote
    Old 01-17-2006, 08:43 PM   #11
    badbunny1984
    badbunny1984's Avatar
    My Ride: 2005 M3
    Send a message via Yahoo to badbunny1984
    yeah....please!!!! I have a red wire coming out of both headlight leads in addition to the usual white and brown for the ballasts....
    Chuck
    badbunny1984 is offline   Reply With Quote
