Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Lighting & Mobile Electronics (I.C.E.)
Xenon lighting, HID kits, fog lights, BMW head units, navigation, speakers, subwoofers, In Car Electronics (I.C.E.), carputers, DDEs, angle eyes, halos, LED tail lights, interior lighting, etc.
Old 05-30-2005, 06:49 PM   #1
KillFox
KillFox's Avatar
My Ride: 2001 330xi
Send a message via AIM to KillFox
Used ALpine MRV-F340 4 Ch Amp V12
This is my old amp, which was replaced by a new MB Quart amp last week. I no longer need it, so I am going to hook up my fellow fanatics. The amp cost me close to $450 about two years ago . Now, as with all technology, it's price tag has come down considerably. New/used ones of this amp are going for $150++ start bids on ebay.
Alpine MRV-F340 V12 4/3/2 Ch amp, please go to http://www.alpineusa.com for all the info.
Great little amp, it ran my stealthboxes for the last 6 months.
Things to consider:
I lost the little allen screws that hold the two cover plates onto the amp (they cover the wired inputs for looks). I never even had them on, so i dont know where the screws went
Also, one of the copper screws that bolts down power/ground is missing. I can probably find this in the trunk of my car somewhere it was on before i uninstalled the amp. Underneath the power screw mount, the plastic broke somehow... It does not affect anything, its just mentioned in the interest of full disclosure.
Finally, one of the protection plates mentioned above has a small 1 inch scratch in it.
$85 shipped FIRM. I will ship via USPS priority mail within 48 hours of paypal receipt. This amp is in perfect working order, and is a good little amp for running speakers or stealthboxes.
Pics up shortly.
Sig by 325i-Vizon
KillFox is offline   Reply With Quote
Old 05-31-2005, 05:27 PM   #2
KillFox
KillFox's Avatar
My Ride: 2001 330xi
will toss in a Fosgate 8 GA Power wire, ground, fuse holder, and some fuses free. Enough slack to mount the amp directly under the rear deck of the trunk. (have another power wire longer if you need)
Sig by 325i-Vizon
Old 05-31-2005, 06:49 PM   #3
KillFox
KillFox's Avatar
My Ride: 2001 330xi
Wow, MSRP is still $430 according to www.alpine-usa.com
Here is the info on the amp:
14.4V RMS Continuous Power 2ohm; Stereo (0.3% THD) 65Wx4 4ohm; Bridged (0.3% THD) 130Wx2
• 12V RMS Continuous Power 4ohm; Stereo (0.08% THD) 35Wx4 2ohm; Stereo (0.3% THD) 45Wx4 4ohm; Bridged (0.3% THD) 90Wx2
• Bass Engineฎ
• S/N Ratio 100dBA
• Frequency Response: 10-50kHz
• 12dB HP/LP Crossover
(50-200Hz)
• Speaker Level Input
• Subsonic Filter (15Hz)
• Extra Large Gold Plated Terminals with Wire Insert Capability
• Top Panel Power LED
• 4 Volt Input Capability
• Continuously Adjustable Crossovers
• DC Straight, STAR Topology
• DC-DC/PWM MOSFET Power Supply
eneral-Amplifiers
# Adjustable Crossover (HP/LP)
# Bass EQ Circuit
# Phase Selector
# Subsonic Filter
# 4/3/2 Channel Operation
# Auto Overcurrent Protection
# Bass EQ Circuit
# Bass Engineฎ
# DC Straight Design
# DC-DC PWM Power Supply
# Discrete Pre-Amp Stage
# Gold Plated RCA Input Connectors
# Input Mode Selector Switch
# Integrated Wire and Mounting Screw Terminals
# MOSFET Final Outputs
# MOSFET Power Supply
# MultiMode
# Noise Elimination Coil
# Non-Fading Pre-Amp Output
# One side Terminal Layout
# Phase Selector
# STAR Circuitry
# Solid Copper Bus Bars
# Speaker Level Inputs
# Subsonic Filter
# Top Mounted Blue LED Power/Status Indicator
Specs:
Bass Engineฎ
* Crossover Network : 30Hz-400Hz HP/LP (12dB/oct)
* Subsonic Filter (Fixed) : (Ch 3/4) 15Hz
* Tuned Bass EQ (Variable) : (Ch 3/4) 50 Hz (0 - +12dB)
General-Amplifiers
* Dividing Network : 30Hz-400Hz HP/LP (12dB/oct)
* Foot Print (WxHxD)in : 11-13/16” x 2-3/8” x 12-7/16”
* Foot Print (WxHxD)mm : 300mm x 60mm x 315mm
* Frequency Reponse : 10Hz-50kHz (+0,-1dB)
* Heat Sink (WxHxD)in : 9-7/8” x 2-3/8” x 12-7/16”
* Heat Sink (WxHxD)mm : 250mm x 60mm x 315mm
* Input Impedance : 10k ohm
* Input Sensitivity (for rated power) : 0.2 V to 4.0V
* Power Requirements : 14.4V DC (11V to 16V)
* Signal to Noise (S/N) : 100dBA (referenced to rated power)
* Slew Factor : greater than 5
* Speaker Impedance : 4 or 2 ohms(stereo), 4 ohms(bridged)
* Weight : 4.2kg(9lbs. 4oz.)
MAX Power (at 14.4V,EIAJ)
* Bridged 4 ohms : 250W x 2
* Per channel into 4 ohms : 100W x 4
RMS Power (at 12V,20Hz-200Hz)
* Bridged 4 ohms : 90W x 2
* Per channel into 2 ohms : 45W x 4
* Per channel into 4 ohms : 35W x 4
RMS Power (at 14.4V,20Hz-200Hz)
* Bridged 4 ohms : 130W x 2
* Per channel into 2 ohms : 65W x 4
* Per channel into 4 ohms : 55W x 4
Road tested and time proven, V12 amplifiers with their "no shut down" design keep playing when you need them the most. The Audio Quality MOSFETS and Subsonic Filter restore power and produce killer, tight crisp bass. They're also Bass Engine Ready meaning they can handle the juiced signal from an Alpine Bass Engine Equipped head unit.
Sig by 325i-Vizon
Old 06-02-2005, 11:28 AM   #4
KillFox
KillFox's Avatar
My Ride: 2001 330xi
Sig by 325i-Vizon
Old 06-02-2005, 12:34 PM   #5
Arram
My Ride: 323i
will this amp work for a jl w6 sub?
Arram is offline   Reply With Quote
Old 06-02-2005, 12:44 PM   #6
Davidjay
Davidjay's Avatar
My Ride: 2004 X3 3.0
Send a message via AIM to Davidjay
I will take it!
Davidjay is offline   Reply With Quote
Old 06-02-2005, 01:11 PM   #7
KillFox
KillFox's Avatar
My Ride: 2001 330xi
Sale pending to David.
I see no reason why you couldnt power a JL W6 with it.
Sig by 325i-Vizon
Old 06-02-2005, 01:29 PM   #8
Davidjay
Davidjay's Avatar
Sold
Old 06-02-2005, 03:12 PM   #9
KillFox
KillFox's Avatar
My Ride: 2001 330xi
SOLD to David Thanks for looking
Sig by 325i-Vizon
