Thread Tools Search this Thread Rating: Thread Rating: 36 votes, 4.94 average. Display Modes
Old 12-23-2005, 12:55 PM   #21
kbsilver
My Ride: 2000 328i
Believe the 49D AutoZone battery is longer
Believe you will find the AutoZone 49D 1.5" longer, and 0.5" shorter than OEM, but not to worry.
From what I unsderstand the battery tray is adjustable to handle the longer battery. Also the battery is mounted from the tabs near the bottom, so the fact it is not as tall does not matter. It still has more capacity than OEM.
I have been told that the 94R is the exact same size, but also costs $20 more.
My car is almost 6 years old with original battery so do not have this experience yet. I expect will be going thru it soon. Not that it matters, never added any water (never checked it for that matter) as still runs perfectly. (Great, just jinxed myself).
kbsilver is offline   Reply With Quote
Old 12-30-2005, 10:32 PM   #22
InSuboRdiNaTioN
Mmm, Pancakes.
InSuboRdiNaTioN's Avatar
My Ride: Collects dust.
Originally Posted by ProV1
Is the Autozone 49DL a PERFECT fit in the E46 trunk? Are the height & width identical to OEM?
Just put one in my Dad's E39 today, and it fit every bit as well as the OEM. It even comes with a small adapter kit to make the vent hose work.
Should be the exact same story for the E46.
And the dimensions seemed identical to OEM when we compared the two side by side at the store.
To reference the above post, I'm pretty sure the 94R is about an inch or so shorter length wise, and puts out less juice.
Originally Posted by vincentvega9701
one moment, you're rolling. the next, you're blowing a guy for a sandwich
InSuboRdiNaTioN is offline   Reply With Quote
Old 12-30-2005, 10:59 PM   #23
UnBreakable
My Ride: OB E46 328i
When removing a battery the rule of thumb is:
Remove Negative first positive later.
When installing a battery:
Positive first negative later..
..unless you wanna shock yourslelf
UnBreakable is offline   Reply With Quote
Old 01-30-2006, 11:57 AM   #24
Drex
My Ride: Cosmic Waves
Good info here. saves me the trip to the dealer. My OEM battery just died on my 00 328. to autozone I go!
Drex is offline   Reply With Quote
Old 07-24-2006, 02:15 PM   #25
bender
hammer talks like this
My Ride: 2006 Honda insight
Send a message via AIM to bender
I've had my car since november 31, 2001 with currently 45,500 miles on it and I suspect the battery is done. is that about right 4.5 yrs, 45k mile?
bender is offline   Reply With Quote
Old 07-24-2006, 02:17 PM   #26
slow323ci
E46-free since 10-13-06
My Ride: 335i coupe
If you live in Houston it's a good possibility. When I lived there my cars seemed to eat batteries like crazy. The heat is hard on them.
slow323ci is offline   Reply With Quote
Old 07-24-2006, 02:18 PM   #27
bender
and the dealership wont cover the battery under their 5 yr service warranty? they said they cover everything, even windshield wipers..... i guess a $100 part is considered along the same lines as gasoline when it suits them
Old 07-24-2006, 03:05 PM   #28
slow323ci
My Ride: 335i coupe
Isn't the maintenance service coverage 3 years or 36,000 miles?
Old 07-24-2006, 04:10 PM   #29
ciello
Banned
My Ride: 325ci
convertible has different size of battery compare to coupe
am i right?
ciello is offline   Reply With Quote
Old 07-24-2006, 04:57 PM   #30
slow323ci
My Ride: 335i coupe
am i right?
That is correct. Convertible battery is physically smaller, it's a 94R if I remember correctly.
Old 07-24-2006, 04:58 PM   #31
2005_330xi_BMW
My Ride: 330xi
Originally Posted by HOMEP1
Hey, I'm not car inclinded, but I would like to know how I can replace my own battery (without going to the dealer). Assuming I buy a Duralast 48 or 49 DL at Autozone. If anyone has the instructions, or just a pointer, please let me know. Thanks...
The hardest part is finding it...
2005_330xi_BMW is offline   Reply With Quote
Old 07-29-2006, 01:01 PM   #32
rkhettry23
My Ride: Has2Turbos & X-Drive
what is the purpose of the vent hose thingy? The battery seems to work fine without it? should i bother connecting it? (with the adapter from the ds-49)
-Raj
2009 535i w/X-Drive
2002 325xi--Parted Out
rkhettry23 is offline   Reply With Quote
Old 07-29-2006, 01:03 PM   #33
tblue3cibm
My Ride: allroad / Hayabusa
takes 10mins tops
tblue3cibm is offline   Reply With Quote
Old 07-29-2006, 02:08 PM   #34
rkhettry23
Originally Posted by tblue3cibm
takes 10mins tops
i'm well aware i just wanted to know what it actually does? plus i have some extra wires around from my ice so it is actually a pain for me to take all that **** out....I just wanted to know if it was imperitive to connect the hose?
-Raj
2009 535i w/X-Drive
Old 07-29-2006, 02:19 PM   #35
russ330
Mod Squad
russ330's Avatar
My Ride: Motorsport III
Send a message via AIM to russ330
I can't say for certain, this is heresy from what a guy at Advance Auto Parts or Auto Zone whatever said, but...
Supposedly the vent is there to, gasp, vent the gasses from the battery to outside of the car. When a battery is placed under the hood there is room for the gasses to expand and exit to the atmosphere under the hood. When a battery is in the trunk it's sealed up and the gasses aren't able to escape. I guess the pressure build up isn't good.
Like I said this is all what homeboy told me, take it with a grain of salt especially in light of the fact that I have had a battery in the trunk of my E36 with a vent tube just dangling around not hooked anywhere and no nuclear explosions have occurred.
russ330 is offline   Reply With Quote
Old 07-29-2006, 03:11 PM   #36
slow323ci
My Ride: 335i coupe
A non-sealed battery like the ones in our car generate hydrogen gas whenever they are recharged, which is pretty much whenever the car is running.
If you don't vent the hydrogen gas from the trunk, and you get a spark from any of the electrical doodads back there, it is theoretically possible for your car to do a good imitation of the zeppelin Hindenburg, circa 1937 at Lakehurst, NJ.
Old 07-29-2006, 03:35 PM   #37
rkhettry23
hmm very interesting, I just wantd to also say that I have modified the "flaps" in the trunk...they kinda resemble gills (often they are the culprits for vibrations from bass)...basically i cut them all out so now there are just holes on either side of my trunk that go into the bumper....i doubt i'll have any issues with build up but I would rather do it than now....thanks everyone
-Raj
2009 535i w/X-Drive
Old 07-31-2006, 01:54 PM   #38
louiegz
My Ride: 03 BMW 330i 40k
So I have 2 questions.
1.) About how long should I expect the original battery last me?
2.) What size of Optima Battery should fit? I have one in my other car and I like them.
louiegz is offline   Reply With Quote
Old 07-31-2006, 04:31 PM   #39
ca1242
My Ride: 2003 330i
Original battery? depends. Mine started having problems a little over a year since I bought the car new.
If our cars sit for an extended period of time, the car's electronics will drain a battery. When a battery gets completely depleted, it reduces it's life span. At the dealer, I always see cars at the showroom/parking lot with drained batteries that need to be charged, so if your car has been a the dealer for a while before being sold, the battery will most likely not last very long.
The battery compartment is pretty large, so I would think that any Optima should fit. Open it up and take some quick measurements, then check optima's website. I recently bough an optima for the wife's minivan at Pep Boys (they also sell them at Costco). If you have a big sound system, you might also want to look at a Stinger 1700. I have one in my car and it is the beast battery I have ever owned (better than Optima, but costs more).
Old 02-04-2007, 09:36 PM   #40
XKxRome0ox
Black and Proud
My Ride: RIP e46/'16 328i
this is great info
thanks guys
now only question...
the phillips screwdriver needed to unscrew the mounting screw... is the one in the BMW toolkit in the trunk long enough?
or do i need a longer one?
is there any tool i need that's not provided for me in the car?
2016 BMW 328i 6MT/M Sport Package/Track Handling Package/BMW M Performance Exhaust/Injen CAI
XKxRome0ox is online now   Reply With Quote
