Old 06-27-2005, 01:30 PM   #1
kwang1
E69Fanatic
My Ride: 2000 323i
Question price for control arm bushing replcaement
Hi yall:
when I brake, I can see my front wheel shift forward alittle, and from what a mechanic tells me, my bushing needs to be changed, have any of you had this done? if so can you tell me a general price so when I go to get it fixed I kind of have a ball park price in mind? thanks. I live in LA culver city by the way, any recommandations on where to go?
thanks!
kwang1 is offline   Reply With Quote
Old 06-27-2005, 02:32 PM   #2
Spiral Prophet
‹ber-Geek
Spiral  Prophet's Avatar
My Ride: '01 Topaz Blue 330ci
Send a message via AIM to Spiral  Prophet
i replaced the front controll arms and bushings myself.. parts were somewhere around 400.. and took me 2 1/2 hours taking my time..
so i guess a shop would charge you probably 500 for the parts (unless you buy them yourself) and then 2 - 3 hours labor?
~T|/\/\
Spiral  Prophet is offline   Reply With Quote
Old 06-27-2005, 03:07 PM   #3
iverson2k10
My Ride: 2000 323i(sold) -
Send a message via AIM to iverson2k10 Send a message via MSN to iverson2k10
Thumbs Up
I got control arms, bushings,endlinks and brake light sensor for 325 that was including Labor .... it literally does pay to know someone whos a Machanic for the Dealership. i try to hook up any e46 member that lives near Rhode Island.
iverson2k10 is offline   Reply With Quote
Old 06-27-2005, 03:20 PM   #4
323power
323power's Avatar
My Ride: '11 335i
My dealer wanted $999.99 for New control arms + bushings. I got it done at my independant shop for $800. Parts were a little over $500.
Jeff
323power is offline   Reply With Quote
Old 06-27-2005, 03:22 PM   #5
chachi328CI
My Ride: 2000 328CI
Send a message via AIM to chachi328CI
Mine were around $400 for the parts.
I did the install my self. Passenger side is more complicated as the mount in an awkward location below the motor.
If you donít have the removal tool for the passenger side or if you have no patients I would have either someone who has done them before, or have your mechanic take a look.
It's surely not a dealer piece to have replaced unless you like to yell RAPE. Any German Auto repair shop should have no issues with this work, and it will save you tons.
Plan on doing this for the life of your E46. I would recommend the nylon bushing instead of factory as you will get some more life out of them.
Also - there is a helpful DIY out here. It is step by step with pictures for doing this in your garage.
chachi328CI is offline   Reply With Quote
Old 06-27-2005, 03:25 PM   #6
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
Stealership told me they wanted 1100 to do it... fortunately, I had bought the car pre-owned with the 100K mile warranty two weeks earlier and caused such a fit they did it free of charge
Timeless Motor Group
Old 06-27-2005, 03:29 PM   #7
323power
323power's Avatar
My Ride: '11 335i
Yea, they claimed $1k + $130 for alignment (which i don't think is required anyway for control arm replacements). So I saved $330+. Used it towards my new wheels from NorthJersey3er
Jeff
Old 06-27-2005, 04:12 PM   #8
luckysnafu
My Ride: 03 ZHP|90 332(s52)
If all you are doing is changing the bushings, the bushings with brackets will cost you just over $100 at either autohausaz.com or turner motorsport. I replaced mine last weekend and it took me less than 2 hours. Check the ball joints on your control arms for cracks/leaks in the rubber seals. If there are any, replace both control arms and get new bushings. If you replace the bushings only, you should not need an alignment.
luckysnafu is offline   Reply With Quote
Old 06-27-2005, 04:48 PM   #9
kwang1
E69Fanatic
My Ride: 2000 323i
the shop told me all I need is bushing, cooL!
Old 06-27-2005, 05:38 PM   #10
BMWtech
My Ride: all of em
Seriously Dont Install These Yourself. Someone Did A Dyi And The Pressed The Bushing Out Of The Metal Brackets. The Bushings Come With New Brackets. Parts Are Like 180, Plus 3 Hrs Labor. Come To Crevier Ask For Gary Temel And Tell Him Jeff Sent You.
Fixed Right First time, on time, everytime
BMWtech is offline   Reply With Quote
Old 06-27-2005, 05:43 PM   #11
a s u r a 0 s 9
Nikkei is a $lut.
My Ride: is always in a shop
if you're in Norcal...and u have extended warranty...
ask for Gene at Fremont BMW and he'll hook you up with a warranty covered replacement!
a s u r a 0 s 9 is offline   Reply With Quote
Old 06-27-2005, 06:17 PM   #12
figuej
My Ride: 330i 2001
Anybody knows if control arm bushings from the ZHP are the same or different from normal sport package??? Thanks
figuej is offline   Reply With Quote
Old 06-27-2005, 06:31 PM   #13
kwang1
E69Fanatic
My Ride: 2000 323i
darn, i am in Socal
Old 06-27-2005, 07:26 PM   #14
rockwell
My Ride: E46 & E60 ;)
Send a message via AIM to rockwell
about $400 for parts and labor from what my mechanic told me...replacing everything too, not bad....
rockwell is offline   Reply With Quote
Old 06-29-2005, 01:37 PM   #15
kwang1
E69Fanatic
My Ride: 2000 323i
your car is sick~!
Old 05-10-2006, 11:40 PM   #16
cory58
My Ride: e46 / e30 / F30
In the Bentley manual, it recommends a BMW ball joint tool to remove the control arm. Will a generic ball joint tool or forked pry bar work without tearing up the seal on the ball joint? This site is great!
cory58 is offline   Reply With Quote
Old 05-11-2006, 01:15 PM   #17
markusmark
My Ride: 2001330Ci
Nope!
markusmark is offline   Reply With Quote
Old 05-12-2006, 01:27 PM   #18
cory58
Thanks for the response. Should I buy the BMW tool?
Old 05-12-2006, 01:52 PM   #19
vert
My Ride: MINI Cooper Hatch
Send a message via AIM to vert
Why would you care if you rip the ball joint seal if you are replacing the whole arm with a new one anyway? LCA diy on this site says you just need a pickle fork and a 10lb sledge hammer, then just install the new ones
vert is offline   Reply With Quote
Old 05-12-2006, 05:23 PM   #20
gjeldubbimmer
gjeldubbimmer's Avatar
My Ride: has a childseat coco
$400 installed in an independent shop
gjeldubbimmer is offline   Reply With Quote
