Thread Tools Search this Thread Rating: Thread Rating: 18 votes, 5.00 average. Display Modes
Old 07-29-2010, 06:53 PM   #141
TerraPhantm
My Ride: M3 & ZHP
Bump, would really like to do this before the summer's over and I don't trust myself to make the harness. If anyone knows a source I'd really appreciate it
Old 09-18-2010, 03:16 PM   #142
throttlehead
My Ride: 330i Imola ZHP 6MT
I would like a front and rear wire harness as well
I have my bosch/bmw bixenons in and currently manually adjusted but would like to follow through the entire project.
2003 BMW 330i ZHP
Imola Red Saloon
6MT
throttlehead is offline   Reply With Quote
Old 11-01-2010, 11:38 AM   #143
TerraPhantm
My Ride: M3 & ZHP
Looks like we've either got to build our own or salvage the harness from another e46 in order to complete the retrofit.
hmm, you and I both have imola ZHPs - too bad the previous owners didn't spend the $700 and just get the damn xenons from the factory
Old 03-24-2011, 12:26 AM   #144
EnDLeSs_27
My Ride: 325ci
Does anyone have a guide with pictures saved somewhere that they would like to share?
Endless Naruto The Greatest Naruto Anime & Manga Fansite!
D-Gray-Man The Ultimate D.Gray-man Fansite!
PS4Lounge.com The First PS4 Community
EnDLeSs_27 is offline   Reply With Quote
Old 11-20-2012, 05:56 AM   #145
dvd64
My Ride: bmw e46 CI
I know old post , but i find this : http://cgi.ebay.fr/Kabelsatz-aLWR-BM...item19d3113c54
or this one more easy to install (UNIVERSAL LEVELING SYSTEM) :
http://www.alibaba.com/product-gs/56...ng_system.html
dvd64 is offline   Reply With Quote
Old 01-31-2013, 02:16 AM   #146
rediahad
My Ride: 330CIC
has anyone found a vendor in america that has these harnesses and cable already dont basically just mount the sensors run the cables and plug and go
rediahad is offline   Reply With Quote
Old 08-05-2013, 08:21 PM   #147
wooboodoo
wooboodoo's Avatar
My Ride: is alpine white...
Hey folks,
I know that this thread is older than me but had nothing better to do the other day so decided to finish what I started 5 years ago lol...
Yes about 5 years ago I run harness A from leveling sensors to LCM, it was challenge to run these harness under the carpet but I got this done long time ago. Installed and connected rear leveling sensor, plugged in all plugs into LCM then got stuck with some parts since my car is awd, it was probably that special bracket for front leveling sensor plus harness B.
Finally I got back to this mod, did myself harness B run it nicely connected to headlights and LCM, today got parts from tischer BMW and installed front leveling sensor... All wiring is completely done but auto leveling doesn't work so far.
My car has halogen headlights from factory so I bought bi xenons long time ago and programmed LCM but after that my hi bims stop working...
My question is, do I need newer LCM from car with auto leveling option (I can buy LCM from 2005 M3) my car is 2003/03 or I can try to program my existing LCM?
How I can fix hi bims? There are extra small plugs in headlights anybody can help me what to connect there?
Any help will be highly appreciated.
mark
No matter which BMW model you drive, pure chiseled performance is the
pulsating heart of its DNA. Yet the 13th letter of the alphabet takes every
BMW built-in performance advantage and amps it up to the Mth degree.
Call it the Year of M.
D. Randy Riggs
wooboodoo is offline   Reply With Quote
Old 08-05-2013, 09:58 PM   #148
TerraPhantm
My Ride: M3 & ZHP
You need an LCM from an HID car (as long as it's not a facelift coupe). The HID LCMs have stepper motor controllers that the halogen ones don't. They also have circuitry to read the information from the leveling sensor.
An 05 M3 LCM will be fine as long as that M3 had HIDs
To use the bixenons, you need to run two additional wires from the LCM. They go to the center pin of the 3-pin plugs on each ballast.
You'l want the following items
61138365348 x 2 -- Bixenon Connector (3-pin AMPseal connector)
AMP 962885-1 x 2 OR 61131393704 x 2 -- MQS Contact
AMP 967067-1 x 2 OR 61138366245 x 2 -- Sealing Grommet
AMP 967056-1 x 4 -- Blank Sealing grommet
Some amount of wire (I think 20 or 22 gauge would work)
Old 08-05-2013, 11:38 PM   #149
wooboodoo
wooboodoo's Avatar
Thank you very much for all detailed informations ! I appreciate it.
Ok now everything is clear ill buy this LCM from 05 M3 yes this car had factory HID lighting.
There's only one more thing I don't know yet... You mentioned to run two wires from LCM to center pins in small plugs located in ballasts, do you know the pins numbers in LCM plug by any chance? Or can you tell me where I can find tat info?
Somebody mentioned that this center pin can be connected with positive hi beam wire... What you think about that option?
Thanks again!
mark
D. Randy Riggs
Old 08-05-2013, 11:54 PM   #150
TerraPhantm
My Ride: M3 & ZHP
Thanks again!
mark
Oh yeah, I forgot to mention that (and I suppose you'd need the pin for the LCM side too... I think that's just a non-sealed MQS connector). The Bixenon pins are pins 2 and 36. You don't have to worry about finding a ground, since the solenoid is grounded via the ballast.
I think Pin 2 is meant for the right headlight, and 36 for the left. Doesn't really matter since there's never a time when the two aren't active simultaneously
Center pin to highbeam +12V is possible, but you'll have to code the LCM to keep the highbeams active with the bixenon shutter (normally it's not when recoded for HIDs). If you use DRLs, you shouldn't do this, since you'll likely just burn out the solenoid
Old 08-06-2013, 12:31 AM   #151
wooboodoo
wooboodoo's Avatar
I appreciate your help, thanks again !
Just ordered all missing parts and will finish this mod as soon as they'll arrive.
Damn wish I know this before that I need to run additional wire from LCM to headlights :-/ I just did that harness B and installed 2 weeks ago, used expensive tape to be more OEM and now what? have to do it again...
Thanks again ill post update soon.
Regards,
mark
D. Randy Riggs
Old 08-17-2013, 04:25 PM   #152
hound4
My Ride: 2002 325xi 5spd
Has anyone tried to pull all the needed parts from a junk yard? This would save time in creating the wiring harnesses, etc. Theoretically this should work right? And might save a lot of time?
hound4 is offline   Reply With Quote
Old 08-22-2013, 11:51 PM   #153
wooboodoo
wooboodoo's Avatar
Another success here !
Received the LCM today (Jack thank you very much) installed and tested, auto leveling function working !!!
TerraPhantm thanks for your help as well.
Now have to find out how to code my vin number and mileage to new LCM cause I have tail lights error and mileage error.
D. Randy Riggs
Old 08-23-2013, 01:24 AM   #154
TerraPhantm
My Ride: M3 & ZHP
If you have PASoft and NCS Expert, you should be able to get everything to work properly
Old 08-23-2013, 01:51 AM   #155
wooboodoo
wooboodoo's Avatar
I do have NCS Expert but never play with vin and mileage before so have to learn how to do it. All I did myself was some hiden functions activation/deactivation.
D. Randy Riggs
Old 08-23-2013, 02:47 AM   #156
TerraPhantm
My Ride: M3 & ZHP
Using PAsoft, set the mileage on the LCM to 0. Then using NCS Expert, read the FA from your AKMB. Then go to your ALSZ, and do the jobs "FA_WRITE". Finally, change the job type to SG_CODIEREN, and execute it with a blank FSW_PSW. Any customizations you had on the LSZ will have to be added back
Turn the key off and then on again. Tamper dot should be gone. Read the FA from the ALSZ and verify that the VIN and FA are correct
Old 08-23-2013, 03:06 AM   #157
wooboodoo
wooboodoo's Avatar
Thank you for detailed instructions, the only problem is I don't have Pasoft...
I though that I can do everything using NCS Expert, is this possible?
D. Randy Riggs
Old 08-23-2013, 03:12 AM   #158
TerraPhantm
My Ride: M3 & ZHP
NCS doesn't let you change the VIN unless the mileage of the LSZ is set to 0, and you can't decrease the mileage without PASoft
Old 08-23-2013, 09:28 AM   #159
wooboodoo
wooboodoo's Avatar
Understood...
Ill try to run BMW scanner 1.4.0 on my edibas cable today, have heard that some folks was lucky and it works for them.
Thanks again,
mark
D. Randy Riggs
Old 08-23-2013, 11:39 AM   #160
wooboodoo
wooboodoo's Avatar
Can't I flash LCM with WINKFP???
I need to check it today
D. Randy Riggs
