Thread Tools Search this Thread Rating: Thread Rating: 18 votes, 5.00 average. Display Modes
Old 08-24-2013, 01:37 AM   #161
jack.chris328
My Ride: is a truck.
Originally Posted by wooboodoo View Post
Another success here !
Received the LCM today (Jack thank you very much) installed and tested, auto leveling function working !!!
TerraPhantm thanks for your help as well.
Now have to find out how to code my vin number and mileage to new LCM cause I have tail lights error and mileage error.
Awesome! Your very welcome. I'm glad it's working out well.
jack.chris328 is offline   Reply With Quote
Old 08-24-2013, 11:53 AM   #162
TerraPhantm
My Ride: M3 & ZHP
Can't I flash LCM with WINKFP???
I need to check it today
Nope
Old 08-27-2013, 12:05 AM   #163
wooboodoo
wooboodoo's Avatar
My Ride: is alpine white...
I run these additional two wires today for hi beams, the headlight side are pernamently done ! But the LCM side nope, I though that the same connectors are for both headlights and LCM sides but looks like I'm wrong lol
But connected these 2 wires temporary just to check it it works and yes they do !
Few more things and mod gonna be done...
Waiting for PAsoft to finally program LCM, there's something I don't understand, I can use my cable for BMW scanber 1.0.4 demo and it works just perfect but full version not... sucks
No matter which BMW model you drive, pure chiseled performance is the
pulsating heart of its DNA. Yet the 13th letter of the alphabet takes every
BMW built-in performance advantage and amps it up to the Mth degree.
Call it the Year of M.
D. Randy Riggs
wooboodoo is offline   Reply With Quote
Old 09-03-2013, 08:34 PM   #164
wooboodoo
wooboodoo's Avatar
My scanner came today...
Fallowing your instructions recoded the LCM, the temper dot is gone.
Checked vin and fa in AKMB and ALSZ both exactly the same...
But funny thing happen I messed up something but don't really know what.
When connected scanner first time it shows me two columns my car info ( I believe it was IKS on the left side) and under LCM was LCM car donor info now on both sides are exact same informations but not about my car... There's no wagon any more but limousine.
Thinking how to get my car info back.
Also have taillights error was trying to reprogram them using PAsoft but I can't... There's option side lights as a break lights which are in my car I activated this option all bulbs working as suppose to but on dash still error tail lights...
D. Randy Riggs
Old 09-04-2013, 07:17 PM   #165
wooboodoo
wooboodoo's Avatar
Ok project is finally done... !
All car information coded back to LCM and IKN
All extra functions (corner lights delete, rolling up windows when alarm aiming etc. etc.) been programmed back, no more taillights error, everything works just perfect !
There's few options I will check soon what they exactly do for example LWR_NEIGUNG_KONSTANTE (Headlight leveling constant tilt) I have set to wert_1 ill try wert_2 or maybe even 3,4 and see what gonna happen
Thanks,
mark
D. Randy Riggs
Old 09-16-2013, 01:28 PM   #166
hound4
My Ride: 2002 325xi 5spd
For those looking to do this retrofit (I am still in the planning stages), here's a link to some photos some of which may be helpful in seeing how the different pieces actually install
http://www.bmwfaq.com/threads/brico-...altura.252551/
hound4 is offline   Reply With Quote
Old 03-27-2016, 08:44 PM   #167
mikeypx82
My Ride: 2005 BMW 330i
Wire Harness B help
Sorry to revive an old thread. I'm doing this retrofit and this is the only thread with good information. I'm currently making wire harness B which connects the headlight motors to the LCM. I have all the parts, I just need to know how the wires on the LCM correspond to the plugs that connect to the headlight. I found this LCM Pin Layout on this thread.
LCM/LKM PIN LAYOUT (actuator/auto-level motor)
PIN 39 Q22 LEFT headlight actuator/motor
PIN 40 Q11 LEFT headlight actuator/motor
PIN 41 Q12 LEFT headlight actuator/motor
PIN 42 Q21 LEFT headlight actuator/motor
PIN 51 Q22 RIGHT headlight actuator/motor
PIN 52 Q11 RIGHT headlight actuator/motor
PIN 53 Q12 RIGHT headlight actuator/motor
PIN 54 Q21 RIGHT headlight actuator/motor
The connectors I have are labeled 1-4. I don't see Q22, Q11, Q12, or Q21 anywhere on the plugs. Here is a picture of one of my plugs. Let's assume this plug is for the left headlight, how would I wire it to the LCM?
Pin 39 to Pin 1 ?
Pin 40 to Pin 2 ?
Pin 41 to Pin 3 ?
Pin 42 to Pin 4 ?
mikeypx82 is offline   Reply With Quote
Old 10-10-2016, 06:07 AM   #168
mikerob97
My Ride: 2006 BMW M3 Cabrio
Pin 39 to Pin 1 ?
Pin 40 to Pin 2 ?
Pin 41 to Pin 3 ?
Pin 42 to Pin 4 ?
Hello - Did anyone reply to your question? I built a harness to connect my LCM to the headlight stepper motors for my 2000 E46 323i Touring model, but this was about 5 years ago. I recently replaced the Touring with a 2006 M3 Convertible and miss the manual headlight adjustment. This winter I will be resurrecting my project notes because I want to convert the current auto leveling vertical control to a manual adjust vertical control. So I have been rereading some of these old posts. As I progress through this project, I'll post to this thread.
Regards,
Mike
Cary, NC
Cars in Fleet
2006 BMW M3 Cabriolet
2000 BMW 323i Touring (Sold)
1991 BMW 325i Cabriolet (For Sale)
2016 Honda Pilot - Wife's Car
2010 Honda CRV - Spare
1998 Honda VFR - Two Wheeled Fun
mikerob97 is offline   Reply With Quote
Old 10-10-2016, 05:47 PM   #169
mikeypx82
xenon retrofit
No one replied but I found the information myself using DIS. I completed this retrofit so let me know if you need help.
Old 12-25-2016, 09:09 PM   #170
elioc9
My Ride: E46 320D
If you could provide the info that would be great. I will be doing this retrofit next week. Thanks
Enviado do meu ONE A2003 através de Tapatalk
elioc9 is offline   Reply With Quote
