#1 |
Manual Trans Oil Change - Gear Oil or ATF?
My 2001 330Ci is getting notchy when shifting into 3rd, the synchro is probably getting worn. I'm planning to change the transmission oil to see if this helps.
The transmission sticker says use BMW MTF-LT1. Some Internet forum articles say to use gear oil (Royal Purple Synthetic), others say to use Redline D4 ATF. Which one is correct? |
#2 |
t(-_-t)=33
both are fine to use. However, some people have detected leaks using the Redline, and premature degradation with the fluid (going sour after 15k-ish miles).
I've always used the LT-1, while it isn't cheap by any means. |
#3 | |
The previous owner swapped the factory oil with Redline about 15k miles ago, hmmm. Thanks |
#4 | |
Halfway to 2L
I use the royal purple also, that smoothness only last a few weeks.
![]() ![]() You down with UCC? Ya you know me! sowing the seeds of jiggery pokery |
#5 |
If the royal purple loses the smoothness that fast, then what should we use when replacing this fluid? I'm not looking to race my car at this point, just want it to stop notching from first to second so bad when cold and from second to third just about all the time. Would the MTF-LT2 be a better solution? Thanks.
#6 |
I Put AMZoil ATF in it. BMW needs Dexron III so get ATF that has it and Amzoil ATF has great results at low temps compare to others.
I had the cold problem and now it is gone with the AMZoil ATF, the notchy feeling is a bit better. My car is also a 2001 325Ci and only has 46000km and you should of seen the grade and colour of the tranny and diff fluids....OMG...I would change them both every 50000Km or every 2 years...it is a must. Oh, and I put RP Max Gear 75W90 in the diff and it made the biggest improvement in the feel of shift and gear transition. |
#7 |
I guess you believe what you want to believe. I've had D4 in mine for 30K. No leaks. Getting ready to change it again.
#8 |
My Ride: Alpine White 3er
I was wondering about this myself and looked in the owners manual. It stated that this is lifetime fluid and does not need replacing??? Is this incorrect?
#9 | |
t(-_-t)=33
#10 | |
#11 | |
Gear 75/90 or close..Royal Purple Preferred
I am a big RP fan from their early days. My 2001 330Ci was all notchy, especially when cold. I put in Royal Purple and the shifting has been perfect ever since...do the change ASAP...don't let BMW's stupid oil change intervals screw you...none in the case of the manual Mike |
#12 | |
#13 | |
#14 | |
Halfway to 2L
It doesn't loose all the smoothness, it is still much better than the stock oil IMO, but the absolute silkiness you experience in the first few weeks wears off.
#15 |
Were can I purchase Royal Purple and what kind should I get, also how hard is it to change my own tranny fluid?
thanxs |
#16 |
Taiwan/Vancouver/Shanghai
My Ride: Jet Black02' 325ci
life time tranny fluid.. ha, the fulid might still be okay when BMW asks you to change the transmission. haha
![]() Orz |
#17 | |
The only place I've consistently found RP is at the NAPA auto parts warehouse, it has a retail parts counter. The local NAPA stores get their parts from this warehouse. Changing the tranny oil is easy if you have the right tools, see http://m3.madrussian.net/diy_rp_tranny_fluid.shtml |
#18 |
How about mobil 1
has anyone tried putting Mobil 1 syn Gear oil in their transmissions?
#19 |
Mike Miller, writer of the "Tech Talk" column in the BMWnsCCA mag "Roundel," has an article on this very subject in this month's issue. He recommends either Redline D4ATF OR Redline MTL (manual tranny lube).
I used MTL in my E30's tranny and had no problems. I currently am running Redline D4ATF in my '01 330Ci (currently undergoing major body repairs!!). The shifting is smoother than the OEM stuff and the smoothness lasts. I change it once a year, in the spring. |
#20 |
You think the syncro's will be okay w/this fluid? I heard using ATF can affect the syncro's in the long term....
