Thread Tools Search this Thread Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Old 07-07-2005, 10:20 AM   #1
onepeon
My Ride: 328i
Send a message via AIM to onepeon
E46 Wiring Diagram
2000 BMW 328I 4DR SEDAN
Audio/Mobile Video
WIRE COLOR POLARITY LOCATION
Battery RED/WHITE (+) RADIO HARNESS
Accesory VIOLET/WHITE (+) RADIO HARNESS
Ground BROWN (-) RADIO HARNESS
Power Antenna WHITE (+) RADIO HARNESS
LF Speaker (+) YELLOW/RED
LF Speaker (-) BROWN/ORANGE
RF Speaker (+) BLACK/RED
RF Speaker (-) BROWN/ORANGE
LR Speaker (+) YELLOW/BLACK
LR Speaker (-) BLACK/ORANGE
RR Speaker (+) BLUE/BLACK
RR Speaker (-) BROWN/ORANGE
Radio Security YES
Security
Battery RED/GREEN (+) OR RED/BLU IGNITION HARNESS
Ignition 1 GREEN (+) IGN HARNESS GRN ALARM PLUG
Starter 1 BLACK/BLUE (+) IGN HARNESS GRN/BLK ALARM PLUG
All Door Trigger RED/BLUE (+) MODULE BEHIND GLOVE BOX (THIS WIRE
DIMS)
Trunk Trigger WHITE/BROWN (-) DRIVERS KICK
Hood Trigger VIOLET/GREEN (-) MODULE BEHIND GLOVE BOX
Parking Lights REMOVE SWITCH (+) 4TH WIRE FROM LEFT ON RIBBON CABLE
(NOTE
FOURTH WIRE FROM LEFT LOOKING AT SWITCH IN RIBBON CABLE
Convenience
Headlights-Lo YELLOW (+) HEADLIGHT SWITCH
Wipers-Lo BLACK/GRAY (-) OR BLK/BLU STEERING COLUMN
Trnk Release GRAY/RED (-) AT SWITCH IN DASH
Remote Start
Ignition 2 VIOLET (+) OR VIO/WHT IGNITION HARNESS
Accessory 1 VIOLET (+) IGN HARNESS OR VIO/WHT ALARM PLUG
Anti-Theft Type RF ACTIVATED SYS.
Anti-Theft Descript EWS II
Key Sense RED (-) IGNITION HARNESS
Tachometer BLACK (-) DIA. PLUG PASS SIDE OF ENG ROUND BLK PLU
Speed Sense WHITE/BLUE (AC) SPEEDOMETER
(NOTE
Brake Lights BROWN/WHITE (+) SWITCH ABOVE BRAKE PEDAL
Reverse Lights BLUE/RED (+) AT LIGHT
Horn BROWN/RED (-) STEERING COLUMN
Modules
WIRE LOCATION
Doorlocks/Windows
Power Unlock BLUE/RED (-) PIN 22 THIS WILL DISARM ALARM DOUBLE PUL
REQUIRES DOUBLE PULSE
PowerLock WHITE/BLACK (-) PIN 20 OF MODULE BEHIND GLOVE BOX:WHT
BO
LF Window Up LF:BLACK/WHITE
RF Window Up RF:BLUE/GREEN LR:BLACK/YELLOW RR:WHITE/YELLOW
LR Window Up LF:VIOLET/WHITE
RR Window Up RF:YELLOW/GREEN LR:BLUE/GRAY RR:BLUE/RED
Use at your own RISK! Double check all wires with a Multimeter!
Props to: ca1242
onepeon is offline   Reply With Quote
Old 07-07-2005, 02:48 PM   #2
ca1242
My Ride: 2003 330i
Just a warning: The Tachometer and Speed sense wires are both at the instrument cluster (one on each plug). Can't remember of top of my head, but I think the VSS is either black/white or white/black.
Old 08-05-2005, 11:21 AM   #3
JRoz
My Ride: 2000 323ci
Send a message via AIM to JRoz
which ignition wire should i wire a shutdown controller too..and should i get one of those little blue clips that you can tap into with that doesnt cut wires?...i need to mount a wire from the shutdown controller to the acc ignition in the trunk near the stock amp...then a wire from my battery to the shutdown controller..then a wire from the motherboard to my shutdown controller
Mods:
UUC TSE DTM Exhaust
Benfer CAI
Euro Clear Corners
SPP Bulbs
Carbon Fiber Dash
Predator Chromium DDE's
Carputer / 7" touchscreen
20% tints
Yellow Top Optima Battery
Work Hard..Mod Hard..Drive Hard
Carputer Specialist & Installer
Contact me for info
JRoz is offline   Reply With Quote
