Car Care & Detailing
Get detailing answers and tips here |
Rating:
#261 |
I dont know the technical name for this procedure... is it worth getting a permagard or zymol or something coating?
Eg. www.permagard.info These guys apply some kind of coating which then makes it simpler to wash your car. |
#262 | |
![]() Wash & Dry Products, Clay Bars, Polishes, Sealants, and Waxes 10offe46 - Discount Code for 10% Off for e46fanatics members Detail University - Detailing Enthusiast Discussion Forum |
#263 |
Chip turning to rust..Obvious noob..yes, I searched
OK so this is not a PURE detailing question but perhaps you'll be kind enough to answer...
I was taking a basket of recycleables to the center, and I had a heavy metal piece of pipe that came out of the kitchen makeover. Of course I nicked the edge of the DS backdoor on the car side (not the door) about midway down the edge. I wasn't too worried as it was a small chip, about half the size of a pencil eraser and I was sure it was only down to primer.. Well, darned if it isn't starting to turn brown which means rust.. I have 2 tubes of touch up (the paint and the clear coat), and I've read about glueing sandpaper to pencil erasers, but I haven't had any success with that approach, So, my question is how FAR or should I say how much bigger should I sand around the chip before applying primer and then paint.. Whats the recommended waiting period between steps, and can I buy "Rustoleum" primer from Home Depot ....and spray it into a cap and use a artist brush to apply.. Any other secrets to making this look good...??? A million thanks !! ED in NJ |
#264 |
Check out this thread that was made about using touch up paint Part I Part II
If you're having problems getting the sandpaper onto the pencil tip, you can use just a sanding block. You can wetsand around the area as much as you want, it will buff out but you're just creating more work for yourself. Make sure you end up wetsanding with super fine grades of sandpaper 2000 - 2500 or you'll have a tough time buffing out the wetsanding marks. The key to a good touch up is wetsanding the blob of touch up you put on to a level surface then polishing it up to clean up the scuff marks. Greg @ Detailed Image
#265 |
Man
How does one clean polishing pads they used for applying products like Klasse AIO etc? (If you don't have those little packets of cleaner?)
#266 |
I just got the SSR 2.5 and the klasse AIO with the microfiber towels. Now as i was reading this thread it says to follow the 2.5 with the SSR 1. Is this necessary, im going to be doing my dads jet black 5 series. It has some minor swirls and scratches on it. Nothing like the black mercedes that u posted pictures of. I just need to know if its safe to just use the ssr 2.5 and then remove that and apply the Klasse AIO and remove. I was reading that you recommend the 1.0 too. I was hoping to skip that step but if its completely necessary i guess i will order that too. Please let me know what to do.
#267 | |
If I'm not mistaken didn't we end up suggesting going with SSR 2 (not the 2.5) since your car(s) just had some minor imperfections. When going with SSR 2, you can jump right to AIO afterwards. The reason the 2.5 and 1 go together is sometimes you will see a slight haze with the 2.5 and then the 1 cleans that right up, but you shouldn't see that with the SSR 2. I could be thinking of someone else, but double check I think you have the SSR 2
![]() George Quote:
#268 | |
#269 | |
- Justin
DIY Garage Build (Updated November 18, 2009): http://forum.e46fanatics.com/showthread.php?t=297607 |
#270 | |
Thanks for the response though!How'd you like the SSR 2 though? Good results with it? George
#271 |
Location: Tis quite a statement. Where do you live - where do we all live? in our minds? our souls? our bodies?
My Ride: She aint much 330ci
great thread.
I have a light scratch showing white on my black car. I have no prior experience using a scratch remover. Any recommendations on how to do this? The product I have is scratch-x. I actually had a detailer come out and look at the car and suggested that i do it myself. |
#272 | |
- Justin
#273 | |
If the scratch-x doesn't work its because its pretty fine polish, something like the SSR 2.5 would be more aggressive and you'd have better luck with that. Many people have tried scratch-x with little to no results then switch to the Poorboy's and it cleaned up their paint with ease. George
#274 | |
Could you clarify what you mean by "showing white"? Is the scratch down to the clear coat, paint or primer? Greg @ Detailed Image
#275 | |
#276 | |
I would then follow George's recommendation and get the SSR 2.5. Follow this up with the SSR 1.0 and that area should look as good as new. Greg @ Detailed Image
#277 |
if i get a PC, do you recomment Optimum or SSR? .. just want your opinion on it, i hear Optimum is easier to work with
#278 | |
#279 | |
#280 |
This may be a dumb question but I've had my 2002 330i (Alpine White) for 3 1/2 years and I wash it at least every other week and wax it (Zymol) two times per year. The paint seems pretty good to me but I'd like to do a full clean/wax or whatever I need to do to make it look perfect again. I've never used a clay bar or done anything else besides wash and wax it and am not sure where to start other than that. What steps and or applications would you suggest??? Thanks in advance...
| Rate This Thread | |
