Car Care & Detailing
Get detailing answers and tips here |
Rating:
#3001 |
Banned
have a 2009 ninja no scratches or swirls ... best way to clean and detail
#3002 | |
The clay bar is a great option that I always recommend using before polishing. The SSR 2.5 is a good medium cutting polish however I would highly recommend the Menzerna Super Intensive Polish PO83 or the Meguiar's Ultra-Cut Compound M105. These polishes are more likely to get you better results. Additionally all three options are most likely followed up with a lighter polish and pad combo for best results. If you prefer a one step polish that can still help you out try the Menzerna Power Finish PO203S. It's slightly less aggressive than the Menzerna PO83 or the SSR 2.5 and would be a better selection in my opinion. After that the Klasse AIO and a white pad would be great. Let me know if you have any other questions. Greg @ DI
#3003 | |
DI Accessories E-Z Detail Brush ![]() Full Size Price $21.99 Mini Size Price $14.99
#3004 |
I just got some panels repainted on my car to repair scratches/chips. How soon should I wait to wash/clay/wax it, etc? It's already covered in pollen, and someone told me I shouldn't wash it for about a half month, I've never heard of this, but it made me nervous about even rinsing the car off with water. Any advice?
MALA MALIS FACIMUS.
#3005 | |
Greg @ DI
#3006 |
So it would be safe for me to at least rinse all the pollen off then, correct? Thank you for your help, I appreciate it.
EDIT: The reason I want to know about rinsing it is because my car club is having a get together tomorrow, we'll probably take a club photo. My car doesn't need to be 100% perfect, but I'd prefer if I could at least make it look halfway presentable.
MALA MALIS FACIMUS.
![]() Last edited by sick.boy1986; 05-28-2010 at 10:02 AM. |
#3007 | |
#3008 |
So I've got several clear coat scratches on my paint (on the bonnet, roof and the boot) that I've been trying to remove with my PC 7424 XP, yellow pad, and Meguiar's M10532 Ultra Cut Compound. I'm using setting 4 to 5 and have done several times over with very limited results. The scratches are still there, most I can't feel with my fingernail, but some are barely catching. Regardless, I don't feel like I'm getting anywhere other than a nice general polish. What am I doing wrong? Do I need to wet sand or something??
My process: Wash, remove wax Clay bar area Meguiar's Ultracut polish with yellow pad Klasse AIO with orange pad Meguiar's Caranuba Wax (2 coats) However, the scratches (even the ones I can barely see) arn't coming off on the ultracut stage. Please advise. thanks. |
#3009 |
My Ride: M3CI, E24 M6
Hi
I have an engine bay question. I have an M3 and the engine compartment is very clean. The painted areas are relatively flat, i.e. no clearcoat on them. I have cleaned the areas that I can easily touch. However, there is a light haze over other areas. These can be seen by a judge but not wiped by me. I would rather not disassemble the engine bay to wipe these areas down. There has to be an easier way. Is there a spray that would clean the haze off that I would then rinse off using distilled water? Again, I don't think I need a degreaser. This engine bay is extremely clean and I don't want to leave a residue to attract more dirt. I have never used an engine bay 'dressing' as I don't like the look. Thanks Mousemaster
I bought my ride outside Calfornia and SAVED A BUNCH OF MONEY !!!
#3010 | |
Additionally if you are applying the M105 with a yellow pad you should definitely be following up with the M205 and a lighter pad (orange, cyan, green, white or tangerine depending on the results) to remove any haze on the surface. Then I would lastly apply the AIO with a white pad or softer pad. Going right from the yellow pad and M105 to the AIO is likely going to leave some haze on the surface.
#3011 | |
One other product I wanted to mention to you is the DI Accessories E-Z Detail Brush. This is the full size and there is also a mini size which may help you do a quick cleaning in the engine bay. ![]() If you read our engine detailing section of our detailing guide you'll get all the info for a complete detail. It usually only takes me about 20 - 30 minutes to do a pretty thorough engine detail as long as it's not filthy. Let me know if you have any additional questions.
#3012 |
Can the same results be seen using aggressive cutting compounds with PC for plastic pieces such as headlight plastic lenses, as opposed to using plastic polish compound?
and the second question being, what are the main differences in compound for plastic cutting compounds (such as meguiars plastx) and just normal cutting clear-coat cutting compounds?
#3013 |
To be honest I'm not completely sure of the exact molecular differences between traditional polishes for the clear coat/paint versus plastics. Most mfgs are tight with their exact formulations. The polishes you use on the paint are the same polishes I use on the headlights. The Meguiar's PlastX Clear Plastic Cleaner and Polish works well on some ultra light imperfections. However if you want a more complete restoration I really like using a combination of polishes like the Menzerna PO83 and PO106FA with a buffer. If you need even more severe restoration a little wet sanding is helpful. Check out this headlight restoration article for more details.
#3014 |
Leather Dye
I just purchased a 2000 Steel Blue 323i and the exterior is in amazing condition but the interior color has rubbed off of the leather. Is there a product out there that will allow me to dye the leather? Is it something I can do or should I consult a professional?
#3015 | |
Take care!
#3016 |
I got some old items I bought in 2005, are they still good to use?
poorboys 2.5, 1, ex-p P21s car wash 303 fabric guard and aerospace protectant Lexol leather cleaner/conditioner thanks for having this convenient thread and maintaining it for so long
#3017 |
It depends on the situation. Generally the products last at least 4 - 5 years in peak condition. It can be shortened if they are exposed to extreme heat or cold. If unsure shake them thoroughly and test in the least visible area.
#3018 |
303 Aerospace
I''ve searched to no avail....does the 303 Aerospace actually clean, or is it just to be used as a protectant? I know there is a 303 cleaner, but trying to save where I can. Thanks for all your help!
2004 325i AW ZSP/ZPP, Step "I'd rather live on my feet than die on my knees." |
#3019 | |
#3020 | |
| Rate This Thread | |
