Car Care & Detailing
Get detailing answers and tips here |
Rating:
#121 | |
![]() George
![]() Wash & Dry Products, Clay Bars, Polishes, Sealants, and Waxes 10offe46 - Discount Code for 10% Off for e46fanatics members Detail University - Detailing Enthusiast Discussion Forum |
#122 | ||
Man with No Name
on your "How To" pages on your website, it says: Quote:
also, you know the plastic (i assume it's plastic?) housings on our BMWs sidemirrors? it's starting to looks white in some areas, what's the best product to clean and protect it? Plexus Plastic Cleaner & Polish? thanks!
BBS | ACS
![]() "if you wanna be king of the ring, this is the kind of car you should get" -M3 CSL "there's no replacement for displacement" - only BMW ///M Last edited by BayerischeMW; 07-27-2005 at 08:24 PM. |
#123 | |||
Ideally (and this is going on the new site) horizontal panels (hood, roof, trunk) should be washed from left to right. Verticle ones, (doors, bumpers, etc.) should be washed up and down. That way, if a imperfection does occur, optically it will not be as visible. Quote:
Sincerely, George Dushensky Detailed Image - Owner
#124 |
definitely should be a sticky!!...
thanks for all the wonderful info. i thought i knew everything. but i guess not.
#125 |
Man with No Name
awesome reply as always George, thanks a lot!
BBS | ACS
![]() "if you wanna be king of the ring, this is the kind of car you should get" -M3 CSL "there's no replacement for displacement" - only BMW ///M |
#126 |
Greg & George -
I received my special order of PoorBoy's 2.0, 1.0, and EX the other day. Thank you very much for the quick shipment and excellent packaging! I am to begin detailing the Jaguar tomorrow. I understand that the orange cutting pad will be used with the 2.0, white polishing pad with 1.0, and a finishing pad with the EX. My question is what speed should I use with each step? I am utilizing the Porter Cable 7424 DA polisher. I've worked with orbital machines in the past, but this is my first time with the PC 7424. Thanks for your help!
- Justin
DIY Garage Build (Updated November 18, 2009): http://forum.e46fanatics.com/showthread.php?t=297607 |
#127 | |
Your polishes you will want to run a higher speed than you will the EX. For the 2.0 I'd personally run it around 4.5 (if its your first time you might want to run it at a lower speed 3 - 3.5 to get used to it). Same goes for the SSR 1. Work it in until it is barely visible, then remove w/ a microfiber towel. You can spot treat the areas that you can't get w/ the PC w/ the microfiber apps we sent. I'd run the EX at 2.5-3, you don't need to heat up the paint at all when applying sealants and waxes. Thanks again! George Dushensky Detailed Image - Owner
#128 | |
http://www.sromagazine.com/home.php?op=go&id=1176 |
#129 |
Question about foam pads:
I understand that using a heavy cutting pad with a light polish or sealant is inappropriate, but can you use a polishing or finishing pad with a compound? I wanted to know if I can use a white polishing pad with 3M Perfect-It II Fine Cut Rubbing Compound. I am trying to remove swirl marks, scuffs, and fine scratches from the previous owner. I would imagine the compound will still cut, even without a cutting pad, but I wanted to ask the experts. Thanks in advance for your response! |
#130 | |
The various detailing forums have info about only using pads that match the product--using pads that are more aggressive than the product only leads to marring/dulling from the pad, or using aggressive products with less aggressive pads creates scouring because the polish/cutting agent doesn’t heat up enough to be effective. Can you use a compound / abrasive polish with a polishing pad and get decent results? Yes. With a finishing pad? No. For example... SSR 2.5 with a white Lake Country Polishing Pad is fine. With a Black LC Finishing pad, no-no. A lot of times we might do a coat w/ a cutting pad, then go over it with the same product on a polishing pad (example SSR 2.5) but never go less aggressive than a polishing pad for an abrasive polish/compound. George
#131 | |
#132 |
Man with No Name
just two quick questions,
will Klasse All-In-One remove old wax/sealants etc., or will only abrasive polishes do that? which polish is the finest/least abrasive of Poorboy's World SSR 1 and Menzerna Final Polish II ? thanks!
BBS | ACS
#133 | ||
Sincerely, George
#134 |
1 Mod //Member
new car new finish
George....
New 330 silver grey metallic. A few water marks on the paint, very faint, but they're there. I can feel grit (by hand) on surface No swirl marks. My plan: Wash with Meguires Gold Class car wash (hey, it was cheap at Costco!) claybar (more meguiars products) to remove water marks and grit Manzerna finishing touch glaze Menzerna FMJ (probably two coats) caranuba wax as my energy allows for extra shine. Anything you would do differently??? Thanks!! JimmyD
2005 330CiC/ZHP Bimmian...customer service before the sale? GREAT Customer service after they get your money? NONEXISTANT! |
#135 | |
If you still plan on claying your process would go as follows: Wash/Dry Clay Some people will Wash/Dry again Mild Polish - SSR 1.0 or Menzerna Final Polish II Menzerna FTG Menzerna FMJ Carnauba Wax If you have any more questions please let me know. Greg Detailed Image - Owner
#136 | |
1 Mod //Member
There are no swirl marks. Only light water stains. I assume the claybar will get out the stains. If not, then I'll use a mild polish. Check your web site for an order in a few minutes... JimmyD
#137 | |
#138 | |
1 Mod //Member
I'll post pics of the sparkling vehicle once I finish her. Oh...and thanks for creating a lot of work for me!!! JimmyD
#139 |
I saw your second order and we'll combine it all into one when we process it through. There is free shipping on all orders over $125 so we'll remove both shipping charges and combine the order into one when it goes out. Thanks again for your business and if you want to add anything else we can make that happen as well.
#140 |
Man with No Name
how should one go about spoilers etc. when polishing/waxing? like these spots, wax must get caught and be hard to remove without scratching anything? (illustration picture borrowed from REVI's "Painted M3 Style Trunk Lip Spoiler" thread - hope you don't mind!)
BBS | ACS
| Rate This Thread | |
