Welcome to the E46Fanatics forums. E46Fanatics is the premiere website for BMW 3 series owners around the world with interactive forums, a geographical enthusiast directory, photo galleries, and technical information for BMW enthusiasts. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
#1 |
My Ride: `07 335i Sedan
Since I know some ZHP owners wonder if the SSK is worth it since the ZHP comes with a "short throw" I thought I would write a quick review.
First off the install is a huge pain in the a55, since you have to remove the full catback exhaust system. After you do that though, it's a breeze (make sure you have snap-ring pliers for the "***** clip"). It also helps if you can get the car up on 4 jackstands/ramps. After taking the car for a test drive, it made the painful install worth every second. The throws are allot shorter and feels like a true short shifter. The shifter feels very solid but with slightly more notchiness (which makes sense). The overall shifter height also sits a little lower.. I had 0 rattles, 0 clunking, and it was 100% smooth. Overall it's an excellent product Here's some install pics for the hell of it: |
#2 |
Amen brother... That was a fricking pain in the arse install but lucky for me I had access to a lift at John Elway Ford here in Denver. Buddy of mine is a mechanic there and helped me out. Love the shifter and I definitely agree that the shifts are short. I don't have the ZHP but was a huge improvement from my standpoint.
#3 |
I think all 6speeds are the same as the ZHP, besides the diff. So the improvement should be the same for both of us.
#4 |
I was wondering about that. Thanks for the post, it shed some light! I used to have an AC Schnitzer short shift kit on my E36. It did help, especially on the FWY and mountain drive.
eli |
#5 |
How long did it take you? And is it a one person job?
I hate my zhp shifter. I don't know if it's me, but the whole thing's very jerky in 1st and 2nd gear. There is only a very small window of engagement when it would be smooth, and it's not consistent. I have the CDV removed but that didn't help too much. Been wondering whether a new ssk would help... mutter. |
#6 |
Took about 3.0 hours or so, but i was taking my time. Yea, one person can do it, but two would help allot for the exhaust part.
I never had any inconsistancy in the shifting in the first place, so I can't tell you if it would get any better with the UUC unit. |
#7 | |
You're having problems with the ZHP shifter, or with the clutch? ZHPs (and all E46s) often have clutch trouble because of the Self-Adjusting Clutch (SAC) mechanism. It's a badly designed "update" to the previously perfectly-functioning standard clutch mechanism. UUC makes a non-SAC clutch replacement for your car that would eliminate the SAC problem. It's a direct-fit with no modifications or flywheel changes requied. For detaisl, please see: http://www.uucmotorwerks.com/performance_clutches/ While I strongly recommend our shifter (of course!), it won't help a clutch-related problem. Please feel free to call me directly to discuss the problem further. - Rob |
#8 |
1.888.JLEVISW
Installing an SSK is very involved. In any case I commend your effort by using simply jackstands!
I'm glad you enjoy the SSK as well, however I have had worse experiences with the UUC SSK (not in my car). It makes odd winding noises and is hard to get into gear in some cases but does offer a great range of adjustability and short throws.
#9 |
Anxiously awaits a turbo
I wish I had a six speed
but I do agree with the EVO III! I love it
![]() If someone challenges you to an after-school fight, tell them you don't want to fight afterschool...you can kick their ass right now. |
#10 | |
- Rob |
#11 | |
My shifter "grind" from gear-to-gear, there's a noticeable "crunch" when it goes into the lower gears. I've driven Patrick's ZHP's before, and his shifter was smooth as butter, nothing like mine. Took it to dealerships and found many other ZHPs have this notchy crunch as well so it was concluded as "normal". I think you may be right about the clutch. Although I'm hesitant to plunk down $1k to change out the clutch when it's only 35k miles. If I have a good way to pinpoint it is worn or it is indeed the SAC, I would probably consider replacing it now. |
#12 | |
There's nothing about the shifter itself that can "crunch". Everything you feel through the shifter is from the transmission. - Rob |
#13 | |
A BMW mechanic once said it may be worn syncros that's causing such rough shifting. Obviously without driving it you wouldn't know, but do you think this can attribute to the problem? The only way to replace the syncro is to replace the whole transmission :edited to change engine to transmission |
#14 | |
- Rob |
#15 | |
#16 |
my next mod i hope
