Sponsored by The Tire Rack
Old 07-28-2005, 12:55 AM   #1
ACS3
My Ride: 2000 323i Modded.
Send a message via AIM to ACS3
Toyo T1r Vs. BFgoodrich G-force T/A KDW2
any recommendations ??? Which 1 would be a better choice ?? I am running 19x8 in front and 19x9 in rear. I was thinking 235/35/19F
245/35/19R to be safe from rubbing. Thanks on any inputs guys.
Ray
ACS3 is offline   Reply With Quote
Old 07-28-2005, 01:31 AM   #2
325 & 55
My Ride: 2001 325Ci Step
Toyo vs BF...
I don't have any expierence with either tire first hand, but from what I've read/heard the Toyo would be your best bet.
The Toyo is quieter, the BFGoodrich gives off a lot of "road noise" and the Toyo has rounder sidewall that will accomodate larger tires and less rubbing issues.
"Search" Toyo's for more feedback from many satisfied owners, I haven't heard any negatives on this tire. Good luck.
325 & 55 is offline   Reply With Quote
Old 07-28-2005, 12:09 PM   #3
Jim_in_Calgary
My Ride: 2002 330ci
I have the T1-S Toyo's and I'm really pleased with them. I've found the performance comparable with the Michelin Pilot PS2's which if you look on the Tire Rack's site were rated one of their best performing tires. The T1-R's I think are a little better than the T1-S's so you couldn't go wrong. Excellent value as well.
I did a track day with a bunch of guys with vipers, twin turbo porsches and corvettes..and the conversations got around to tires...quite a few of them said the T1-S's were great tires in their experience.
I don't know much about BFG's, but I honestly don't remember hearing anyone saying great things about them.
I'm running an 18 x 8.5" rim with 235 40 r18's. I don't think they look quite right. The tread seems to be narrower than the rim. It could be a t1-s issue, but next time, I'd go with a 245 for width on those rims.
You'll be really pleased with the Toyo's if you get them...my buddy did quite a bit of research on this topic on his Mazda RX8 boards as well. They all like the T1-S's...and the T1 R's are better.
Jim_in_Calgary is offline   Reply With Quote
Old 07-28-2005, 12:20 PM   #4
kevmo
kevmo's Avatar
My Ride: vDubDizzle
Send a message via AIM to kevmo
i have those bfg kdw 2 on my 17x8 type 44s... they are great sheds water like WOH... got the same tire for my 19" csl reps
kevmo is offline   Reply With Quote
Old 07-28-2005, 03:44 PM   #5
ACS3
I guess both are great then ... in that case i'll just go w/ the ones that are cheaper ... Thanks on the feedback guys, appreciate it ! anyone else ???
Old 07-28-2005, 06:52 PM   #6
GarrettF
needs a new sig...
GarrettF's Avatar
My Ride: '02 330Ci
Send a message via AIM to GarrettF
I have had the BF Goodriches for 3 years now on my 19's... thier thread wear is really really good in my experience, they are sticky as hell, much better then the stock conti's not quite as good as my S0-2's but still pertty good, weird thing is they are not noisy at high speed but low speed 5-15 mph they are the noiseiest tires i have ever owned, they are also pretty fender friendly witha slammed car like mine
[LEFT]
CAR IS GONE
GarrettF is offline   Reply With Quote
Old 07-28-2005, 08:58 PM   #7
ACS3
Thanks on the input Garrett !
