Old 07-28-2005, 06:39 PM   #1
slow323ci
E46-free since 10-13-06
My Ride: 335i coupe
Coupe owners with droopy door seals -
This problem finally happened to my 6 year old car.
This has already been posted a few times but not so concisely -
If this happens to you, just go to the hardware store and get some Liquid Nails perfectGLUE 1 and glue them back up. PerfectGLUE comes in 3 varieties but #1 is best for this application.
It's easy to use, clear so that if you mess up a little it is no big deal, and it doesn't stink or stick your fingers together like super glue.
Here's what you need:
- Liquid Nails perfectGLUE 1 (about $5 at any hardware store)
- paper towels
- masking tape
1. Apply the glue right out of the tube onto the back of the droopy trim piece.
2. Carefully spread out the glue with your fingertip
3. Wipe off your finger on paper towel
4. Press the trim into place and hold it for a few seconds
5. Pull the trim off again and let it sit for 5 minutes
6. Press the trim back into place and hold it there with masking tape.
7. Let sit for a few hours (or overnight)
8. Remove the tape and admire your repair.
This is so easy, cheap, and quick that I would do the repair myself even if the car was still under warranty.
Hope this helps somebody.
slow323ci is offline   Reply With Quote
Old 07-28-2005, 06:45 PM   #2
rootsy05
My Ride: 330ci
Send a message via AIM to rootsy05
That was a factory defect and they recalled my car and replaced the seal with a new one that i havent had problems with anymore.
rootsy05 is offline   Reply With Quote
Old 07-28-2005, 07:56 PM   #3
ksuen21
CEO OF THE ROC
ksuen21's Avatar
My Ride: 01 330ci,05 Yama R1
i was sick of dealing with it and cut that biatch off
my sig needs a makeover
8000k Predator Chromiums
Rogue Engineering DMS Exhaust
Rogue Engineering Pulleys
ECIS Intake
Stoptech Stage II Brake Kit
Short Shift Kit
6000k Fog Lights
18" Hyperblack CSLs
Clears All Around
35% Tint
ksuen21 is offline   Reply With Quote
Old 07-28-2005, 10:28 PM   #4
love2drive330CI
My Ride: 2001 330CI
I cut mine off too. I did get one replaced while the car was under the initial warranty. Since that has expired I was advised that the otherside(has now come off) I would have to pay for it to be replaced. Is this true since it was a factory defect?
Any bulletins on this from the tech side?
thanks.
love2drive330CI is offline   Reply With Quote
Old 07-28-2005, 10:45 PM   #5
speedmike
My Ride: Black on Black 3
Mega Black
Someone on the site said to use MEGA BLACK and that sheit worked! I am in Houston and its gets HELLA hot and its still sticking!
speedmike is offline   Reply With Quote
Old 07-28-2005, 11:42 PM   #6
hirokiseki
My Ride: E46 330ci 2002
I just used Super Glue and it never came off again. But i wish i knew it was a factory defect, then i would have got it replaced with warranty. But Super glue works really really well.
hirokiseki is offline   Reply With Quote
Old 07-29-2005, 02:56 AM   #7
Austin7
My Ride: E92 & blk '04 M3
Happened to both my cars but fixed under warranty. The M3 is a 04 though, shouldn't they have fixed the problem since my 00?
Austin7 is offline   Reply With Quote
Old 07-29-2005, 02:22 PM   #8
3Series
My Ride: 550i Sport
Happened on my coupe. Passenger side was replaced under warranty, driver side was fixed by me with super glue.
Super glue is quick as easy unlike that Liquid nails method. At first I didn't think Super glue would be strong enough so I bought "Goop" and that was a pain. Takes to long to dry and adhere.
Superglue takes 30 sec, apply the glue, press and hold in place, count to 30, let go and walk away.
3Series is offline   Reply With Quote
Old 07-29-2005, 02:46 PM   #9
slow323ci
My Ride: 335i coupe
Super glue didn't hold on my car. I rolled the window up and down twice and it was broken again.
Old 07-29-2005, 02:49 PM   #10
savage
My Ride: S/c
Send a message via AIM to savage
happened to me 2 weeks ago, i just used superglue and it worked
savage is offline   Reply With Quote
Old 07-29-2005, 05:44 PM   #11
Dry Heat
My Ride: 2002 330Ci
I've been dealing with this problem for the last year since I purchased the vehicle. In Phoenix, in the summer, the temperature in my car parked outside at work pushes 160 degrees or more. The trim on both sides started to droop at different times. I've used dual-phase epoxy with success - even around those "S" shaped curves where the window meets the door. I'll apply the glue and hold it in place for 10 minutes with both hands as sweat pours down my back into my shorts! Tape, clamps, wedges, etc. just don't provide the positive pressure. I can only do small sections at one time (two hands wide) but I have found, with patience, it's as good as new.
Just my personal observation, for what it's worth.
Dry Heat is offline   Reply With Quote
Old 07-29-2005, 06:26 PM   #12
jdr
My Ride: Retired e46
I used the 3M Weather Stripping stuff, so far so good. Red box and the glue is yellow...got it from Autozone.
RETIRED E46
E36 M3/4 project
jdr is offline   Reply With Quote
Old 07-31-2005, 10:45 PM   #13
love2drive330CI
My Ride: 2001 330CI
If this was a factory recall, wouldn't the dealer still be responsible for replacing these? Again, I had one done under the original warranty. Since then both have come off. The stealership said they would only replace the side that was done under the original warranty and I would have to pay for the other side. Is this correct? I am thinking if it was a factory defect, they are responsible. Any way to get a copy of the factory defect information??
help
Old 08-01-2005, 09:31 AM   #14
slow323ci
My Ride: 335i coupe
There's no recall for this problem. Recalls are only issued for safety-related items.
BMW issued a service bulletin to alert dealers that an improved part was available for repairs. If your car is still under the original 50k factory warranty then it will be fixed for free. If you have the CPO warranty or are out of warranty you are on your own.
Old 08-01-2005, 12:26 PM   #15
Jeff43
next mod: recaro child seat
My Ride: smells like surf wax
i used a Wurth adhesive on mine about 2 weeks ago; worked great and saved a fortune.
Jeff43 is offline   Reply With Quote
Old 08-01-2005, 01:15 PM   #16
MahaloM3
My Ride: 03M3 Carbon Black
Mine just happened yesterday. Called the dealer and they won't be able to replace it till next week. I,m just going to fix it myself with super glue.
Mahalo!!
MahaloM3 is offline   Reply With Quote
Old 08-01-2005, 01:16 PM   #17
thesixsins
My Ride: 01 325ci
3m weather strip glue worked for me! supposed to be rated up to 300 degrees or something... got it at napa auto parts...
thesixsins is offline   Reply With Quote
Old 08-01-2005, 01:25 PM   #18
idoc330ci
My Ride: 2003 330ci
nice write up
idoc330ci is offline   Reply With Quote
Old 08-01-2005, 01:32 PM   #19
MahaloM3
I might try that.
Mahalo!!
Old 08-02-2005, 05:14 PM   #20
codex57
Advogado
My Ride: 08 Lexus ES350
Bah, mine happened last nite. I'm gonna call the dealer and see if they have this new part. Otherwise, I might just do it myself since no dealer around me has loaners.
My TiAg 325Ci
WARNING: If you are a "NOOB" then you need to take the NOOB TUTORIAL
codex57 is offline   Reply With Quote
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
(c) 1999 - 2007 performanceIX Inc - privacy policy - terms of use
