Sponsored by The Tire Rack
Old 07-29-2005, 06:21 PM   #1
Straz M3
Rogue Engineering
My Ride: 2008 M3 Coupe
Send a message via AIM to Straz M3
Gary...question...
I will be ordering BBS CHs soon for my 330ci...19x8.5, 19x9.5...
My question is this...I want to run 265/30/19 tires in the backs...The tirerack site said it suggests 245/35/19...Is it possible to run the 265s in the back with the CH...if not what is the widest I can go?
2008 E92 M3 6MT
Alpine White / Fox Red/ Carbon Fiber
Straz M3 is offline   Reply With Quote
Old 07-30-2005, 08:35 AM   #2
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
265/30R19 will mount on the wheel, but it is a pretty aggressive setup.
The site recommends 245/35R19 because this is much more likely to fit without fender modification. If you're okay with getting the rear lips rolled and possibly dialing in a bit more negative camber to help with clearance, consider the wider 265/30R19.
http://www.tirerack.com/a.jsp?a=BN4&...ires/index.jsp
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
