Old 08-01-2005, 02:05 PM   #1
Score
My Ride: 2002 330Ci
Spark plug anti seize compound?
Is it required? What happens if you don't use it? Are the plugs just harder to remove, or are they impossible to remove?
Thanks.
Score is offline   Reply With Quote
Old 08-01-2005, 02:30 PM   #2
KP
t(-_-t)=33
KP's Avatar
My Ride: 01.5 325Ci/93 Miata
Send a message via AIM to KP Send a message via MSN to KP
depends on how long you have it on there.
go to your local auto store and ask for anti-seize that's safe for spark plugs, it makes things easier next time around.
KP is offline   Reply With Quote
Old 08-01-2005, 03:13 PM   #3
333HPDog
My Ride: bmw
but dont go nutty putting it on.. a very small amount will work.
333HPDog is offline   Reply With Quote
Old 08-01-2005, 03:54 PM   #4
topazblu323
My Ride: 323ci
Send a message via AIM to topazblu323
what happens if you put to much on?
topazblu323 is offline   Reply With Quote
Old 08-01-2005, 04:40 PM   #5
Tom Busby
My Ride: 2001 325i, 1995 318i
Porsche is the source for nixing the anti-sieze, where if you use too much it allegedly will foul the plugs.
Tom Busby is offline   Reply With Quote
Old 08-02-2005, 11:20 AM   #6
markusmark
My Ride: 2001330Ci
Use copper-based anti-sieze compound.
markusmark is offline   Reply With Quote
Old 08-02-2005, 08:08 PM   #7
Amoeba
Amoeba's Avatar
My Ride: his: zhp hers: 325ci
Send a message via Yahoo to Amoeba
I imagine the threads should be plenty enough to hold the spark plug in, and it's usually only hand-tightened. Why would you need to use anti-seize?
Amoeba is offline   Reply With Quote
Old 08-03-2005, 07:05 AM   #8
markusmark
My Ride: 2001330Ci
Plugs need to be tightened to a specific torque. I don't have the Bentley manual with me so I can oly guess it's about 20ft-lbs or so. The anti-sieze is there to ensure that you can remove the plugs without problems.
Old 08-03-2005, 01:43 PM   #9
Tom Busby
The head is aluminum and the plugs are steel, so there is an electrical potential where they touch. The aluminum head is more electrically active than the steel, so aluminum electroplates to the steel plugs through a galvanic reaction that some call cold welding.
Old 08-03-2005, 02:18 PM   #10
markusmark
My Ride: 2001330Ci
Couldn't have said it better!!!!
Old 08-03-2005, 02:45 PM   #11
Lone
My Ride: 2000 328i
uh..... so what does that mean? i need to go back to school
Lone is offline   Reply With Quote
Old 08-03-2005, 03:19 PM   #12
Solid
Solid's Avatar
My Ride: `07 335i Sedan
Send a message via ICQ to Solid Send a message via AIM to Solid Send a message via MSN to Solid Send a message via Yahoo to Solid
It's 18 ft/lbs
Solid is offline   Reply With Quote
