Old 08-02-2005, 04:33 AM   #1
EDawg
My Ride: :/
O2 sensor: i may have gotten mine mixed up
ok, this is concerning the post cat o2 sensors. underneath the plastic cover above the engine, there are 2 wires where you connect the post cat sensors to. i thought i had correctly kept track of which wire plugs into which o2 sensor, but now i'm kinda doubting myself. anyway, one of them is closer to the firewall , while the other one is closer to the front of the car. so right now, i have the post cat sensor for the exhaust manifold closer to the firewall plugged into the wire clipped closer to the firewall, and the sensor for the exahaust manifold closer to the front of the car plugged into the wire clipped closer to the front of the car. so is this correct?? i know my description is somewhat confusing, but basically i'm assuming the the wire that is directly across from each exhaust manifold is for the post cat o2 sensor of that exhaust manifold.
EDawg is offline   Reply With Quote
Old 08-02-2005, 12:14 PM   #2
Solid
Solid's Avatar
My Ride: `07 335i Sedan
Send a message via ICQ to Solid Send a message via AIM to Solid Send a message via MSN to Solid Send a message via Yahoo to Solid
Does this help at all?
Solid is offline   Reply With Quote
Old 08-06-2005, 09:56 AM   #3
Zyaltr
My Ride: 01-325cic,08-750Li
That correct even if they where mixed up they would be fine...BTW these are Pre cat, not post.
Zyaltr is offline   Reply With Quote
