Sponsored by The Tire Rack
Old 08-02-2005, 02:22 PM   #1
Navin323i
Europrojektz East
Navin323i's Avatar
My Ride: See Sig
Tire pressure question for 235/40/18 tires
I'm currently using Lowenhart BR5 rims mounted on Goodyear Eagle F1 GSD3 tires. My tire pressure is currently 36psi for all four tires. Is this PSI okay or should I be using more/less? I searched thru the archives and saw some people used more and some used less.
Also, when I'm not able to diligently check my tire pressure, I was thinking of getting the following tire pressure monitors to allow me to visually ensure that my tire pressures are okay. Are these accurate? I would buy four of these with a 36psi rating.
http://www.brookstone.com/shop/produ...ry&prodtemp=t2
My 2 Little Girls... the REAL carbon fiber keeping my mechanical heart alive
BMW Individual Atlantis Metallic Twin Screw S/C'ed 2000 323i
SPONSORED BY: BBS | Modbargains | Toyo Tires | DPE | WheelSTO | Vorsteiner | European Auto Source | Bimmertools | GetBMWParts.com | Race Apeel
Navin323i is offline   Reply With Quote
Old 08-02-2005, 03:02 PM   #2
slow323ci
E46-free since 10-13-06
My Ride: 335i coupe
Is that tire size listed on the tire pressure sticker on your driver side B-pillar? If so, use the pressures recommended there.
slow323ci is offline   Reply With Quote
Old 08-02-2005, 03:12 PM   #3
Navin323i
Europrojektz East
Navin323i's Avatar
My Ride: See Sig
No, unfortunately my tire size is not listed on the tire pressure sticker on the driver side B-pillar.
Old 08-02-2005, 03:38 PM   #4
slow323ci
My Ride: 335i coupe
There's usually 2 choices on the sticker. One for <= 4 passengers and one for 5 passengers and/or max load capacity.
From what I've seen the recommended pressure for most tire sizes is 29 front, 33 rear for <= 4 passengers and 33 front 41 rear for max load capacity.
I run 29 front, 33 rear on both my BMW's. My E46 has 225/40-18 in front and 255/35-18 in back, my E39 has 235/45-17 all around.
Old 08-02-2005, 04:10 PM   #5
Navin323i
Europrojektz East
Navin323i's Avatar
My Ride: See Sig
Yeah, I did see the 225/40/18 size on the sticker, but it was a little confusing because I saw a circle symbol next to this size and then saw under the PSI column for the front tires the same circle symbol next to the 33psi (so I gathered from this that the recommended front tire pressure should be 33psi), however I did not see the circle symbol next to any of the recommended psi's under the PSI column for the rear tires.
