Thread Tools Search this Thread Rating: Thread Rating: 43 votes, 5.00 average. Display Modes
Old 03-14-2009, 02:55 AM   #61
kaiv
My Ride: E46 M325iT
bookmarked
kaiv is offline   Reply With Quote
Old 04-03-2009, 07:44 AM   #62
Focal E46
My Ride: is a DIYer
I just did this last night and it took me about 3.5 hours to take it off, wrap it with shadowline, eat dinner, and put it back together.
TIPS!!!! I have a 2004 Coupe so it may vary.
1) When pulling the chrome bottom strip from the door, make sure when you pull back the rubber boot to access the strip that you do not pull off and drop the little hard plastic piece that bonds the boot to the strip. It WILL fall down the door gap. It's the little tooth piece that you have to line up when putting it back together. LEFENGAS has a picture of it on page one
2) On the coupe, the rear piece can be removed with dental floss, the same as when you debadge your car. It may be a lot easier if you heat it some first.
3) MAKE SURE SOME DUMBASS THAT HAD THE CAR BEFORE YOU DIDN"T TRY THIS AND STRIP SCREWS OUT. You may end up like me and get to the last piece and realize this. If I had known this I would have just left it
4) Shadowline TIP: Don't try to pull the tape and wrap it as you go. You will be in cluster**** heaven. Run it down the length of the chrome strip. Press the tape in the center (all the way down), then start from the top again and pull it tight and work your way down. Then start from the top again and work out bubbles/ gaps/ etc. If you try to wrap it all perfect the first time you will lose your mind. Think of it as spray painting, one step (coat) at a time.
It's really not that hard of a job, just time consuming and not for the impatient
Focal E46 is offline   Reply With Quote
Old 05-15-2009, 02:08 AM   #63
Mazi
My Ride: M3 E46
I guys I'm new to forums in general and I really appreciate all the help you guys give they are very helpful. I got a little problem with my rear window on my m3. You see I left my rear windows open over night and I guess someone thought it would be a good idea to pull it so the "stick" or whatever you can call it broke. The motor seems to work fine as it does go in and push out but when it goes in it won't pull the window all the way in. Leaving the window flapping when you are driving on the freeway.
Here is a picture I borrowed from LAFENGAS from this thread and moddified it a bit to show you what I mean.
PS
Thanks LAFENGAS for your great DIY!
Mazi is offline   Reply With Quote
Old 05-16-2009, 08:40 PM   #64
Mazi
My Ride: M3 E46
I would appreciate it if anyone could help me out with this problem.
Thank you!
Old 05-17-2009, 03:41 AM   #65
killahkay559
My Ride: 2004 330ci
my back trim is rotten so ill do this when i get back next year but i cant wait. this was what i been looking for. thanks again. also this will be a good time to do the chrome trim and change it out to black.
killahkay559 is offline   Reply With Quote
Old 08-20-2009, 10:36 PM   #66
kaiv
My Ride: E46 M325iT
Thanks for this great thread!
I need some extra help: I pulled the weatherstrip on the rear window. Unfortunately for me all the double side tape stayed on the panel instead off coming of with the weatherstrip.
I've been going at it with hair dryer + box cutter blade but other than chopping my fingers I'm going nowhere fast.
Any suggestions?
Old 08-22-2009, 11:28 AM   #67
kaiv
My Ride: E46 M325iT
Anyone?
Old 08-23-2009, 01:25 AM   #68
kaiv
My Ride: E46 M325iT
Alright well for anyone who cares, I used PB blaster and Goo Gone along with a blade to get rid of the stuff.
Old 10-01-2009, 05:33 PM   #69
JAJA
My Ride: 2003 325ci
What type of double sided tape did you guys use? The stuff I picked up at Staples is clear and sort of gel like. It's only about 1/32" thick, but looks to be thick enough to raise the trim off the paint and show a gap. Did you use more of a double sided scotch tape thickness or will the stuff I have be alright? I'm just trying to avoid doing it twice. Thanks for the help.
JAJA is offline   Reply With Quote
Old 01-13-2010, 12:16 AM   #70
Born Again
Born Again's Avatar
Location: Tis quite a statement. Where do you live - where do we all live? in our minds? our souls? our bodies?
My Ride: She aint much 330ci
wow great write up - bump for
replace rear window rubber seal
best mod to date : OEM grocery bag holder
Originally Posted by Zell View Post
E46Fanatics - the Honda community of gun owners. Keep staying classy, I'm sure you all are going to be excellent examples of how to keep gun rights from being infringed. :facepalm:
Born Again is offline   Reply With Quote
Old 01-14-2010, 01:51 AM   #71
moomber
My Ride: 330ci
if someone can post the part # to get, that'd be great ! thanks!
moomber is offline   Reply With Quote
Old 01-14-2010, 01:57 AM   #72
Born Again
Born Again's Avatar
and price 2
Old 03-14-2010, 06:35 PM   #73
buddyclubinteg
My Ride: hates pot holes...
definate bookmark here. cant wait to do this long awaited project.
buddyclubinteg is offline   Reply With Quote
Old 03-15-2010, 12:00 AM   #74
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
Subscribed!
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 05-14-2010, 04:37 PM   #75
Trmdubs
My Ride: 02 330CI, '75 W-100
Has anyone found the part number for the trim in black anywhere? or a price?
Trmdubs is offline   Reply With Quote
Old 07-23-2010, 11:01 PM   #76
wickedliquids
My Ride: BMW 330CI 2004
ECS Tuning has both the black and the chrome trim available. The black trim is about half the price of the chrome trim. I got my chrome lower trim today and I'll be putting that on this weekend.
wickedliquids is offline   Reply With Quote
Old 07-25-2010, 05:16 PM   #77
John in VA
My Ride: 328i/325xi
15 Finisher, side frame left SCHWARZ 1 from 12/1999 51717003935
15 Finisher, side frame right SCHWARZ 1 from 12/1999 51717003936
15 Finisher, side frame left CHROM 1 from 12/1999 51717003937
15 Finisher, side frame right CHROM 1 from 12/1999 51717003938
15 Finisher, side frame left GLANZSCHWARZ 1 from 12/1999 51717030845
15 Finisher, side frame right GLANZSCHWARZ 1 from 12/1999 51717030846
16 Fillister head self-tapping screw 51717000290
16 Fillister head screw 51717013307
John in VA
'13 328i xDrive
'06 330ci ZHP
'03 530i
'02 325xi
'00 328i
'86 535i
'85 535i
'85 325e - RIP
'74 2002tii
John in VA is offline   Reply With Quote
Old 07-26-2010, 12:27 PM   #78
wickedliquids
I put on the lower trim for the rear quarter window's yesterday and I have just a couple of things I'd add; if you can, sit the car in the direct sunlight to soften the adhesive; hair dryer works, but not as well as freaking 100+ degree heat from the sun haha. Also, if you can pry the chrome trim off first, that makes it a ton easier. I lifted the trim with my left hand and took a fine knife in my right and slowly severed the adhesive. You'll be left with the residue, but nothing you do will take that off completely unless you're looking to add another 2 hours to the job.
I also took a fine cutting blade from the hardware store and after applying goo gone, I ran the blade, flat edge, against the adhesive - took 90% of it first try.
This DIY is excellent and it WILL take at least 3 hours to complete, but when done - awesome! Great write up!
Old 07-27-2010, 12:01 AM   #79
WBVenom
My Ride: Car 54
Thank you!
Open the vent window and take pictures of your problem to post here. It could be anything any part in the assembly that snapped. It could also simply be that the ball and socket are disconnected (the attachment mechanism for the vent windows). You may simply be able to snap it back together.
WBVenom is offline   Reply With Quote
Old 08-02-2010, 03:58 PM   #80
ilbmwista
My Ride: 320 ci
great work!
ilbmwista is offline   Reply With Quote
