Old 08-03-2005, 05:41 AM   #1
ddbb325i
My Ride: 325i 2002
Send a message via MSN to ddbb325i
PDC Problem
Hi Everyone,
E46 2002 325i
Does anyone have any suggestions as to what I have done wrong?
I just installed the PDC today (double & triple check the wiring).When I put the car in reverse, I just get a ring tone for about 5 seconds from the gong. Then I reverse and the PDC don't work.
Any suggestions??????
thanks
Dennis
Do I need to take the car to my dealer for coding the PDC unit?
ddbb325i is offline   Reply With Quote
Old 08-03-2005, 09:53 AM   #2
Godspeed
My Ride: BMW
You definitely need a MoDiC III or DIS Tester for coding. See step 8 in your installation instructions.
*edit - I'm thinking you don't have the install instructions. I can email them to you if you care to provide me with your address.
Godspeed is offline   Reply With Quote
Old 08-03-2005, 06:21 PM   #3
ddbb325i
My Ride: 325i 2002
I got the instructions thank you . It said "For optimal adaptation of the PDC retrofit system to the specific vehicle, coding of the PDC control unit is required."
I though that it should still work without coding the PDC unit.
