Sponsored by The Tire Rack
Old 08-06-2005, 01:05 AM   #1
dumassass
My Ride: bmw
questions about tire size?????
hey guys........i"m running on toyo t1-s 265.30.19 on the rear with the stock Suspension on my e46 (not a m3).. i was planning to go with 285.30 tire...
do any one out there have 285.30.19 on the rear of there car that is not a m3 and does it fit?
please send some pic......
dumassass is offline   Reply With Quote
Old 08-10-2005, 09:14 AM   #2
MikeySpice
My Ride: 2000 323ci
try the wheels and tires forum.
MikeySpice is offline   Reply With Quote
Old 08-10-2005, 10:37 AM   #3
tim330i
E46Fanatics Owner
tim330i's Avatar
My Ride: 03 Ti Silver M3
Moved.
tim330i is offline   Reply With Quote
Old 08-10-2005, 11:56 AM   #4
Tutankhamon
My Ride: 2017 M2, 2002 330ci
Send a message via ICQ to Tutankhamon Send a message via AIM to Tutankhamon Send a message via MSN to Tutankhamon
that size seems way too big for a non-m. I don't think you'll be even close to getting them to fit unless you have some sort of widebody.
Tutankhamon is offline   Reply With Quote
Old 08-11-2005, 02:21 AM   #5
Bim Growl
Banned
Bim Growl's Avatar
My Ride: E86 3.2
Naw, that's way to wide in the rear. 265's are more than enough rubber in the rear of the Non-M, unless you are putting down some major power, but then you'll be thinking about massive fender flares, or a widebody, and I doubt you want to go there, or even need to.
Youll most likely have rubbing issues, and you won't be able to lower your car at all. You'll be creating some pretty unbalanced auto dynamics if you go with something that wide regardless of how wide your rims are.
Good Luck.
Bim Growl is offline   Reply With Quote
Old 08-11-2005, 02:46 AM   #6
bluecougar
A bimmer chick moderator :)
bluecougar's Avatar
My Ride: MB & LR3
you'll be lucky to even fit 275s on a non-m
||Just another ///M Female Driver||Sold: E46 328ci||E92 335i||E60 M5||
bluecougar is offline   Reply With Quote
