Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 08-09-2005, 01:52 PM   #1
kinggrimwood
My Ride: 1999 328i
How many miles for OBD to reset?
I had a repair done to have my check engine light go off so that i could pass emissions. They reset the system and when i took the car over for emissions testing, the OBD system was not ready for testing.
Can anyone tell me how much the car has to be driven for the system to be ready again. Are there any tips or techniques to make them come on sooner?
kinggrimwood is offline   Reply With Quote
Old 08-09-2005, 06:52 PM   #2
Nesh10
My Ride: 2002 M3
Miles to reset OBD
had the same problem in may. They said to drive about 90 miles then come back.....so i did...and everything was cool.....
Nesh10 is offline   Reply With Quote
Old 08-10-2005, 09:18 AM   #3
beluv
My Ride: '01 325i
My local BMW dealership told me the "drive cycle" is 300 miles.
beluv is offline   Reply With Quote
Old 08-10-2005, 01:27 PM   #4
kinggrimwood
My Ride: 1999 328i
Do you know if it has to be that many miles between the computer readings. I'm thinking that i've driven my car a lot, but only some between my checks at the emissions. Should i drive it a whole bunch before even taking it back.
Old 08-10-2005, 09:15 PM   #5
beluv
My Ride: '01 325i
I doubt it. The drive cycle begins after the computer sees there are no problems anymore. So you should be good if you've driven at least 300 miles after having the service done.
Old 11-20-2005, 03:12 AM   #6
asiangear
My Ride: 323 2000 Ci
Is the drive cycle really driving the car for at least 300 miles? I read slow323ci's post in this thread:
http://forum.e46fanatics.com/showthread.php?t=181921
stating that the drive cycle is starting the car from engine cold, then driving for a while, and the shutting off the car successfully. And to reset the readiness indicators, I would have to complete this cycle 3 times. Which is correct? I am trying to confirm a DTC, so I erased it using an OBD II scanner, and want to see if the same DTC will appear. If slow323ci is right, then after 3 drive cycles, I should see the MIL come on again and see the same exact DTC on my OBD II scanner.
USC Internet: We are the 1%, in lightning-fast porn download (Brazzers at the speed of light)
asiangear is offline   Reply With Quote
