Old 08-17-2005, 06:22 PM   #1
abefroman
My Ride: 2000 323i
Fabric coming off rear pillar...need help
While I was driving with the windows down, I noticed the fabric flapping in the wind. Does anyone know of a good way to fix this?
abefroman is offline   Reply With Quote
Old 08-17-2005, 06:35 PM   #2
wesborl898
My Ride: Acura RSX-S/Ducati
Send a message via AIM to wesborl898
put some cement on it..itll hold pretty well
wesborl898 is offline   Reply With Quote
Old 08-18-2005, 09:25 AM   #3
abefroman
My Ride: 2000 323i
How does that piece come out?
Old 02-27-2006, 08:48 PM   #4
navid525
My Ride: 2001 325ci
ANyone???? i am having the same problem with my car and need intructions of removal
navid525 is offline   Reply With Quote
Old 06-25-2006, 04:11 AM   #5
beefy6969
My Ride: 2000 323CI TiAg
Me too. Its been bothering me for weeks. Can anyone recommend something?
SP,PP,ICE,VGA LCD,DvD,
P46 w/HID, FOG HID (6000K), Clears,
Brembo Rotors, Replica CF GruppeM Intake, ACS Pedals, OEM 19" M3 rims
beefy6969 is offline   Reply With Quote
Old 06-25-2006, 11:26 AM   #6
ryanwhite74115
My Ride: 2013 Infiniti G37S
guy at a shop that does that stuff told me 400 because the whole thing has t be redone in order for it to match, and we all know our headliners arent a piece of tin
ryanwhite74115 is offline   Reply With Quote
Old 06-25-2006, 01:26 PM   #7
SrCsTc
Banned
My Ride: 00 323Ci
Send a message via AIM to SrCsTc
You can replace that pillar for about $30.
SrCsTc is offline   Reply With Quote
Old 06-26-2006, 02:19 PM   #8
mrbmwx5
My Ride: 01bmwx5 2003 bm330ix
try some clear 3m tape spray on it , but do'n spray too much it will wet the fabric and will leaved the clue on it. just spray a lillte of it ,and firmly press on it. goooooood luck.
mrbmwx5 is offline   Reply With Quote
Old 06-26-2006, 03:39 PM   #9
Bulsara
My Ride: 330XI
i have the same problem. how do i remove it cuz i dont want to mess up my rear window and liner with excess glue
Bulsara is offline   Reply With Quote
Old 04-19-2011, 01:52 PM   #10
datssoled
My Ride: 2001 BMW 330i
I have the same problem.
Anyone have a DIY on fixing it?
use rep code DATSSOLED at karma loop.com or plndr .com
datssoled is offline   Reply With Quote
Old 04-19-2011, 10:58 PM   #11
DvSkD4
My Ride: E46 M3
appears im not the only one with this problem, except mine was on the A pillars and the previous owner TRIED to glue them (used too much and it leaked through - came loose again anyway)
anyone take it to a dealer and ask them about it?
DvSkD4 is offline   Reply With Quote
Old 04-19-2011, 11:04 PM   #12
TwoFastFurYa
My Ride: 02' 325Ci Coupe
Subscribed!! Samee problem on the rear for me, only its on both rear pillars lol
02' 325Ci -SOLD
04' 350Z -Current
TwoFastFurYa is offline   Reply With Quote
Old 04-20-2011, 12:03 PM   #13
datssoled
i tried using the 3m 77 spray last night, it works with a light coat, but it isnt sitting flush.
Needs to be taken off in order to make it sit flush.
Anyone have a DIY on taking both front A-pillars and rear C-pillars off?
Old 04-20-2011, 12:11 PM   #14
Golden330ci
My Ride: 330ci
in for removal of A/B/C pillars. A/C are peeling and B is dirty as hell
Golden330ci is offline   Reply With Quote
Old 04-20-2011, 06:23 PM   #15
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
A pillars - use a flathead screw driver and remove the thin strip cover. Behind the cover are torx screws. Remove the torx screws and pull the pillar perpendicular to the mount. Once its off, pull it off from the dash as it is attached to it.
B pillars - remove both front and rear door trims. Remove the bottom piece of the pillar by prying. Its held on by 2 clips on the top. Once off, unscrew the top of the b pillar. The screws are located on the bottom. Unscrew the seat belt from the chair if you have a sedan. Pull off the trim and remove the seatbelt buckle
C pillars - remove the trim on the bottom of the rear door. Remove the map lights by prying the edges. Take a flat head screw drive and pry from the top. This piece is held on by 2 clips.
phamine is offline   Reply With Quote
Old 04-22-2011, 05:16 PM   #16
iifast
My Ride: 2001 325i sedan
Pillar removal
Search DELMARCO and then visit his homepage. He's got REALLY helpful, in-depth videos posted. Browse through them and you should be able to find what you need and then some
iifast is offline   Reply With Quote
Old 04-22-2011, 05:40 PM   #17
BimmerTaco
My Ride: 328i stocky stock
i wantyed to wrap them with suade
Image and video hosting by TinyPic
2000- 328I stock
2003- svt Ford lightning twinscrew supercharger sold
1991- 454ss silverado eddlebrock headers procharged wrecked :(
BimmerTaco is offline   Reply With Quote
Old 01-17-2012, 10:38 PM   #18
scott0482
My Ride: 2001 530i, 1997 M3/4
Send a message via AIM to scott0482
All of mine are peeling.. I have the super 77 ready to go. It looks like I need to borrow some torx bits from work.
The B pillars are different though, there is some thicker fabric underneath the main stuff. also, the fabric is work thin from the seatbelts rubbing against it, so I have have to replace that fabric. which means I may want to replace all of it so it matches.
scott0482 is offline   Reply With Quote
Old 01-17-2012, 10:49 PM   #19
zhenkaaaM3
My Ride: Fst'r then your e46
3m-90 does the trick.
zhenkaaaM3 is offline   Reply With Quote
Old 01-17-2012, 11:50 PM   #20
scott0482
I have been driving around like this for six months:
I just fixed it in 5 minutes.. I just have to wait for the glue to dry and pop it back in tomorrow.
I will try to remember taking pictures of me putting it back in tomorrow so you guys can see how it attaches..
