Sponsored by BAVSOUND
Old 09-12-2002, 02:52 PM   #1
noflash
My Ride: '99 328i-->'06 325i
stock stereo upgrade
Okay,
I just got a new job, so I can finally afford to upgrade my non-HK system in my '99 328i - note: the rear seats don't fold and I don't have a ski-pass.
My plans so far:
- Punch out ski-pass plate.
- Install Basslink vertically on the firewall right over the hole (I know the opinion is that the Basslink is weak, but I already own it and I really can't hear it in it's box in the closet!).
- Install 12-disc Pioneer changer w/ BMWPILA (it will work, 7-12 will look funky on display; I already own this so I gotta use it)
- tint
This all makes use of the factory non-HK amp. Will it be possible to upgrade the sound of the 10-speaker system after all this and keep the stock head-unit?
I DO NOT need more volume, I need better quality sound.
I would consider an amp and speaker upgrades, though I don't know what combination and how many of each.
Any help would be appreciated.
TIA
noflash is offline   Reply With Quote
Old 09-12-2002, 02:57 PM   #2
BGReddy00
09 X5
My Ride: 2009 X5
I would look into getting some JL W6 like one 10 for a lil extra bass and getting 2 Rockford Fosgate amps or JL one for your stereo and one for your sub...add a power cap, and finally start adding I.C.E. like maybe a indash apline or pioneer DVD player with flip screen
BGReddy00 is offline   Reply With Quote
Old 09-12-2002, 04:02 PM   #3
fabulus323
My Ride: 1999 323i
I started by adding an amp and a some subs(still using the factory HU). I had a problem getting bass in the cabin so I punched out the ski hole(like you plan on doing) and it did help but I still want more. So now I am going to remove the rear speakers and mount 2 10's in a free air (when the speaker uses the trunk as the box) set up. Once the subs are taken care of I am going to add a 2nd and 3rd amp to power the front and rear mids and tweets.
Although it takes awhile doing it in stages helps you appreciate you upgrades and you can save money for better performing products.
1999 323i
18 inch Alba Bertha's
BMW accessories 2dr. front bumper
McIntosh MC427
McIntosh MC427
McIntosh MC425
/////Alpine PXA H600
(3) JL Audio 8w6's
fabulus323 is offline   Reply With Quote
Old 09-12-2002, 04:23 PM   #4
noflash
So, two relatively small amps can power the ten speakers and hook up directly with the stock head unit?
That would be ideal. And an easy next step would be to gradually replace the speakers.
True?
Old 09-12-2002, 04:52 PM   #5
fabulus323
My Ride: 1999 323i
And like I said you appreciate your upgrades that much more. You might want to look into the JL Audio stealthboxes for the E46. I heard they sound really good(not too loud) and you dont need a big box in the trunk for them.
Check it out!
http://www.jlaudio.com/stealthbox/3series2.html
1999 323i
McIntosh MC427
McIntosh MC427
McIntosh MC425
(3) JL Audio 8w6's
Old 09-13-2002, 12:27 PM   #6
noflash
help!
Can someone move this to the new ICE forum?
I'd like to hear some more responses b/f it dies.
Thanks.
Old 09-13-2002, 02:00 PM   #7
NiTE
My Ride: M3
I dont think you even need 2 amps to power the factory 10 speakers, one for the speakers should be fine and one for the subs. Someone correct me if im wrong
NiTE is offline   Reply With Quote
Old 09-13-2002, 02:01 PM   #8
NiTE
My Ride: M3
Woah those JL stealthboxes would look nice in a car thats trying to retain a factory look... id rather keep the rear speakers and just get subs in the trunk though
Old 09-16-2002, 11:21 AM   #9
noflash
moderator?
move to ICE por favor!
Old 09-16-2002, 11:27 AM   #10
boynix
My Ride: 12 Volvo S60
my setup's gonna be 2 JL 10"s in a custom box in the trunk w/ a RF amp..
something simple to throw in and get some extra bass from the HK HU.
I believe one amp is good enough for the subs
boynix is offline   Reply With Quote
Old 09-16-2002, 12:02 PM   #11
noflash
but how amps
for the ten speakers? I mean is the stock amp a 10-channel amp?
I'm sure it's not, but how many channels do I need for 10 speakers.
And can you hook up the amp(s) to the stock head unit?
Old 09-16-2002, 08:20 PM   #12
djabaley
does anyone read my p0sts?
My Ride: 325 slushbox
Re: stock stereo upgrade
that's nice to hear for a change. in that case, go w/ the basslink. It's not hugely (new word) loud, but it has a built-in amp and should do well for adding in a little bit of low-end power. Also (strongly) consider the JL audio stealthboxes. They will need a separate amp, but they don't require much power for - what I consider to be - tasteful listening levels. (Try a Rockford Fosgate m250 or a smaller PPI amp if you get the stealthboxes.)
DO NOT try to use an after-market amp on the factory speakers, you are just asking for trouble. First, the factory speakers cannot handle much power, and you might run a chance of blowing them. Secondly, it can be very tedious to modify the stock system to this level. If you decide to do upgrades other than add more bass, you'll need to start with (at the minimum) a set of component speakers for the front and a four-channel amplifier. The four channel amp would power the front components (a mid-range and tweeter in each front door) and two "filler" speakers in the rear. The factory rear speakers should do fine for this as long as most amp power is diverted to the front components. So, that's just my two cents.
ps...any shop worth their weight in speaker wire should be able to interface the speaker set-up I mentioned with the factory head unit
djabaley is offline   Reply With Quote
Old 09-17-2002, 08:30 PM   #13
noflash
Re: Re: stock stereo upgrade
Good reply!
I am starting with the Basslink - hopefully moday.
If that doesn't do the trick I will take your advice with the component speakers.
