Old 08-20-2005, 01:16 AM   #1
Jlevi SW
1.888.JLEVISW
Jlevi SW's Avatar
My Ride: Vorsteiner 335i
Send a message via AIM to Jlevi SW
**Jlevi SW** Introducing ICELED Custom Electro Styling for your interior and exterior
Jlevi SW is proud to announce its new alliance with an overseas company to bring you the finest interior and exterior electro styling. While we are not as interested in the underbody effects as we are in the interior ones, we will now offer everything from interior “disco” setups to exterior lighting and underbody glow for show cars.
These lights are FULLY programmable and can do designs, patterns, beats, etc featuring between 2 and 12.6 million colors depending on models. They can be used WITH or without the various programming tools and controllers – some wired, some wireless.
Here is a basic rundown of the product lineup:
ICELED SPOT provides powerful illumination precisely where it's needed inside your car. It has the advantage of being self-contained in a small surface mounted box. The built-in program makes it suitable for stand-alone operation or alternatively it can be connected to other ICELED controllers.
ICELED FLOOD uses wide-angle LED's to provide a greater spread of light at close range while still maintaining the intensity of SPOT. The built-in programme makes it suitable for stand-alone operation or alternatively it can be connected to other ICELED controllers.
ICELED GEM is a miniature 'plug & play' light source that produces an incredibly big beam for such a tiny device. It will fit as a direct replacement for the 1.5" long 5 or 10 Watt lamp found in many automotive interior lights. It can also be used in other locations - with a special waterproof version available for external use. It has a built-in colour change program for stand-alone operation, or can be connected to any ICELED controller.
ICELED Tubes are available in different lengths to suit a wide variety of applications. Each tube contains a series of individually addressable pixels and can be supplied in lengths of 1, 2, 3 and 4 feet. Normally associated with ICELED UFO these tubes can also be connected to other ICELED controllers. In addition, the shortest one-foot tube has a a built-in colour change program that makes it suitable for stand-alone operation.
ICELED TRON Is a compact 6" tube providing an intense pool of light. Although it is the least expensive ICELED light source, it still produces over 2 million colours and shares all the other advanced features that are typical of the rest of the product range. For example, the built-in programme makes it suitable for stand-alone operation or alternatively it can be connected to other ICELED controllers.
ICELED Scanner Is a self-contained scanning light source housed in a 20" long tube. In keeping with all other ICELED light sources, scan patterns can appear in over 2 million different colours. The scanner can be used with or without external contol.
ICELED ZAP is a small handheld controller designed to operate all ICELED light sources such as TRON, GEM and Tubes. It is capable of generating a number of automated lighting programs such as sound-to-light and strobe as well as providing direct manual control of the colours displayed. It can also be used in conjunction with any other ICELED controller such as UFO or ZEN.
ICELED UFO is a complete underbody lighting kit consisting of four ICELED tubes, an advanced Electronic Control Unit and a wireless Infrared handset that allows the entire system to be remote controlled from inside or outside the car. The ECU can independently address all the pixels in the tubes allowing them to project patterns ranging from complex all the way down to a single colour on the ground. The ECU also provides ICELED data for synchronous control of additional ICELED light sources.
ICELED ZEN provides remote control of four independent zones of interior or exterior lighting. Each zone can be set to react to sound, colour sweep or follow the global colour from UFO if connected. Additional ZEN controllers can be linked to provide extra zones if required. 10 different programs plus a strobe mode can be recalled to provide instant access to a variety of dramatic lighting arrangements. Each ZEN can drive up to 16 ICELED light sources such as SPOT, GEM, FLOOD or Tube in various lengths.
ICELED EXP connects to ICELED UFO in order to expand the side-tube pattern to fill additional tubes. EXP can be used to extend the standard side-tube length to five, six, seven or eight feet by adding another one, two, three or four foot tube to the end of the standard four foot tube. Digital image processing is used to re-distribute and interpolate the original data to fill the combined length of tubing in a seamless fashion.
These new products are brought to you exclusively by Jlevi SW.
They have been installed rdsesq’s car for some time, and after seeing them we have decided to become a retailer.
We are in the process of testing them on our own cars and will most likely be offering them in 2 varieties:
-Purchase your own components and put the kit together.
-Purchase a ready made kit for interior and/or exterior with all compatible controllers and wiring included.
More to come. Stay tuned!
JL
Jlevi SW is offline   Reply With Quote
Old 08-20-2005, 01:23 AM   #2
Jlevi SW
1.888.JLEVISW
Jlevi SW's Avatar
Videos are available upon request.
JL
Old 08-20-2005, 01:32 AM   #3
Jlevi SW
1.888.JLEVISW
Jlevi SW's Avatar
Until such time as all these amazing products are on our site, here are the prices:
ITEM DESCRIPTION RETAIL PRICE
TRON.....................................47.99
GEM.......................................71.99
Rough GEM..............................74.99
ZAP.......................................71.99
SPOT.....................................85.99
FLOOD...................................93.99
FLOOD, EXTERIO....................104.99
ZEN (4 Zone).........................147.99
UFO.....................................938.99
ONE FT. TUBE EXTENSION........276.99
TWO FT. TUBE EXTENSION.......367.99
THREE FT. TUBE EXTENSION.....481.65
FOUR FT. TUBE EXTENSION......595.99
ONE FT. TUBE.........................85.99
SCANNER..............................166.99
Old 08-20-2005, 02:03 AM   #4
Edison@JleviSW
1.888.JLEVISW
Edison@JleviSW's Avatar
My Ride: BMW Duh
Can't wait to get these into my car!
Old 08-20-2005, 02:13 AM   #5
Jlevi SW
1.888.JLEVISW
Jlevi SW's Avatar
I'm not crazy about the exterior ones (reminds me of the fast and the furious), but the interior ones are AWESOME when we roll up to meets in Rob's car and it's like a nightclub
Old 08-20-2005, 02:02 PM   #6
JC7727
JC7727's Avatar
My Ride: 01 330i
Send a message via AIM to JC7727
I think we need to test some interior lights in "one" of your east coast cars.
Sponsored by Jlevi StreetWerks
FOR SALE: http://forum.e46fanatics.com/showthread.php?t=417026
JC7727 is offline   Reply With Quote
Old 08-20-2005, 02:06 PM   #7
Jlevi SW
1.888.JLEVISW
Jlevi SW's Avatar
OK, no problem. We're doing our first order monday, call me if you want to get in on it.
JL
Old 08-20-2005, 10:05 PM   #8
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
I almost want to get these done during Thanksgiving but unfortunately my car will be in LA
Old 08-20-2005, 10:51 PM   #9
Mike@Modbargains
ModBargains CEO
Mike@Modbargains's Avatar
My Ride: 2008 BMW 135i
Looks good Jon!! Another great product offering from JleviSW
Authorized Dealer of: Forgestar Wheels l KW Suspension l VMR Wheels l Miro Wheels
Hours: Monday - Friday 8am - 7pm, Saturday 8am - 5pm (PST)
We Specialize In: BMW Parts | BMW Rims | BMW Wheels | BMW Exhaust
Mike@Modbargains is offline   Reply With Quote
Old 08-21-2005, 01:21 AM   #10
Jlevi SW
1.888.JLEVISW
Jlevi SW's Avatar
But mine won't!
JL
Old 08-21-2005, 01:31 AM   #11
E46SEAN323i
My Ride: 00' BMW 323i
hey jon, can you send me the videos. my email is cackmang@gmail.com
E46SEAN323i is offline   Reply With Quote
Old 08-21-2005, 07:53 PM   #12
E46SEAN323i
whats the best setup for interior? id need the remote zap of course but what is the best looking interior lighting kit. and are the prices for 1 or the bulbs or complete set?
Old 08-22-2005, 03:23 AM   #13
BMWE46Fl
My Ride: 2000 E46 turbo
Send a message via AIM to BMWE46Fl
1k for an underbody LED kit, dont you think thats a little high?
00 323ci/3.4L turbo
02 M3 SMGII-Sold
05 330ci-Sold
04 325ci
04 M3 Vert SMGII-NEW TOY
00 Toyota Camry
BMWE46Fl is offline   Reply With Quote
Old 08-22-2005, 10:31 AM   #14
Dougs325
Anxiously awaits a turbo
Dougs325's Avatar
My Ride: '03 325i
Send a message via AIM to Dougs325
those interiors are HOT!!
If someone challenges you to an after-school fight, tell them you don't want to fight afterschool...you can kick their ass right now.
Dougs325 is offline   Reply With Quote
Old 08-22-2005, 11:25 AM   #15
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
This is not just any underbody kit but a multi-color LED underbody kit that changes colors via remote control. It's not for everyone but then again we don't market it that way
What I am doing on my 4 door is the zap system with 2 floods for the rear and a spot for the front
Old 08-26-2005, 04:30 PM   #16
Jlevi SW
1.888.JLEVISW
Jlevi SW's Avatar
I gotta order our first 2 sets soon.
JL
Old 08-29-2005, 02:08 PM   #17
3quarterI
3quarterI's Avatar
My Ride: 2010 Honda Insight
can you send the video(s) to davidc1982@hotmail.com? thanks
Instagram - @MisterDavidC
3quarterI is offline   Reply With Quote
Old 08-29-2005, 02:50 PM   #18
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
We are putting our order in this week for our introductory kits!
Old 08-29-2005, 03:56 PM   #19
tdevil
My Ride: 03 325i
Send a message via AIM to tdevil
could these be used as puddle lamps? or they look too much like underbody glow?
tdevil is offline   Reply With Quote
Old 08-29-2005, 04:00 PM   #20
Edison@JleviSW
1.888.JLEVISW
My Ride: BMW Duh
They easily could be puddly lamps, you can get a spot LED system that is waterproof and able to be mounted outside
These shine a focused beam of light!
