Bavarian Soundwerks' Mobile Electronics Forum
Have all your A/V and electronics questions answered here. Ipods, A/V, Radar Detectors Oh My! Sponsored by Bavarian Soundwerks |
#1 |
Wiring diagram for HK subs
Does anyone have the link to wiring your speakers up again.
I recall someone had a diagram of it. I tried a search but i can't seem to get the key words to spit ou the diagram. Can someone repost? I'm trying to wire an amp up to the kicker 6x9 I have replaced the factory HK subs with. It looks like I'll need a line level converter but I'm wondering what else. Any tips? |
#2 |
here
#3 |
Line Out Converter?
Does the Line out converter have to be a VEN4?
#4 |
Clem's Padawan
Any idea what crossover points the signal coming out from the HK sub amp are set at?
Also since I have a wagon (i.e. 10speaker HK set up), I think there is only one amp I'm thinking of leaving base system in tact and added a "real" sub. If I want to grab a full freq. signal where is the easiest place to tap into the system? TIA
#5 |
Banned
My Ride: 2002 LSB M3 6-spd
Is there anyway to make a HK sub amp and main amp work w/an aftermarket deck?
#6 |
What subs are you going to run? I have JL 8-IB4's running off the factory sub amp. Not too bad. I found that the polarity seems to be reversed (swap + and -). If you still want to replace that amp, go with something that accepts differential or balanced inputs. Soundstream
http://www.mindspring.com/~pmbenn/hk_retrofit.htm
'02 330i Steel Grey SP,18's,X's ECIS, front strut bar, FOX exhaust clears & silvers diesel ducts!! |
