The Tire Rack's Tire & Wheel Forum
Use this forum to discuss anything in relation to wheels to tires to offsets. Sponsored by The Tire Rack |
#1 |
Banned
What psi do you run on tires?
I do 40psi on each tire...what do you guys run?
#2 |
My Ride: 2004 330i zhp
I want to know too. Mine is ZHP with stock wheels/tires.
#3 |
38 to 40
2001 330ci retired
#4 |
it should say on the lable on the side of your door. or the side wall of your tires.
If you're not scared, you need to be driving Faster! |
#5 |
39 front/ 40 rear
#6 |
My Ride: smelly & leaky 330ci
46
#7 |
usually around 36......everyday driving in the east coast.
#8 | |
Recommended PSI....
#9 |
Dude you aint no baller unless you got 35 psi
#10 |
19" rims 38 psi's all around
#11 |
My Ride: 2000 323i 5spd
18"s with 35-36 psi all around
They say there is a thin line between genius and insanity.
I say it is more like a Mobius Strip. |
#12 | |
#13 |
Actually, it can vary from car to car and tire to tire. THe best way to find out what works best for YOUR car is to draw a chalk line on each tire. If the outside parts, or the center wear unevenly then you need to adjust your psi accordingly. the chalk line should wear evenly.
Makes sense, right?
