Old 08-24-2005, 08:02 AM   #1
raine24
My Ride: 330i Lim
Send a message via Yahoo to raine24
Q: SMG with supercharger ??
Honestly did a search and did not find anything useful exept some of smg owners have had qlutch problems.
How does the smg tranny handel SK1 kit comparing to manual and auto?? do I need and can I upgrade a stronger qlutch??
Rainer
raine24 is offline   Reply With Quote
Old 08-29-2005, 12:03 AM   #2
Mike Benvo
Past Site Sponsor
My Ride: Dinan E60 ///M5
Send a message via AIM to Mike Benvo
Rainer
You would probably just have to upgrade the clutch.
Mike Benvo is offline   Reply With Quote
Old 08-30-2005, 07:28 AM   #3
RUSSancho
My Ride: 2004 330Ci SMG
Well I guess I am the one with SMG who had all the clutch problems...
I'll give you my feedback on what I had to do to make it work.
At first, when I was chosing between SKI and SKII I was hesitating on how much power the SMG tranny can hold, so in the end I went with SKI to be sure.
After the install I could really feel the difference in car's performance, but i noticed a serious problem in gear changes. The clutch was slipping bad. So bad that it took all the fun from driving a S/Ced car.
I was speculating on what the problem could be and it took me awhile to undestand what had to be done.
I've also searched this forum for someone who installed S/C on 330 with SMG but didnt find answers. At first I thought that the control unit of my SMG was programmed for stock engine torqe. Thats why it didn't realesed the clutch and allowed for clutch slip. I asked many dealers and tuning companies in Moscow if they can reprogramm the SMG unit. they all said "NO"
I was desperate and was ready to remove the supercharger...
Later after another extensive search I learned that all 330Ci original clutch has a new "SAC" (Self Adjusting Clutch) design. That was probably the cause of my problems (you can learn more about it at http://www.uucmotorwerks.com)
I've decided that uprgrading the clutch was my best bet. Unfortunatly for me (I live in Russia) we dont have any tuning companies who offer clutch upgrades for e46 so I had to oder it from uucmotorwerks. (I went with Lightweight flywheel and clutch combo with organic clutch)
After the install the problem was gone!!! but another problem emerged...
the car was very jerky everytime i started rolling...it felt like the clutch was released to soon, so I had to throttle up to compensate. As a result the car was jumpy and traffic was a nightmare. Again I was dissapointed
This forum helped me in solving this problem . I went to a dealer and asked them to update the SMG control unit software and also to reset the control unit so it goes into learning mode (actually they do this everytime you change the clutch). After that I felt like the car was trying to adapt to a new clutch. It took 2 days for it to adapt...Now I can definitely say that the car is amazing. It has the performance of a S/Ced car and is a daily driver.
bottomline: heres what you need to do
upgrade the clutch --> update SMG cotrol unit --> let the car adapt to a new clutch
hope it helps. Good luck!
RUSSancho is offline   Reply With Quote
Old 08-30-2005, 07:39 AM   #4
raine24
My Ride: 330i Lim
woa thanks a lot for the write up
you said that you changed the flywheels also.. why? is this reccomended or just the clutch? did you order UUC-330-6S-OEPO 658USD??
thanks again
R.
Old 08-30-2005, 08:37 AM   #5
RUSSancho
Once I started to upgrade the clutch I thought "why not put a lighter flywheel while I am a it" so I dont know if its a must or not, but I can say the car revs up quicker and the gear changes are faster.
I ordered this:
Lightweight Flywheel & clutch - '03+ E46 330 6-speed/SMG, Z4 3.0, '04+ 530i
at http://www.uucmotorwerks.com/
Old 08-30-2005, 11:07 AM   #6
sublimey
My Ride: 325Ci
Hi Russ,
The stock clutch should be able to handle up to 300HP or more that the SK1 puts out. Is it really neccessary to go through the steps you suggested? Could you just update the control unit and let the car adapt? So I need another control unit?
Jason
sublimey is offline   Reply With Quote
Old 08-31-2005, 07:16 AM   #7
RUSSancho
You can try just updating the control unit software. Dont know if it'll work... I changed the clutch to eliminate SAC system in the stock clutch which I think is the main reason why the clutch was slipping
you dont need another control unit...you just need to reset it so it goes into learning mode.
Old 09-07-2005, 08:58 AM   #8
adliz
My Ride: 325sc smg
emm.. my smg + sk1 slips very badly.. went to dealer, and they said the plate still has plenty of thickness in it. they reset the control unit to learning mode.. so i guess it's not a mechanical issue.. must be the software..
problem solved!! but only for a couple of weeks..!!
now the problem becomes more apparent.. can hardly rev up without the clutch slipping.. but funny, if i stop by the roadside and restart the car, it'd be back to good.. that made me conclude that the software is the issue..
all this take away the joy of driving the car.. sigh..
any smg owner (non-M) checked if we have the CDV on the car? anyone tried removing it?
adliz is offline   Reply With Quote
Old 09-08-2005, 04:03 AM   #9
RUSSancho
I have the same problem...
After the clutch and flywheel install the gear changes were amazing...but after couple of weeks its slipping again.
Im really hoping that SMG tranny has CDV so I can remove it, burn it and destroy it.
Old 09-08-2005, 09:05 AM   #10
sublimey
My Ride: 325Ci
Russ... I'm not so sure it's slipping because of the clutchand flywheel
You could have a bigger underlying problem. I just had my GB change because of that problem
Old 09-09-2005, 03:35 AM   #11
RUSSancho
You changed your gearbox?
Old 09-09-2005, 05:29 AM   #12
sublimey
My Ride: 325Ci
Yup I did! My GB was giving me a hell of alot of problems. Periodically from a stop I had to revv it up to 2000rpm then the clutch would catch and then slip and it would be almost impossible for me to change gears. send it back to BMW countless of times finally they changed the whole GB
Old 09-09-2005, 02:27 PM   #13
jersey
My Ride: 2004 330I ZHP
Send a message via ICQ to jersey Send a message via AIM to jersey
jeez, sublimey are you boosted?
Special Thanks To: DPEngineering | Jlevi StreetWerks
jersey is offline   Reply With Quote
Old 09-10-2005, 12:29 AM   #14
sublimey
My Ride: 325Ci
Hey,
Nope not FI at all. That's why I'm concerned about the potential problems if I get mine S/Ced! Any successful S/C stories with SSG?
Old 10-09-2005, 01:06 PM   #15
sublimey
My Ride: 325Ci
Hi Russ
Any updates on whether your SSG unit is still slipping?
Old 10-10-2005, 06:09 AM   #16
RUSSancho
I had a accident...will have to repair the car before I can get back to this slipping problem.
Old 10-10-2005, 10:35 AM   #17
sublimey
My Ride: 325Ci
Hi,
Sorry to hear about that.
Hope everything turns out alright.
J
Old 11-15-2005, 08:07 PM   #18
jersey
hey RUSSancho how go the repairs?
any chance to get back to the slipping issue?
Old 12-08-2005, 12:02 PM   #19
RUSSancho
hey....got the car back from the dealer...
A good thing is that the S/C wasn't damaged
the bad thing: the clutch is slipping bad and im still not sure how to fix it
i am starting to think that the software in the control unit is to blame...but im not sure if you can reprogramm the software (not just reset it)
Old 12-08-2005, 12:04 PM   #20
jersey
hmmm thats not good news...i was going to pick up a blower in the december sale...but i guess i should wait......ill keep up the research and if i find anything ill pass on the info...please keep me/us updated....
have you talked to technik about this??
