Old 12-08-2005, 06:44 PM   #21
Lay2Low
My Ride: Psshht Widebody; M3
Send a message via AIM to Lay2Low
What did you need to do the SMG swap on your car? Please list everything, and how much it actually cost to do it! Much appreciated!
Lay2Low is offline   Reply With Quote
Old 12-08-2005, 06:46 PM   #22
jersey
My Ride: 2004 330I ZHP
Send a message via ICQ to jersey Send a message via AIM to jersey
mine came with it stock.....
Special Thanks To: DPEngineering | Jlevi StreetWerks
jersey is offline   Reply With Quote
Old 12-08-2005, 06:59 PM   #23
Rider_Ryuuga_13
My Ride: Dragblacker
So SSG was available for 2004 ZHPs?
Rider_Ryuuga_13 is offline   Reply With Quote
Old 12-08-2005, 10:26 PM   #24
crazy1323
My Ride: '02 330Ci
Send a message via AIM to crazy1323
yes, SMG was available on 2004 330's and 325's. After that they stopped ofering it. so only 4 door ZHP's can have SMG
'02 330Ci
A Bimmer, a Porsche, and an old Dodge, I am too lazy to list and update.
crazy1323 is offline   Reply With Quote
Old 12-08-2005, 11:09 PM   #25
2003330i
My Ride: SC'330izhp,09 335i,
what is ssg
2003330i is offline   Reply With Quote
Old 12-08-2005, 11:12 PM   #26
jersey
SSG is the same as SMG I, SMG II is on the m3
you can downshift and upshift with both the left and right paddle
little less hardcore than the M3 SMG
Old 12-09-2005, 10:31 AM   #27
jersey
hey russ...
how bad is this issue? can you describe when it slips, and if there is anything you can do (let off the gas) to get it to lock up.
can you gradually get on the gas, let the clutch engage, then hammer the gas and not slip? does 1st to 2nd gear slip too?
Old 12-09-2005, 11:16 AM   #28
Mr Paddle.Shift
Mr Paddle.Shift's Avatar
My Ride: B3 epsilon
I believe someone mentioned in this or other thread you started.
SSG has nothing to do with the SMG I, II and III lineup. SMG I was first introduced in E36 M3 Evo. SMG II in E46 M3. SMG III in E60 M5, E63 M6.
SSG is made by Magneti-Marelli and was instroduced in non-M E46s around 2002 in Europe and around the world except US.
Technik Engineering ASA Stage 1.
Supercharged E46 M54B25.
2011 NASA TTC So Cal Champion!
Track blog.
Technik Engineering oil cap o-ring maintenance kit available.
Mr Paddle.Shift is offline   Reply With Quote
Old 12-13-2005, 08:36 AM   #29
RUSSancho
My Ride: 2004 330Ci SMG
this issue is something that was bothering me for quiet a while, but after getting my car back from the dealer I was so happy that didn't give a dam about slipping (actually for some reason it there was no slipping for a couple of days)
letting of the gas does help, but waiting for the clutch to lock up is annoying.
RUSSancho is offline   Reply With Quote
Old 12-15-2005, 10:40 AM   #30
sublimey
My Ride: 325Ci
Hi Russ, so technically the problem has not been solved? Ugh... I want to S/C my car!!!
sublimey is offline   Reply With Quote
Old 12-15-2005, 10:41 AM   #31
jersey
no i dont think its been solved....he said even after he got his car back from the shop it was slipping....at first it wasnt, but then as the software learned, it started to slip again....
Old 12-15-2005, 01:10 PM   #32
sublimey
My Ride: 325Ci
I think the problem lies either with the clutch unable to deal with the larger power or the SMG hydraulics just are unreliable...
Jersey will you be S/Cing your car?
Old 12-19-2005, 03:30 PM   #33
jersey
i was seriously considering it...but now im having second thoughts to be honest
Old 09-16-2008, 09:31 AM   #34
_Calle_
My Ride: 330Ci ESS TS2
Send a message via ICQ to _Calle_
Hi RUS
could you remove the problem completely? do you have the performance UUC Organic - street and occassional track clutch?
_Calle_ is offline   Reply With Quote
