Sponsored by The Tire Rack
Old 08-25-2005, 07:11 AM   #1
Slither
My Ride: 330i
Where to get wheel locks....after adding spacers?
Just put on coilovers and there was some slight rubbing happening.
I put on some 5mm spacers and the problem was solved.
New problem is that now my old wheel locks won't fit.
Where can I get some wheel locks that will now fit my wheels taking into account the 5mm difference?
Thanks.
Slither is offline   Reply With Quote
Old 08-25-2005, 05:11 PM   #2
Gary@Tirerack
Moderator
Gary@Tirerack's Avatar
My Ride: 1995 BMW M3
Thanks.
I replied to your email, but it keeps getting bounced back to me for some reason. Here is the reply :
Stock lugs have a usable length of 26mm, unfortunately we have no locking lugs in the 31-30mm range available. The next closest is going to be longer at 33mm:
27015 MCGARD 33.3UL
The danger of going longer is that there may be contact of the bolt going in too far and causing damage.
Refer to 'Gary/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by ordering through the sig link.
Click sig! -->
Gary@Tirerack is offline   Reply With Quote
Old 08-25-2005, 05:27 PM   #3
Slither
My Ride: 330i
Thanks Gary.
Would I be able to order the 33mm and just cut off a couple of mm's?
Old 08-26-2005, 02:13 AM   #4
Munky
My Ride: too old for this BS
Try these euro-style locks....They are the same size as BMW lugs.
EURO WHEEL LOCKS
Munky is offline   Reply With Quote
Old 08-26-2005, 09:42 AM   #5
Gary@Tirerack
Moderator
Thanks Gary.
If you're able to do so, then I don't see a problem.
Click sig! -->
