Old 08-31-2005, 12:53 PM   #1
mdahman
My Ride: 2001, 330XI
Subtle Hissing / Fluttering Noise coming for Drivers Side of Car
I have this slight hissing / fluttering noise that comes from the driver’s side of the car. If I turn the steering wheel slightly to the left or right, the noise goes away for a brief moment. It seems like the noise is most prevalent when the wheels are straight and the car has had an opportunity to warm up a bit.
Dealer hooked the car up to their computer and said nothing is wrong with the car.
Anyone run into this before / have any suggestions?
Big Thanks in advance,
MD
2001 330XI
mdahman is offline   Reply With Quote
Old 08-31-2005, 02:10 PM   #2
dave12345
My Ride: 2003 ///M3 6MT
i hear like a air blowing noise coming from the back of my car if u stand next to my rear wheels.... sounds like its coming from the differential/axle area
2003 BMW ///M3
Carbon Black/Cinnamon 6MT
dave12345 is offline   Reply With Quote
Old 08-31-2005, 02:43 PM   #3
mdahman
this is definitely coming from the front of the car ...I can sometimes feel the vibration of the fluttering coming through the steering wheel.
Old 09-01-2005, 05:55 AM   #4
Mike@Modbargains
ModBargains CEO
Mike@Modbargains's Avatar
My Ride: 2008 BMW 135i
I don't know what it is, just wanted to bump your thread to the top so somebody who might know can respond
Authorized Dealer of: Forgestar Wheels l KW Suspension l VMR Wheels l Miro Wheels
Hours: Monday - Friday 8am - 7pm, Saturday 8am - 5pm (PST)
We Specialize In: BMW Parts | BMW Rims | BMW Wheels | BMW Exhaust
Mike@Modbargains is offline   Reply With Quote
Old 09-01-2005, 11:10 AM   #5
mdahman
Hey guys, I got a response from another member who had this problem as well. Turns out he took it to the dealer where they were able to identify that a vacuum hose that originates in the back of the dash to a valve in the exhaust had come loose. Does anyone know about this hose and how to access it?
Any help / guidance would be greatly appreciated!
Matt
Old 09-01-2005, 12:28 PM   #6
LCB
My Ride: 330ci
hose...
i had a similar problem, and it wasn't a huge issue. in my case, a hose was leaking air. the hose was worn due to rubbing one of the steering wheel components.
You can access this particular hose from underneath the steering wheel.
goodluck
LCB is offline   Reply With Quote
Old 06-30-2006, 03:17 PM   #7
hanzo
My Ride: '03 325i, '04 M3 SMG
I think I have the same problem. This noise goes away when I accelerate, or turn the wheel. It feels like the A/C is on but when i shut everything off I can hear it. So it's a loose vacuum hose?
hanzo is offline   Reply With Quote
Old 06-30-2006, 03:21 PM   #8
dave12345
i only hear my noise when i get outta the car and its running, i cant even hear it from inside the car
is it normal for hte differential area to make an air noise? its louder on the passenger side
2003 BMW ///M3
Old 06-30-2006, 03:25 PM   #9
supark
My Ride: E60 M5, 69 02
it is the vacuum line leading from your manifold to the mpg gauge in your instrument cluster. For some idiot reason, it's routed at the factory to rub against the base of the steering column where it emerges from the firewall in the cabin. Over time, the constant rubbing wears a hole in the vacuum line. That's why it sometimes goes away when you move your steering wheel slightly and why it goes away when you accelerate.
It's pretty easy to temporarily fix/check. Remove the panel underneath your steering wheel - couple screws and pop rivets are all that hold it in. Look towards the very end of the steering column and you should see a thin rubber vacuum line. If it has a hole in it - there's your culprit.
You may think that the sound is actually coming from another portion of the dash - mine seemed like it was coming from the left vent next to the steering wheel. The reason for this is because in that enclosed space, the hissing gets deflected a bit so it's difficult to tell exactly where it's originating from. When I go in this weekend to fix mine for good I'll take a few pics.
supark is offline   Reply With Quote
Old 06-30-2006, 03:28 PM   #10
supark
it can also be vacuum leaks in your engine bay - however, be aware that your intake manifold and various vacuum lines will by their very function make some sucking/hissing noises. I've heard of others having issues with the rubber boot attached to the intake manifold developing cracks, but on mine - the noise wasn't present in the engine bay, only the cabin.
Old 06-30-2006, 04:41 PM   #11
hanzo
Thanks for the info all!!! How do I remove the panel underneath the steering wheel? Can I just put electrical tape on the hole of the line? I need to temporarily relieve this until I go to dealer on monday.
Old 06-30-2006, 05:52 PM   #12
supark
you can try electrical tape like I did, but it won't hold for very long - the constant pressure from the vacuum line will eventually work it's way past the tape. The only way to fix the hole is to either splice in some new vacuum line somehow or preferably to replace the entire hose. Don't worry about fixing it ASAP - it won't hurt anything in the meantime, just annoying.
As for removing the panel - it's held on with a couple of those expanding rivets along with some screws. The top edge is held on with a couple snaps that you have to just pop out with a hard tug - it'll almost feel like you might break something but you're not.
Old 09-27-2006, 12:42 PM   #13
mdahman
supark, were you able to take photos of the problematic hose? I still have this problem and any guidance you have to offer would be great.
thanks!
Old 09-27-2006, 03:46 PM   #14
mgrassi99
My Ride: 2006 330i
I had this problem too when I first bought my used 2001. The sound was bad enough that it probably saved me significant $$ because the dealer had no idea what was going on with it, we thought the whole vacuum system might be toast.
Its a very simple fix...once you take off the cover under the steering wheel, the hose will be very obvious (black with a blue stripe, if I remember correctly, about 1/4" in diameter). With the way it rubbed against the steering column, the hole was easy to find - it was towards the firewall. I wrapped it in duct tape (which has held for 2 months so far) and tucked the hose out of the way a bit so that the problem would not recur.
Good luck fixing it!
mgrassi99 is offline   Reply With Quote
Old 05-26-2011, 09:25 PM   #15
immigrant
My Ride: 2001 BMW 330CI
Send a message via MSN to immigrant
I know this is an old thread but im having the same problem. Anyone do a DIY on this?
FS OEM BLAUPUNKT CD PLAYER (no mode)
FS 35W CANBUS BALLASTS (UMNITZA)
FS COMPLETE OEM LIGHTS: FRONT,CORNERS, REAR
FS PEAKE TOOL
FS 2001 LCM
P.M. me for anything you are interested.
immigrant is offline   Reply With Quote
Old 11-29-2011, 02:13 PM   #16
alfie87
My Ride: '02 330i 4dr
Just returned to E-46, I have a similar issue to all but my "hissing" noise only rears its ugly head when I brake. The funny thing, no loss in braking. The pedal does not sink and stays firm. Any thoughts?
alfie87 is offline   Reply With Quote
Old 11-29-2011, 03:57 PM   #17
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
http://forum.e46fanatics.com/showthr...m+steering+diy
heres the fix. Its related to whats described in this thread.
"Player-haters turning bitch like they have vaginas ‘Cause we see them dollar signs and let the cash blind us.
Money'll brainwash you and leave your ass mindless..When snakes slither in the grass spineless.."
MachRc is offline   Reply With Quote
