Electric Buzz (cricket sound) behind dashboard - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 13 votes, 4.92 average. Display Modes
Old 09-07-2005, 05:18 PM   #1
samytampafl
My Ride: 325ci
Angry Electric Buzz (cricket sound) behind dashboard
Hi, just began this weekend.. upon starting/or just passing the key to the on position. I hear what sounds like a cricket/buzz from behind the dashboard.. it happens w/ the a/c on or off.. and stops as soon as I turn the key to the off position.. any ideas? has this happened to someone else?? there's a thread but no help on it.. any info is appreciated in advance! Thanks..
samytampafl is offline   Reply With Quote
Old 09-28-2005, 06:57 PM   #2
samytampafl
My Ride: 325ci
found the answer to the cricket/buzz/chirp sound...
will post a DYI w/ pics soon... just above the footrest there's an air blower that sends cabin temperature air into an electronic cluster across the firewall.. this blower works at all times w/ A/C on or off.. as long as the key is on the second position, so after 80k miles of use or such the blower begins to loose it's balance and the blower itself begins to scratch the plastic housing hence creating the chirp/cricket sounds.. took it off and greased it but all it did was hide the noise for a couple of days.. so went to pick up a new one $70 at the dealership.. so I hope this helps others since I did see several people asking about this in this and other forums.. but no one had an exact answer.. will post pics later..
Old 09-28-2005, 07:14 PM   #3
crumpet
My Ride: burned down
Send a message via AIM to crumpet
looking forward to the DIY, i have this same problem!
crumpet is offline   Reply With Quote
Old 09-28-2005, 07:48 PM   #4
exmike
My Ride: 2002 Silver 330ci
Send a message via AIM to exmike
ive had the cricket chirping sound since like 20k miles. looking forward to the DIY
exmike is offline   Reply With Quote
Old 09-29-2005, 12:17 PM   #5
samytampafl
My Ride: 325ci
part has been ordered, will not be in 'till friday.. will post DIY over the weekend or early next week.
Old 09-29-2005, 12:25 PM   #6
KWMSeattleU
My Ride: TiAg 328i and X5
Send a message via AIM to KWMSeattleU
I also have the cricket sound on occasion... it comes and goes. I'm also looking forward to the DIY.
________________________________________
KWMSeattleU is offline   Reply With Quote
Old 09-29-2005, 01:37 PM   #7
nEVERCLEAR
My Ride: 323
I have the sound also, I thought is was from the Final stage resister that is up in that area.
other post
Thinking about a Honda or VW Dont buy from East Coast Honda - VW Read about my experience here
Some people dream of speed-others create a damn jet powered shopping cart.
Curious about VoIP and Vonage click here
nEVERCLEAR is offline   Reply With Quote
Old 09-29-2005, 04:11 PM   #8
coocoohead
My Ride: bmw 330ci
I have a cricket sound but that' when I go through bumpy roads. I feel like something is loose in the dash. Any idea? It's so annoying.
coocoohead is offline   Reply With Quote
Old 09-29-2005, 04:11 PM   #9
belaire46
My Ride: 2001 325i
I hope this is the cause of my "cricket." It's driving me crazy. Keep us updated with the fix.
belaire46 is offline   Reply With Quote
Old 09-30-2005, 12:37 AM   #10
18jake18
My Ride: '01 White 325i
I am gettin a crickety sound from my dash too. It seems to be coming from the area behind or right next to the glove box. Mine however has nothing to do with wether the fan is on or off. Its only when i accelerate, i'll hear it.
18jake18 is offline   Reply With Quote
Old 09-30-2005, 07:35 PM   #11
18jake18
Old 10-03-2005, 01:39 PM   #12
samytampafl
My Ride: 325ci
Ok.. here's the DIY for the cricket/electric buzz behind the dashboard (driver's side) culprit was the fan. You will need the following description and part number from the dealership: BLOWER WITH COVER PART NO. 12-14-1-437-454. Cost $70.00. It takes approx. 30 mins to change and you will need the following tools a hexagonal tool set and a phillips screw driver.
Here we go.. STEP 1: remove the plastic cover just above the pedals..
JUST A FRIENDLY REMINDER REMOVE THE PIN
COMPLETY OFF THE FASTENER..
IF U PULL THE FASTENER WITH THE PIN INSIDE IT WILL BREAK!!!
STEP 2: remove the 3 screws from the blower.. yes this is the culprit to the cricket noise!!.. which dealer could never find..
Warning! once blower is free.. is NOT!..
DO NOT PULL ON IT!! it's not yet free from the electric connection..
STEP 3: open hood.. head out to the front of the car.. find the electric box and remove the 4 hex screws, then remove the plastic cover..
STEP 4: Where my index finger is, in the back of the box you will see the connector to the blower slide it off (after releasing the safety clip it slides down not up...) Then disconnect the blower and retrieve it from the inside..
STEP 6: get replacement, connect it.. and place everything back!!
Hope this helps and enjoy u'r cricket free car!!
Old 10-04-2005, 07:30 AM   #13
samytampafl
My Ride: 325ci
Dyi
(don't know what happened to the pics.. let's try again)
Warning! once blower is free.. it's NOT!..
ID:	147662   Click image for larger version
ID:	147663   Click image for larger version
ID:	147664   Click image for larger version
Old 11-10-2005, 12:39 PM   #14
belaire46
My Ride: 2001 325i
Yay...just did the DIY but instead of replacing the blower I just greased it (too cheap to buy a new one). Hopefully it will keep the noise from coming back for more than a few days. So far so good.
Anyway, how important do you think the blower is? If it the noise comes back I was just thinking about unplugging the damn thing until I have time again to replace it with a new one.
Old 11-10-2005, 02:40 PM   #15
djm1k0
My Ride: -99- 323i
just subscribing
djm1k0 is offline   Reply With Quote
Old 11-27-2005, 12:27 AM   #16
belaire46
My Ride: 2001 325i
Still criket free for almost a month now after lubricating the blower thingy.
Old 11-27-2005, 02:03 AM   #17
ASD123187
My Ride: /!\
Send a message via AIM to ASD123187
Can someone post a vid or soundclip of the "cricket" culprit...
I have a buzz coming from somewhere behind the dash whenever I release the clutch and hit the accelerater. It's annoying as hell because I think you can hear it outside as well. The catch is, you only hear the buzz when disengaging clutch and hitting 950-1050 RPM's
TIA for any advice.. AP
ASD123187 is offline   Reply With Quote
Old 11-27-2005, 03:38 AM   #18
emthree
My Ride: E46 / E60 M5
Send a message via MSN to emthree
Nice DIY
emthree is offline   Reply With Quote
Old 11-27-2005, 03:59 AM   #19
bmwmkc323i
My Ride: 1999 BMW 323i sedan
Wow, this is exactly the same problem I just started to have on my 99 323i with 130K miles. A month ago, in the morning when I was starting my car, I would hear some buzzing sound coming from the driver's side dashboard and I also hear a cricket sound or clicking sound while i back up my car sometimes, once i start driving the noise goes away. But the cricket/chirping sound still happens sometimes when driving at night.
Does anyone know if I dont fix this, would it cause any problems in the future?
2007 BMW 328i E90 (Premium, Navi, Xenon, Steptronic, Black Sapphire/Gray Dakota Leather)
My 1999 BMW 323i sedan is SOLD!!
Active Autowerkes Front Strut Bar
Clear Lenses
18" CSL replicas
OEM M3 Lip spoiler
Jlevi - Predator Chromium DDE
Yes, my car is photoshopped!!
bmwmkc323i is offline   Reply With Quote
Old 11-29-2005, 06:44 AM   #20
Nehemiah1
My Ride: 325i
Thanx
Great DIY! Took apart the blower fan and the jimminey cricket chirp went away.
The Stealership wanted to replace the instrument cluster!
Nehemiah1 is offline   Reply With Quote
blower, cover
