Sponsored by The Tire Rack
Old 09-08-2005, 06:56 AM   #1
sna77
sna77's Avatar
My Ride: BMW
Right tire sixe for staggered setup?
Going to put staggered 18 ZHP wheels onto my 2001 325i sedan:
Unsure of the correct tire size to go with all around...
Wheels:
front 18 x 8
rear 18 x 8.5
this is what tire rack has:
Front Optional 18" 225/40-18
Rear Optional 18" 245/35-18
The 225 / 245 part makes sense to me, but wouldn't the sidewall always be 40???
sna77 is offline   Reply With Quote
Old 09-08-2005, 07:10 AM   #2
BMW330d
My Ride: 330d Sport
Wheels:
front 18 x 8
rear 18 x 8.5
Standard fit from BMW is 225/35/18 on the rear I belive the reason that a 35 profile is fitted to keep the rolling radius the same as the front, because it is wider tire it needs a smaller aspect ratio
Someone please correct me if I am wrong
BMW330d is offline   Reply With Quote
Old 09-08-2005, 07:12 AM   #3
sna77
sna77's Avatar
My Ride: BMW
So the sidewall is actually smaller on the rear tire?
Old 09-08-2005, 08:38 AM   #4
BMW330d
My Ride: 330d Sport
Firstly I misposted above the rear tire should be 255/35/18.
225/40 = 225mm x 40% =90mm
255/35 = 255mm x 35% = 89.25mm
Therefore the difference in sidewall heights is 0.75mm! Despite the fact that the tire is 30mm wider
Hope this helps
Old 09-09-2005, 08:09 AM   #5
sna77
sna77's Avatar
My Ride: BMW
Hope this helps
Thats great, thanks. And that config wont run on a stock 325i?
Old 09-09-2005, 10:50 AM   #6
whiteNgold
My Ride: 2002 325ci
I'm pretty sure it'll fit on your 325i. The offset on those wheels (if you get the real ZHP ones) should clear your wells ok because they came from a similar body. You could put bigger tires on if you wanted, but you might have to roll your fenders. I have 18x8 (+40) in the front and 18x9 (+47) in the back, lowered with the H&R cupkit. Tires are 235/40 front and 265/40 in the back. Yes, I'm raked really hard and the back tire is a little tucked. I rolled my rear fender just a little to make sure I won't rub, but I never rubbed before I rolled them anyway. Hope this helps.
whiteNgold is offline   Reply With Quote
Old 09-09-2005, 12:34 PM   #7
sna77
sna77's Avatar
My Ride: BMW
I'm just going to go with the stock setup, so there should be no need to adjust the fenders, right?
225/40/18 front
255/35/18 rear
Old 09-09-2005, 01:46 PM   #8
Tutankhamon
My Ride: 2017 M2, 2002 330ci
Send a message via ICQ to Tutankhamon Send a message via AIM to Tutankhamon Send a message via MSN to Tutankhamon
225/40/18 front
255/35/18 rear
that's the exact setup I'm using right now and it works beautifully. It's a close fit but a perfect one none the less, no rubbing or any issues on stock sport suspension.
Tutankhamon is offline   Reply With Quote
Old 09-09-2005, 01:49 PM   #9
sna77
sna77's Avatar
My Ride: BMW
If it fits the stock sport suspension, i should be OK with non-sport suspension, since its actually higher, right?
Old 09-09-2005, 03:57 PM   #10
whiteNgold
My Ride: 2002 325ci
That'll be fine. If they were my wheels, I would but 235's in the front. It'll give your front tires some meat and help protect your rims if you do curb them a little.
Old 09-10-2005, 02:48 AM   #11
thebighash
My Ride: Z4MC / Sold
OEM BMW setup:
225/40/18 front
255/35/18 rear
Tire Rack setup also makes sense & i'm using it now
225/40/18 front
245/35/18 rear
No rubbing or other issues in both cases.. but i suggest get sports suspension or lowering kit (Eibach, H&R, UUC..) when installing 18s
2007 Imola Red Z4MC / Sold
thebighash is offline   Reply With Quote
Old 09-17-2005, 09:10 PM   #12
sna77
sna77's Avatar
My Ride: BMW
Originally Posted by thebighash
OEM BMW setup:
225/40/18 front
255/35/18 rear
225/40/18 front
245/35/18 rear
What will a sports suspension run me?
Old 09-17-2005, 09:15 PM   #13
sna77
sna77's Avatar
My Ride: BMW
OEM BMW setup:
225/40/18 front
255/35/18 rear
225/40/18 front
245/35/18 rear
Whats the advantage of the 255 or 245s in the rear ? Why did you go with the 245?
Old 09-17-2005, 11:43 PM   #14
thebighash
245 would be better if you have more aggressive rim offsets and you worry about rubbing.. and in case you got 8" rear rims were 245 fits better.
but in your case (with OEMs) it doesn't matter
i'm sure other fanatics who upgrade to cup kits, coils.. are willing to sell their stock sports suspension check'em up
