#1 |
Daytime Running Lights
Does anyone know if low voltage/watt white lights are available for the daytime running lights.
I dont like the yellowish hue lights that are OEM on the car. Actually saw a coupe today with white daytime running lights that looked sweet.
03' 325i Sapphire Black/Natural Brown- Xenon's
35% Llumar Tints |
#2 |
No halogen bulbs are white enough to match the Xenon.
#3 |
(oOO \ (||||)(||||) / OOo)
My Ride: 03 E46 JB, 08 MBE350
He's talking his daylight running lights on how he can increased his bulb light output from yellow to white and not to match his xenon lights.
#4 |
_
Can't you just replace the H7 bulbs with like SPP super whites? That's about the whitest look you're going to get.
#5 | |
I was doing a search on the forum and someone made a good point...this bulb is also used for the High Beam (flashing). So whatever bulb is used has to support enought high voltage for the high beams, as well as run on lower voltage while being used as DRL's. I am not looking to match the xenon's, I just want to get rid of the ugly yellowish hue of the DRL's. I cant believe no one's done this yet?!?! I'm actually quite surprised at how many people want their DRL's turned off. Personally, I've always found the look of the DRL's to be very cool. Makes the car look more aggressive....don't you think??
35% Llumar Tints |
#6 | |
DK Jack Sparrow
My Ride: 328Ci | Range Rover
![]() Everything you need to know on muffler deletes : http://forum.e46fanatics.com/showthread.php?t=745244 Back Up Camera for E46 : http://www.youtube.com/watch?feature...&v=ckrDiAClGgM Muffler Delete on E46 : https://www.youtube.com/watch?v=ofYhRq0T3eI ![]() |
#7 | |
How much?? How easy is it to install these bulbs??
35% Llumar Tints |
#8 |
any light at a lower wattage will be much less whiter than what you want. Don't think this can be done with a simple bulb switch. I like the look too, its not that bad. But I like angel eyes better, so no drls i guess
#9 | |
#10 |
I'm running Silverstars but they don't look that different than the stock GE's at DRL voltage. They are a bit whiter at full voltage.
Daytime Running Lights are there for safety not looks. Your vehicle is more noticable to others in traffic so you are less likely to get hit by someone talking on the cell phone for example. I'm not thrilled with how DRL look with my DDE's but I'm certainly not turning them off. It would be like turning off my brake lights because I didn't like the way they looked. There's a limit to what I'm willing to do for esthetics and that limit is reached when safety is an issue. Just my 0.02.
#11 |
I asked BMW service here in Hong Kong to turn on DRL but they can't seem to find the code, maybe due to the fact that all cars here don't have DRL. My car is 2003 M3 does anyone know the code that they use to activate DRL so that I can inform service?? Thanks
#12 | |
I have DRLs also, and I enjoy being seen, especially at dusk since I have a black car. Im sure any blue coated bulbs will make the DRL appear whiter or bluer, depending on coating.
E92 335i 6spd
BMS JB4 stg 3, BMS DCI, CM methanol injection 04 M3 sold 03 330Ci sold |
#13 |
sorry to thread jack, but anyone know a DIY for having dde's go on instead of drl? i basically want the ddes to be on by themselves without the yellow tinge of nasty drl! for projector 46 headlights to be specific. sorry again.
Hold the person that you love closely if they're next to you
The one you love, not the person that'll simply have sex with you Appreciate them to the fullest extent, and then beyond 'Cause you never really know what you got, until it's gone.~Technique |
#14 |
I was wondering if this was possible to do as well. Turns out it's not that easy.
Few days ago I installed the SPP Superwhites as my DRL/Highbeam bulb, and it still gave off a yellow hue at DRL wattage. I'm not really sure what your best bet is. |
#15 |
anyone?
#16 |
leave ur xenons on all the time...
