Rear spring DIY - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Old 11-04-2016, 01:11 PM   #1
lingon300k
My Ride: 2005 325xi Automatic
Rear spring DIY
I made a quick DIY for replacing the rear springs.
The formatting here is a bit difficult to read, and annoying to work with, so I've posted it on my own site. Sorry if it's ugly. It's brand new and I haven't worked out the format or design of the site yet.
E46 Rear Spring DIY
lingon300k is offline   Reply With Quote
Old 11-04-2016, 02:26 PM   #2
Spannerhead
Save the Manuals!
Spannerhead's Avatar
My Ride: '02 330i/5 slicktop
Thanks for the DIY! Many will be helped by this.
I should note that due to the "Mango effect" around here, there will be folks who will look suspiciously at an off-site DIY.
Current: '02 330i/5 '10 Mazda5 '72 240Z
Past: '85 GSL-SE '95 540i/6 '95 525i/5 '86 635CSi/5 '88 JZA70 '86 4K quattro '85 RX-7 S
Spannerhead is offline   Reply With Quote
Old 11-04-2016, 02:54 PM   #3
das_autobahn
My Ride: 2004 330ci coupe
lol ^^^^^
das_autobahn is offline   Reply With Quote
Old 11-04-2016, 05:38 PM   #4
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: Project 330xi
The torque for the shock to trailing arm is 74 ft-lbs.
-Gary
DiscoStu is offline   Reply With Quote
Old 11-04-2016, 09:27 PM   #5
lingon300k
Thanks! I thought about the Mango effect before I did it, actually--so I laughed pretty hard when I read that! I'm actually planning to rewrite the other DIY for that site as well.
Thanks for the info! Do you have a source I could reference in the DIY?
Old 11-04-2016, 09:43 PM   #6
Nicker
My Ride: 323ci
This is right... 100Nm=~74 ft/lb (74*1.3556)
according to this doc: http://www.argyrides.eu/bmw/mods/sus...que_values.pdf
00' 323ci - 170hp
Nicker is offline   Reply With Quote
Old 11-04-2016, 09:46 PM   #7
lingon300k
Thanks! I'll post the info in the next few minutes.
Old 11-04-2016, 10:49 PM   #8
Jason325xi
My Ride: 2004 325xi 5speed
Great diy Lingon! I noticed all the leaves on the ground in the pics. I hate leaves lol when i did my rtabs last week i swept away all the leaves and with the wind i was sifting through leaves looking for tools fifteen minutes in
Adjustable koni yellow front struts, Rob43 9-way adjustable rear shocks, Special Rob43 lowering springs, supreme power drop hats, billet aluminum rear shock mounts, poly RTAB, G.A.S. Disa kit, G.A.S. 1.2bar expansion tank cap
I run 6010 overhead in a t-shirt!
Jason325xi is offline   Reply With Quote
Old 11-05-2016, 02:01 AM   #9
BiH55
My Ride: 2001 bmw 325i
Just don't do this with taller springs
BiH55 is offline   Reply With Quote
Old 11-05-2016, 08:29 AM   #10
lingon300k
Thanks! I was waiting for someone to mention the leaves. It was actually raining a little bit, too. I had been working in the garage for days, and I didn't want to be inside anymore if I didn't absolutely have to be. My tools were on a cart, though. Luckily, it wasn't very windy.
Not quite sure what you mean. The car is an xi. What taller springs might you be referring to?
Old 11-06-2016, 01:34 AM   #11
BiH55
I installed some aftermarket lowering springs, they were much taller
Old 11-06-2016, 12:57 PM   #12
lingon300k
I'm still not sure that I understand what you're saying. Your lowering spring would have been shorter than the stock height xi spring I installed.
If you're saying you had difficulty installing them, then maybe I get your point. You have to seriously extend the control arm to get the new spring in. It's a bit difficult, and you need to have the jack in the correct place so that you can insert the spring at the correct angle. Even still, you might need to bang it into place with your hand.
Old 11-06-2016, 01:25 PM   #13
BKMrSteel
My Ride: 99 328i
Rear spring DIY
It helps if you use a pry bar to push on the control arm. Just enough to get the springs in or out.
It's good to add if one side is connected, the sway bar will be fighting you. Get both springs in first.
<a href=http://forum.e46fanatics.com/showthread.php?t=1094528 target=_blank>http://forum.e46fanatics.com/showthread.php?t=1094528
</a>
BKMrSteel is offline   Reply With Quote
Old 11-07-2016, 01:54 PM   #14
lingon300k
Thanks for the note! I didn't consider the sway-bar before you mentioned it.
I'm probably going to update the DIY to advise doing both springs at the same time, instead of one after the other.
Old 11-07-2016, 02:18 PM   #15
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
Nice DIY. E39Source on YouTube also has a pretty good video on this
>IN SEARCH OF GRAY SEDAN SPORT SEATS<
lllRazorlll is offline   Reply With Quote
Old 11-07-2016, 07:48 PM   #16
lingon300k
Thanks! I'll take a look at that video to see if there's anything I should note in my DIY.
Old 11-08-2016, 08:38 AM   #17
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
Good job on the DIY. I use a bottle jack to pry the beavertail open to remove the spring. It holds the tail down and I can use two hands to lift out the spring. Makes installation easy too as both hands are free. I disconnect the sway bar links first.
The bottom of the jack is on the hub knuckle (where the beavertail connects) and I use a hockey puck between the body underside and the top of the jack.
Pries it open great and takes minutes to pop in new pads and springs. I coat the pads with a little grease to make spring adjustment (turning) easy, then release the jack pressure. reconnect the sway bar link and done.
BMW-North is offline   Reply With Quote
Old 11-08-2016, 12:29 PM   #18
lingon300k
Thanks! I used the spare tire jack because I wanted to make it as simple as possible, using an "extra" tool that everyone has in their car. A lot of the DIYs have said this is likely a two person job, because someone has to pry the control arm down while the other pulls the spring out or pushes it in. By using the spare tire jack, which is a lot like the method you described, it's easily done by one person.
I like the hockey puck idea. I probably would have done something similar with the base of the jack on the control arm if I'd had one. Another reason I like the spare tire jack for this is the plastic on the top of the jack where it goes against the body of the car.
I've edited the post to recommend doing both sides at once. Thanks again, BKMrSteel!
