Thread Tools Search this Thread Rating: Thread Rating: 3860 votes, 5.00 average. Display Modes
Old 04-03-2006, 03:32 PM   #21
Custom3
My Ride: HellRot 330CI
at what milage should the post-cat be changed?? I change my pre-cat at 50k...great diy by the why
Old 04-03-2006, 03:37 PM   #22
Ivegotissues666
My Ride: 88' BMW E30 SETA
Send a message via AIM to Ivegotissues666
Same things for Post O2's 100k
And Thanks
Ivegotissues666 is offline   Reply With Quote
Old 08-11-2006, 12:21 PM   #23
Hash328i
My Ride: 00 328i w/ red leath
I just replaced my rears yesterday. This guide was helpful but I would like to add 1 thing.
When pulling out the old rear ones, I tied a string to the end on the top side, so when I needed to route the new sensors wire back to the top, I just tied it to the string and pulled.
Hash328i is offline   Reply With Quote
Old 07-21-2007, 01:10 AM   #24
vids_blk323Ci
DFW
My Ride: JB 323Ci SP PP
Send a message via AIM to vids_blk323Ci
excellent diy write up. what a PIA though! btw, i found the post cat o2 (lambda) sensors on realoem.com but cant find the pre-cat senors, ne1 have the part numbers for those?
Post cat:
just found the write up for the pre-cats, thought i would cross-link: http://forum.e46fanatics.com/showthr...=o2+sensor+diy
Dinan Stage I S/W | ACS RSB | ///M FSB |UUC TMEs & Pulleys |Ate Slotted Discs | ScanGuageII | RockyMounts MTB Carrrier | OEM Rear Clears | LED Euro City Lights & Rear Fogs | Two-Tone Suede DIY | ACS Pedals | Bimmian Gauge Rings & M3 Face | Smoked Frnt Corners w/ Luxeon LEDs | EAS CF Roundels | JLevi Ti CF trim | Blk Suede shift/ e-brake boots | ECS Smoked Frnt Bumper Reflectors | DICE Duo
vids_blk323Ci is offline   Reply With Quote
Old 10-16-2007, 08:47 PM   #25
dirsh
Hawaii 3.0
dirsh's Avatar
My Ride: sanbyaku sanjuu
nice DIY
I need to do this soon
Hello dirsh it appears that you have not posted on our forums in several weeks, why not take a few moments to ask a question, help provide a solution or just engage in a conversation with another member in any one of our forums?
dirsh is offline   Reply With Quote
Old 10-30-2007, 01:06 PM   #26
excitermode
My Ride: 320DSE (2000)
If I disconnect my pre-cat 02 sensors will this allow me to assess whether my power problems are due to a bad Cat? i.e. if my power problems are solved its the bad reading from the o2 sensors causing a poor air/fuel mix. Will disconnecting the pre-cat 02 sensors allow this?
excitermode is offline   Reply With Quote
Old 11-12-2007, 03:41 PM   #27
dirsh
Hawaii 3.0
dirsh's Avatar
bumpin to remind myself to change these
I think i'll do the precats first then post when im not as lazy
Old 04-14-2008, 09:13 PM   #28
myksbmw
My Ride: BMW 2003 325i
Great write up
myksbmw is offline   Reply With Quote
Old 05-08-2008, 10:21 AM   #29
tony325ci_51
My Ride: BMW 335i 2007 Coupe
Great write up, very useful but one thing missing.
Error codes refer to bank 1 or bank 2. As I understand it, bank 1 is cylinders 1-3, bank 2 is cylinders 4-6.
Although when you get into the job you can probably work it out (am I right assuming cyl 1 is at the front and cyl 6 at the back ?), it would be really useful if the sensors and connectors in the pictures had been labelled as to which was the bank 1 or bank 2 post-cat sensor and plug. If I get a bank 1 error (P0420 - cat bank 1 below efficiency actually, but the car's passed an emission test in the MOT so I suspect post-cat sensor at fault, not cat) I'd like to know which sensor to look at (so I know in advance whether it's the "easy" one or the "hard" one I'm looking at changing).
Can anyone help with that info ?
tony325ci_51 is offline   Reply With Quote
Old 05-19-2008, 12:50 PM   #30
tony325ci_51
Vexed !!!
Cheapest price I can find for OEM (post-cat sensors) Bosch part number 0258005109 in UK is: Bosch Direct Fit - (wires 4, cable length 990mm) 71.68 inc VAT & UK deliv. (= $139.55 USD !!!)
That's $80 more, for the same OEM Bosch part that I've seen advertised in the US for $58-$60 !!!
http://www.lambdasensor.com/main/bos...tem=0258005109
http://www.rockauto.com/catalog/rafr...1433864k279826
http://www.autohausaz.com/search/pro...xygen%20Sensor
Can anyone recommend a supplier who will supply at similar prices and ship to UK at a reasonable price ? I'm gonna have to check around the web further too I think.
Old 05-20-2008, 08:50 AM   #31
Cheezemurda
My Ride: 2002 330ci
I got mine from KO Performance. 55 bucks each!
Cheezemurda is offline   Reply With Quote
Old 05-20-2008, 11:22 AM   #32
markovnikov5
My Ride: E46 323i
guys, my car is giving faults:
-AfterCat oxygen sensor short to B+, Cyl #4-6
Peake Research code: 15 9F...I keep getting this code
-AfterCat oxygen sensor disconnection, Cyl #4-6
Peake Research code: 15 D8...I only had this code once
So I am only going to replace the one post-cat O2 sensor, not both.
Is that OK? Or is there some reason I am unaware of that I should do both?
Also Im not sure which sensor is for cyl #1-3 and cyl #4-6. Does anyone know?
Any other advice is appreciated
Thanks for the help!!!!
markovnikov5 is offline   Reply With Quote
Old 05-20-2008, 11:24 AM   #33
tony325ci_51
Realoem gives me a part number 11781433940, which is $151 from KO.
Even if they'd ship internationally there's no savings to be had for me there.
Old 05-26-2008, 09:57 AM   #34
markovnikov5
My Ride: E46 323i
Anyone?
Which POST CAT sensor is for cyl #4-6??
Old 05-27-2008, 07:30 AM   #35
tony325ci_51
Superb write up, excellent thread. I thought I'd add a how-to for the other part of the job, if you're changing your sensors you've probably got a fault light which needs clearing. Here's how:
http://forum.e46fanatics.com/showthread.php?t=576850
Old 06-02-2008, 07:01 PM   #36
tony325ci_51
Anyone?
Summer must be here, we had a warm day on Sunday so I got outside under the car and did an oil change.
While I was under there I thought I'd trace the exhaust pipes, finally take some pics and answer this question.
Both post-cat sensors are easy to reach but the Bank 2 sensor (cyl 4-6) will be more fiddly to undo, as the 22mm "sensor socket" (with a slot in it, picture attached) will have to be turned and repositioned just like with a normal spanner. Due to the wires you can't just undo it with a rachet. An open-ended 22mm spanner will be fine for Bank 1 (cyl 1-3) sensor (You couldn't use a "sensor socket" on this, there isn't enough clearance to get a rachet on it.).
(You won't have the advantage of being able to see the view in the 2nd picture. This was taken by holding a small camera in the gap up above the exhaust).
Photos include details of post-cat sensors, and the tools required to replace each:
ID:	273395   Click image for larger version
ID:	273396   Click image for larger version
Old 06-03-2008, 11:10 AM   #37
2001black330ci
My Ride: 2001 330CI
For anyone wanting to download or print this DIY, I made a nice setup for a friend, and figured someone might be interested in this.
Screen shot :
DIY (PDF)
http://www.mediafire.com/?wbehdbbf3px
2001black330ci is offline   Reply With Quote
Old 06-03-2008, 11:30 AM   #38
sdbimmer
My Ride: 2004 325Ci
For reference:
sdbimmer is offline   Reply With Quote
Old 06-03-2008, 12:25 PM   #39
markovnikov5
My Ride: E46 323i
wow thanks tony, thats great information, just what I needed. thanks to sdbimmer also
Old 06-26-2008, 10:43 PM   #40
hoseb'sm3
My Ride: 2001 325xi wagon
Hey Tony, I have the exact same error on my 03 M3 saying htat efficiency for bank 1 is below threshold. Did you fix your problem and did the light go off? I was just wondering if you could help me out because I'd like to do it myself. Was it a post-cat sensor and did you just have to replace one? Any help would be appreciated. Thanks.
hoseb'sm3 is offline   Reply With Quote
