Sponsored by The Tire Rack
Old 09-18-2005, 05:33 PM   #21
guest1016
fanatical
My Ride: .
Send a message via AIM to guest1016
Originally Posted by Idrivea328I
I believe the rear offset is 45mm on the staggered setup. It should still be noticebly staggered because 5mm is only 1/2 a centimeter, which is noticeably less than one inch.
Basically, indeed the dish will be less with the 5mm offset increase, but it will still be more agressive looking than the front rim, since 5mm < 1 inch. They make the rear offset 45mm since a 9.5 width rim will rub with a 40mm offset.
Specs:
Size: 18x8.5 front, 18x9.5 rear
Bolt Pattern: 5x120
Offset: +40mm
Center Bore: 72.60
if they did infact change the rears to a 45 this would make sense the the rim is closer on the inside towards the suspension because that extra 5mm will be on that side now, vs. towards your 1/4 panel....i read in another post somewhere that the guy lighty tapped it in with a hammer for clearance...you may have to do this (as might i )
guest1016 is offline   Reply With Quote
Old 09-18-2005, 06:19 PM   #22
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: 335i
Yeah, with the extra 5mm there would definelty be enough room for a tire. I'm going to call velocity motoring first thing tomorrow and see what the deal is. I'll post the results immediately.
-Gary
DiscoStu is offline   Reply With Quote
Old 09-18-2005, 07:59 PM   #23
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
straight from their website:
Straight | Angled
VB3
Bolt Pattern
5x120mm
Center Bore
72.6mm
Available Sizes
18x8.5" / +40mm / Silver
18x9.5" / +40mm / Silver
18x9.5" / +22mm / Silver
19x8.5" / +40mm / Silver
19x9.5" / +45mm / Silver
19x9.5" / +22mm / Silver
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 09-18-2005, 08:00 PM   #24
Activ3
Offset is +45mm for the rear 9.5 on 19"s, but 40 for the 18"s
Old 09-18-2005, 08:27 PM   #25
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: 335i
That's why I'm worried, i've got an 18x9.5 with a 45mm offset.
-Gary
Old 09-18-2005, 09:10 PM   #26
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: 335i
Here is a picture of the label on the box:
-Gary
Old 09-18-2005, 09:20 PM   #27
Activ3
ooooooooooooo... I thought you were worried because you had +40mm in the rear. You will 100% perfectly fine with 18x9.5 and +45mm... With +40 you would rub on your 1/4 panel, with 45 you'll be oki doki
Old 09-18-2005, 09:22 PM   #28
Activ3
Oh, and with the +45mm rear offset, you'll still have the dish look, going back to what I previously posted, 5mm < 1 inch. You're wheels are perfectly fit bro, go slap them on and post some pics!
Old 09-18-2005, 09:22 PM   #29
LakeShow
Millennium Bankers Mortgage
LakeShow's Avatar
My Ride: is almost finished!
Send a message via AIM to LakeShow Send a message via Yahoo to LakeShow
The 45mm offset will help you bro! Slap those puppies on already!
Supporting Sponsors:
* DPE * Euro-Spec * Technik * WestCoast Auto Sound *
LakeShow is offline   Reply With Quote
Old 09-18-2005, 09:23 PM   #30
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: 335i
Yeah but now im worried about my rim hitting the inside. Ill see if i can put the csl wheel on and then put a ruler up to it to show you just how little space im taking about.
-Gary
Old 09-18-2005, 09:25 PM   #31
Activ3
You won't rub on the inside. I know people with 10" wide rear wheels running 265/30/19 and a HIGHER offset than you with SEDANS that are clearing okay. Quick example: bluecougar
Old 09-18-2005, 09:28 PM   #32
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: 335i
That's also a 20" rim, this is an 18 and because of that size it looks like it might hit. Its hard to explain, im going to try and get a picture tomorrow.
-Gary
Old 09-18-2005, 09:38 PM   #33
Activ3
lol I understand what you're saying man. But before she got 20's, she had DPE 19's, 8.5 front, 10" rear. Also, the hamman PG2 rims are 45mm offset in the rear and they are 9.5 width as well.
Old 09-19-2005, 11:24 AM   #34
guest1016
fanatical
My Ride: .
there are quite a few people on here with the csl reps, and they are all listed as being +40 front and rear, and most run a 255/35/18 out back with no issues. if you have a little bit higher offset, (have you actually looked at the rim stampings, maybe the post on the box is missprinted) you should still be ok. remember the coupes have slightly larger wheel well openings than due the sedans (i found this out when i received the wrong mtech sideskirts) just get them mounted up and drive to pittsburgh immediatley so i can see them!!
Old 09-19-2005, 01:38 PM   #35
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: 335i
^ good point. I'm going to go take a picture of what i'm talking about so I can get everyone's input. I did check the inside of the wheel and on one of the spokes it says "45" dont know if this is the offset or not. The back tires just got delivery to my house about 30 minutes ago, im getting so excited to finally get these wheels on.
-Gary
Old 09-19-2005, 03:12 PM   #36
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: 335i
Well after another test fit and further inspection i think im going to be fine. I was just alittle worried because it seems i'm the only person around that has the 45mm offset in the back on csl wheels. Even mike@modbargains was unsure about it. So yeah, this is me:
ME =
-Gary
Old 09-19-2005, 03:43 PM   #37
Staszek
Are we there yet??
Staszek's Avatar
My Ride: Now a daily drive
Send a message via AIM to Staszek
If it really is the 45offset you are better off. I would call Velocity
I know my 19's are 45 THANK GOD or I would have never fit the 265s on it
Originally Posted by Rob Levinson * UUC Motorwerks View Post
What if leprechauns installed them while unicorns watched? :D - Rob
Staszek is offline   Reply With Quote
