Sponsored by The Tire Rack
Old 09-15-2005, 11:48 PM   #1
Babskie330
My Ride: BMW330 CI Titan Silv
Rubbing Issues on front inner rim
Gary...I bought Breyton Spirit 19x9 and 19x9.5. I just had my car slammed with FK coilover suspension and everytime I turn, the inside part of the rim is rubbing on the suspension. Do you know if you've encountered this problem on any customer's set-up? Do i need to switch to 19x8.5 in the front to avoid this issue? Thanks!
Babskie330 is offline   Reply With Quote
Old 09-16-2005, 08:09 AM   #2
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Yes, this is a very aggressive setup, so the rubbing is not too surprising. Unfortunately Breyton does not make the Spirit in an E46 fitment in any less aggressive sizes like 19X8.5". You may need to look into running a small spacer up front to help with the suspension rubbing, but this will push the wheel closer to the fenders so you may need to do some fender work as well.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
