Sponsored by The Tire Rack
Old 09-15-2005, 11:18 PM   #1
kimluk
My Ride: 328i
Gary, questions for wheels and suspension
Gary, I have 1999 328i w/o sport package. I would like to upgrade both the wheels and suspension. I am not going to track or race the car. It is my daily driver. I would like to match the look and the ride performance of the 330i's sport package. I am going to upgrade to M68 wheels; 17x7.5 with 225/45 in the front and 17x8.5 with 245/40 in the rear. I am thinking to go with Dinan Stage 1 or Stage 2 upgrade. Can you recommend any other setup? If any one of you have this or similar setup, please give me your opinion. Thanks.
kimluk is offline   Reply With Quote
Old 09-16-2005, 07:19 AM   #2
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
Although I'm not familiar with Dinan products, a common setup to get you in the league of (or slightly beyond) the 330 sport suspension, I'd suggest looking into a setup with Koni sport adjustables and either H&R or Eibach springs for a good compromise between ride and handling.
http://www.tirerack.com/a.jsp?a=BN4&...sion/index.jsp
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
Old 09-16-2005, 08:55 AM   #3
TwoE46s
My Ride: Dinan 330ci & 325it
I really like my Dinan Stage 2 - a solid ride, that doesn't beat you or your car to death on the street, and is a nice improvement on the track as well. As you probably know, the shocks are Koni's, and I think the either H&R or Eibach make the Dinan springs and bars to Dinan's specs.
I'm also a fan of 17s over 18s or above, although 18s do look nice. You may also want to consider 17x8s with a 38 or 40 offset, and 235/40s all around. That's my track set up, and I think it looks really good as well - with that offset the rear tires actually sit out further in the rear wheel wells than the factory 17x8 1/2s with 245/40s - even the 225/45s on my wagon sit futher out in the rear wheel wells. The only problem you may run into is a lack of choices in that tire size.
TwoE46s
01-Dinan3/330ci (sold); 03-325it; 07-E92/328; 06-Cayman S
Wagon:
17X8 BBS RXs & 225/45 Toyo Proxes 4s
Coupe:(sold)
Dinan "S" plus Throttle Body & Stg 3 Software
Dinan Stage 2 Suspension
UUC Shifter
UUC Underdrive Pulleys
Goodridge Braided Brake Lines
Michelin Pilot Sport PS2s on factory M Double Spoke 68s
Track Stuff - 17X8 OZ SuperLeggeras & 235/40 Toyo RA1s; Shroth Harnesses
TwoE46s is offline   Reply With Quote
