Old 09-17-2005, 10:19 PM   #1
ADA
Banned
My Ride: 323ci
EVAP capillary leak (0.5mm) detected
Guys,
This problem been bothering lately.
The check engine light does not come on. I can only pick it up when scanning with my Peake's Tool.
I already changed my fuel filter, fuel pressure regulator, and the fuel hose around the fuel filter/fuel pressure regulator.
Additionally, I also changed my gas cap.
No matter what I do I keep on getting this error code. I know .5mm isn;t much but now it is driving me crazy.
Prior to the problem, each time I open the gas cap fill my car at the gas station I will always here a "gushing/vacum/pressure" sound. However, ever since I have the "EVAP capillary leak (0.5mm) detected" error I no longer hear that "gushing/vacum/pressure" sound from my gas tank.
Any ideas?
ADA is offline   Reply With Quote
Old 12-20-2005, 09:08 AM   #2
greatx
My Ride: 2007 328xi
I am having the same error (also with the Peake tool). But I also have the error 41 (Camshaft sensor - intake cam).
Could you figure out what is wrong??
greatx is offline   Reply With Quote
Old 12-20-2005, 08:16 PM   #3
Surk
My Ride: C Blk E46///M3
I had this same prob in summer, and dealer replaced the evap canister valve in rear that syphons fuel between the tanks.. apparently it's common to replace these once in a E46 lifespan..
Surk is offline   Reply With Quote
Old 12-20-2005, 09:09 PM   #4
ADA
Banned
My Ride: 323ci
Maybe this is why.
Prior to this problem: My gas tank would always have the glushing sound (ie...opening a soda bottle) when I am at the gas station filling my car up
After the problem: No matter how low my gas level is I will never hear the gushing sound.
My dealers thought my gas cap was not tighten. That was false. I got so upset that I replaced my gas cap with a brand new one. However, that didn't fix the problem either.
I will tell my dealer evap cansister valve thingy though. Thanks!!!
Old 12-21-2005, 12:35 AM   #5
ADA
Banned
My Ride: 323ci
Hello....do you still have your service record. If so, can you PLEASE PLEASE post the parts number. Numerous people on here will appreciate your input.
Hope to hear from you soon
Old 12-22-2005, 10:49 AM   #6
Surk
I'll look for it and post the p\n..hopefully it helps others out as cause\fix..
Old 12-22-2005, 03:48 PM   #7
jaymar88
My Ride: Acura
I second that. I'm pulling two code, both referring to the air pump.
I'd like to see what the service sheet said.
jaymar88 is offline   Reply With Quote
Old 12-22-2005, 07:17 PM   #8
ADA
Banned
My Ride: 323ci
please do! thank you
Old 12-22-2005, 08:50 PM   #9
Tom Busby
My Ride: 2001 325i, 1995 318i
Check the solenoid valve that is on the passenger side rear of the car, on the underneath, behind a black plastic cover. Remove the plastic cover and then unhook the little solenoid (looks like an inductor coil of copper wire with a valve on the other side -- about 1 1/2" long and as big as a quarter around) and then pop the cover off the solenoid, re-grease the rubber seals front and back, and put it back together. The rubber seals and the solenoid are made a lot better than they need to be so don't replace the part. Just refresh the seals with some fresh dilectric grease (which is merely a high quality vasoline grease).
Tom Busby is offline   Reply With Quote
Old 01-08-2006, 01:45 PM   #10
ADA
Banned
My Ride: 323ci
UPDATE: Went to the dealer last week. they did a leak test and couldnt find/detect anything. they charged me $35 for it.
So far the leak (error code) hasn't come back yet.
Old 01-09-2006, 01:43 PM   #11
MarvelPhx
www.my330i.com
My Ride: E92335i,04ZHP,99M3
Send a message via AIM to MarvelPhx
The car does this evap test every other time you drive the car basically. It runs a small pump that pushes air through a .5mm orifice into the evaporative fuel system. It then measures the load the pump encounters and checks it to see if, once it reaches a peak, if it must keep pumping. This shows a leak.
The leak could be anywhere in the evap system, but I would check valves, hoses, and the canister itself.
MarvelPhx is offline   Reply With Quote
Old 01-16-2006, 10:45 PM   #12
ADA
Banned
My Ride: 323ci
Error code came back. The dealers order some part for the replacement. I can't remember what he said. However, when I get my car fix (later this week. thursday or Friday) I will post the total price, part number, item discription, and whether or not it is covered under CPO warranty.
P.S. Please remind me to update if I forget. Lots of people on e46 post questions to their problem but are too busy to post updates so that other members can learn from their experience.
Old 05-03-2006, 07:46 AM   #13
E46Marine
My Ride: 99 323I
Hey ADA, you were supposes to post the results after the dealer fix your evap leak. Please post.
E46Marine is offline   Reply With Quote
Old 05-03-2006, 09:25 AM   #14
cimbali
My Ride: 323i
This post is on the money for me! Looking foward to ADA's reply. I am bringing my car to the dealer to address this same problem!
cimbali is offline   Reply With Quote
Old 05-06-2006, 09:13 AM   #15
ADA
Banned
My Ride: 323ci
busy but will post update ASAP
Old 05-06-2006, 11:20 AM   #16
ADA
Banned
My Ride: 323ci
it was the evap canister
Old 08-03-2007, 03:48 PM   #17
celsoglima
My Ride: 2001 330i
Does anybody know the part number of this "evap canister" or another name used for it? Could not find it on realoem.com.
celsoglima is offline   Reply With Quote
Old 08-03-2007, 10:24 PM   #18
cimbali
My Ride: 323i
For my car it would be 16131183893...but check out realoem.com to confirm
