Sponsored by The Tire Rack
Old 09-14-2005, 09:45 PM   #1
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: Project 330xi
Question Question about my CSL replicas?
Well ive had these wheels sititng around for awhile and i've finally got some tires on the way. The are the staggered 18x8.5 and 18x9.5. The tires will be some nice 235 up front and 255 in the back. For some reason i went to look at the box the wheels were in. The 18x8.5 box says the offset is 40mm, which is right. Now the box for the 18x9.5 box says 45mm offset. Is this right? I just want to make sure i've got the right wheels before i pay to have some tires mounted. I'm a wheel/tire dummy.
-Gary
DiscoStu is offline   Reply With Quote
Old 09-14-2005, 09:49 PM   #2
jsedlak
My Ride: 2002 325i
Send a message via AIM to jsedlak Send a message via MSN to jsedlak
[ - Thread Jack - ]
Staggered?
Offset?
[ - /Thread Jack - ]
jsedlak is offline   Reply With Quote
Old 09-14-2005, 09:51 PM   #3
LakeShow
Millennium Bankers Mortgage
LakeShow's Avatar
My Ride: is almost finished!
Send a message via AIM to LakeShow Send a message via Yahoo to LakeShow
Thats perfect bro. You want the higher offset in the rear...if you had 40mm in the rear, you would most likely rub. Dont worry Post pics when you get them on
Supporting Sponsors:
* DPE * Euro-Spec * Technik * WestCoast Auto Sound *
LakeShow is offline   Reply With Quote
Old 09-14-2005, 09:53 PM   #4
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
Awesome man. I really appreciate the reassurance. I'm already worried about going 255 in the rear..
-Gary
Old 09-14-2005, 09:56 PM   #5
LakeShow
LakeShow's Avatar
I think with the 45mm offset and the 9.5 rear and 255 tire (255/30/18?), you wont have to worry about rubbing on stock suspension. If you drop it in the future, I think all it needs is a good fender roll and you are good to go man!
Old 09-14-2005, 10:01 PM   #6
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
255/35/18 actually. Thats good to hear. I do plan to lower in the near future so i'll look out for that when it comes time.
-Gary
Old 09-14-2005, 11:06 PM   #7
MysticBlau330Ci
My Ride: 330Ci '04 & M4 2016
I have the 18inch staggered set too. Goodyear 225/40 front and 255/35 rear. I have the sports suspension which seems pretty darn low to me ( I can't get a descent jack under the car). ABSOLUTELY no rubbing. Have fun.
MysticBlau330Ci is offline   Reply With Quote
Old 09-14-2005, 11:53 PM   #8
unsp0ken
My Ride: is stock and slow
i thought 18" csl replicas had 40mm offset in the rear...
unsp0ken is offline   Reply With Quote
Old 09-15-2005, 09:22 AM   #9
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
Apparently the staggered csl replicas have a 45mm offset on the rear wheels.
-Gary
Old 09-15-2005, 09:58 AM   #10
guest1016
fanatical
My Ride: .
Send a message via AIM to guest1016
the ones from velocity were most cetainly 40 front and rear on the staggered, unless you got them from someplace else and are a diff. brand or the offset has been changed...
guest1016 is offline   Reply With Quote
Old 09-15-2005, 11:27 AM   #11
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
They came in big black velocity motoring boxes. And i ordered through modbargains. It looks like they changed their offset.
-Gary
Old 09-15-2005, 05:28 PM   #12
guest1016
fanatical
My Ride: .
interesting....maybe they did. i'm waiting on these wheels myself. only neg. would be the rear wouldn't have as deep a dish wiht a 45 as the would with a 40, and this deep dish on the rears is what makes the csl wheels look good imo...the non staggered look so plain..
Old 09-15-2005, 10:33 PM   #13
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
Really? Can someone please explain to me about the whole offset thing? Whats the difference between 40mm and 45mm and the difference between m3 and non-m3. Like i said i'm a wheel dummy.
-Gary
Old 09-15-2005, 10:38 PM   #14
LakeShow
LakeShow's Avatar
CSL'a dont have a lip? Would a 40mm and a 45mm matter when the spokes go all the way to the lip?
Old 09-16-2005, 11:01 AM   #15
guest1016
fanatical
My Ride: .
it would be noticeable sure. haven't you seen pics of the staggered csl rims....the spokes are dished much more in the rear because they are 1" wider, and use the same offset. increasing the offset will only lessen the dish on the spokes...
Old 09-16-2005, 11:57 AM   #16
2000_328CI
2000_328CI's Avatar
My Ride: 328Ci | Range Rover
All i know is that you will love your csls... i have the 19" staggered set up with 235 in front and 265 in the rear and absolutely love the way it looks... its flat out meannnnnn
Timeless Motor Group
Old 09-16-2005, 06:40 PM   #17
LakeShow
LakeShow's Avatar
Ah...I get it now bro
Old 09-17-2005, 05:06 PM   #18
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
Ok I just test fit the rear wheel and the inside of the wheel was about 1/4-1/2 inch from hitting the inside of my wheelwell, the side closes to the suspension. For those that are running the staggered setup now, or any other 18x9.5 rim, does this sound right?? It doesn't seem like there is much room for a tire.
-Gary
Old 09-17-2005, 08:23 PM   #19
Activ3
My Ride: gets DRIVEN.
Send a message via AIM to Activ3
I believe the rear offset is 45mm on the staggered setup. It should still be noticebly staggered because 5mm is only 1/2 a centimeter, which is noticeably less than one inch.
Basically, indeed the dish will be less with the 5mm offset increase, but it will still be more agressive looking than the front rim, since 5mm < 1 inch. They make the rear offset 45mm since a 9.5 width rim will rub with a 40mm offset.
-David www.e46nonm.com | My Videos
2000 328i - Custom Turbo tuned by AA
Activ3 is offline   Reply With Quote
Old 09-17-2005, 08:52 PM   #20
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My concern is the tire rubbing the inside, not the outside.
-Gary
