Old 10-22-2005, 09:26 PM   #1
ChrisMT79
Here
ChrisMT79's Avatar
My Ride: 2015 AW M3/5GT
Loose window. Need help
I read a few posts on how to tighten up the window. My drivers side window dosent completely slide in when you shut the door and seems a bit loose. I read some post on taking off the panel and tightening a screw. Anyone have any incite?
Chris
ChrisMT79 is offline   Reply With Quote
Old 10-22-2005, 09:40 PM   #2
///Mechanic
My Ride: None currently
More descriptive? Coupe? Sedan? Which way is it loose? What are you talking about it 'sliding in'?
YOU BOUGHT A BMW, IF YOU CANT AFFORD TO MAINTAIN IT............SELL IT.
///Mechanic is offline   Reply With Quote
Old 10-22-2005, 10:36 PM   #3
ChrisMT79
Here
ChrisMT79's Avatar
Well I have a couple 330ci. What I mean my loose is that when you wiggle the window its pretty loose. And when you shut the door the auto "seal" dosent slide in completely and leave a little gap. Does that make sense?
Let me know if it dosent and I can post some pics.
Chris
Old 10-23-2005, 12:30 AM   #4
///Mechanic
Your description is still kind of vague, but I do know what you are talking about. Post a picture of your window and door closed to show me how the window 'isnt' shut properly.
Old 10-23-2005, 01:01 AM   #5
ChrisMT79
Here
ChrisMT79's Avatar
Ok here are the pics..
The first one is of the window not sealing when closed... The other is of it sealed when I was out of the car pushing it in.. and the last is the "wiggle" the window has that the passenger side dose not have.
ID:	150447   Click image for larger version
ID:	150448   Click image for larger version
ID:	150449   Click image for larger version
Old 10-23-2005, 03:32 AM   #6
krazyvi3t
My Ride: 330
Its your weather strip and the seal happened to me my window wouldnt go all the way up, had to get it replaced my the dealer if your still under warranty just go ahead and have them replace
krazyvi3t is offline   Reply With Quote
Old 10-23-2005, 10:32 AM   #7
///Mechanic
Its hard to tell from the pictures. Are you talking about it not moving up all the way......are do you think the window isn't far enough back?
As far as the play in the window, pretty much all coupes/vert's have play in that direction.
Old 10-23-2005, 10:44 PM   #8
ChrisMT79
Here
ChrisMT79's Avatar
No.. the problem is down in the door panel itself. Trust me, the looseness is from it not being tight down in the door. You can see the play in the actual top of the door (not the window) its very loose. Its not the part I took a pic of, its the top of the door, with the window up you can see the play in the window. The passenger side is not like that. There has to be a way to tighten the window itself. Ill just take it apart and tighten everything when I get some time.
Old 10-24-2005, 08:07 PM   #9
xmltok
My Ride: 2014 Carrera 4S
Send a message via AIM to xmltok
there is an bolt in there you can tighten, you need an E7 socket to do it
if you do this, please take a picture of the rear socket (there is also one in the front), mine has a rattle that I could not fix by tightening
I recently had the door replaced and I think that they may have left out a rubber pad of some sort.
xmltok is offline   Reply With Quote
Old 10-25-2005, 12:50 AM   #10
ChrisMT79
Here
ChrisMT79's Avatar
No problem. Ill be doing this tomorrow night. Ill post the pics for you.
Thanks again
Chris
Old 10-25-2005, 12:56 AM   #11
ChrisMT79
Here
ChrisMT79's Avatar
BTW... is this bolt one of the ones on the side of the door or inside the door panel?
Chris
Old 10-25-2005, 06:02 PM   #12
///Mechanic
I am so confused.
Old 10-25-2005, 06:39 PM   #13
xmltok
The glass sits on two metal mounts. the mounts pinch on the glass via two bolts, one or both of his boths are probably loose.
Old 10-25-2005, 06:42 PM   #14
xmltok
this is inside the door panel, if you take off the huge foam covering you will see them, they are what hold the glass to the lifting mechanism, you will probably have to move the window up and down until you can access both bolts (i had to, make sure you reconnect the airbag before you hook the battery back up)
Old 10-25-2005, 06:53 PM   #15
///Mechanic
If all this guy is trying to say (in an unclear way) is that just the window is loose at the regulator, then DO NOT remove the door panel to tighten those screws! You are wasting your time and money (if you have to replace the vapor barrier). All you have to do is remove the outer door trim.......there are two access holes for these torx screws that hold the glass in place. Once you pop the molding safely off, all you need to do is bump the glass up or down so the bolt is centered in each hole.
Remember 2 things:
1. The threads are reverse on these bolts
2. Do NOT overtighten.......meaning do not crank down on the bolt. THE GLASS WILL BREAK
Old 10-25-2005, 07:03 PM   #16
xmltok
thats what im talking about, what outer door trim are you talking about?
Old 10-26-2005, 09:24 PM   #17
///Mechanic
The removable trim halfway down your door that runs horizontal.
Old 10-26-2005, 10:14 PM   #18
ChrisMT79
Here
ChrisMT79's Avatar
There are 3 hex screws there. Is that where you mean?
Old 10-27-2005, 12:53 AM   #19
ChrisMT79
Here
ChrisMT79's Avatar
Ok here are some pics..
The first is of the outside door panel,.. then the obvious door itself.. so do I just tighten the outside ones? Or actually take the panel off?
ID:	151104   Click image for larger version
Old 10-27-2005, 01:01 AM   #20
xmltok
you have to take the panel off, i dont see how you are supposed to access the bolts by any other method
