Thread Tools Search this Thread Rating: Thread Rating: 21 votes, 5.00 average. Display Modes
Old 06-17-2010, 07:58 PM   #21
mitchell172
My Ride: 2003 E46 325i
12-90-1-745-182 is the number on my fan that was removed. 2003 325i
mitchell172 is offline   Reply With Quote
Old 06-17-2010, 10:26 PM   #22
sharpx
My Ride: E46 330i
props for a great thread
sharpx is offline   Reply With Quote
Old 06-18-2010, 01:02 PM   #23
mitchell172
Looks like the list price for the part number on my fan is about $250. They look identical except for the wiring. I'm wondering if I can "engineer" it. Hmmmm
Old 07-25-2010, 02:43 PM   #24
achuang24
My Ride: 2003 325i
Here we go.. STEP 1: remove the plastic cover just above the pedals..
Can someone help me? I can't get this plastic cover off after I removed the screws and pins. It seems to be stuck where the cover joins the steering column. Does the cover slide toward you, away from you, or directly down?
achuang24 is offline   Reply With Quote
Old 07-26-2010, 03:29 AM   #25
vegito
My Ride: BMW 318i E46 2002
Thank you!!! cricket noise especialy cold start!..
vegito is offline   Reply With Quote
Old 07-26-2010, 07:22 AM   #26
vegito
There are 2 metal clips you must use a flat screwdriver to push the clip lift up than you can release the hole cover.
Old 07-26-2010, 08:45 AM   #27
325beemer
My Ride: 2001 325ci
WOW, this is so annoying in my car, to this day I thought the only solution was to turn up the music. Incredible thread!
325beemer is offline   Reply With Quote
Old 07-26-2010, 03:13 PM   #28
achuang24
My Ride: 2003 325i
Thanks vegito, that was it. I attached a picture of the clip.
After I got the cover off, I had to go back to the dealer to swap out the 12-90-7-570-074 (two prong) for 12-90-1-745-182 (three prong).
It appears in mid-2003 changed the part and the dealer's computer system did not note this change unless they are looking at the 2 door E46.
Old 07-27-2010, 12:55 PM   #29
vegito
This is a very good D.I.Y its very very annoying sound
Old 08-02-2010, 02:37 AM   #30
min24
My Ride: 2001 bmw 330ci
Is the part really approx $70? I'm searching for the blower and its like 200-300 dollars! Did the part number change?? or can someone post a direct link to buy this part online? Thanks!
min24 is offline   Reply With Quote
Old 08-02-2010, 03:38 AM   #31
joneperry
My Ride: e46 + S60 + Z
so tahts what it was!!!!!! mines comes on like 2 minutes for every hour?? can i just wait for like a couple of months or is it imperative that i change it whenever possible?
joneperry is offline   Reply With Quote
Old 08-18-2010, 11:32 AM   #32
OrientBlau
My Ride: 2003 330i
I've had this cricket sound for a couple of years.
I will have to add this to my DIY.
Thanks!
OrientBlau is offline   Reply With Quote
Old 08-18-2010, 07:26 PM   #33
delmarco
My Ride: 335xi Deep Sea Blue
Send a message via ICQ to delmarco Send a message via Yahoo to delmarco
my god! my car just started making this noise this morning. never heard it before. I actually thought a bee or bug of some sort got stuck in the vents.
WTF!
delmarco is offline   Reply With Quote
Old 10-09-2010, 05:13 PM   #34
Luky
My Ride: '08 335i RIP'03 330i
Just did it. Very easy DIY. Hardest part was getting the connector to snap back into place in the side of the fuse box under the hood.
Thanks!
Luky is offline   Reply With Quote
Old 10-13-2010, 09:16 AM   #35
eweis
My Ride: 1999 328i
How can you tell whether this cricket-type noise is from this "cover with blower" part behind the brake pedal being discussed here or it's coming from the blower motor discussed elsewhere (which is a much more expensive part and much harder to replace). I can't really pinpoint the source of that noise in my car.
I know...the right approach might be to replace this less expensive part first and then graduate up to replacing the other if it doesn't resolve it but I'm just wondering if there's a distinction in being able to tell one from the other.
Edit: I guess an easy way to figure this out is to disconnect the wire in the control box area for "cover with blower" part and see if the noise continues or not.
eweis is offline   Reply With Quote
Old 10-16-2010, 07:03 AM   #36
90 coupe
My Ride: 2004 325i
I need some assistance...I have a 2004 325i and I just got done changing the ECU cooling fan due to cricket noise. My question is, are your supposed to hear the fan go on and off when you are inside the car? The sound that I am referring to sounds the same way as if the A/C is on . What controls the ECU cooling fan? Is it supposed to go off and on?
90 coupe is offline   Reply With Quote
Old 10-17-2010, 01:59 AM   #37
Luky
I assume that it goes off and on (since the cricket noise was off and on). However mine is so quiet after I replaced it that I can't hear it running. I gently stuck my finger tip inside it to feel the spindle/blades turning to make sure it was working. Just pull the dash trim piece off and you can get your fingers up to it.
Old 10-17-2010, 07:17 AM   #38
90 coupe
My Ride: 2004 325i
Thank s for the info, I only hear the ECU cooling fan running when I dont have the radio on and the A/C is off and when the car is at a full stop. Besides that everything is fine. I did E mail the Dealer and asked them if it was normal. Maybe I got a bad cooling fan.
Old 10-17-2010, 02:12 PM   #39
90 coupe
My Ride: 2004 325i
Does anybody know what makes the fan turn on? I know it is not on all the time. Is there a circuit board that tells it when to turn on?
Old 11-02-2010, 11:15 PM   #40
eso123
My Ride: 2003 330xi
"How can you tell whether this cricket-type noise is from this "cover with blower" part behind the brake pedal being discussed here or it's coming from the blower motor discussed elsewhere (which is a much more expensive part and much harder to replace). I can't really pinpoint the source of that noise in my car."
To test which fan is making the noise, when you're hearing the noise, put the fan speed on your climate controls to zero, which will turn off the climate control-heater blower motor, and also power off the climate control display. If the noise slows and stops, that's the one- the main blower.
If the noise doesn't stop, it's the little one. The cricket noise comes and goes even when the climate control is off. It also can run when the whole ignition switch is off.
The cricket noise in mine, from the little fan, sounds like its behind the instrument cluster. The climate control-heater blower motor noise comes from more like inside the center console.
eso123 is offline   Reply With Quote
buzzing, cluster, cricket, noise
