Old 10-04-2005, 04:37 AM   #1
Oshin02
My Ride: turbo E46/M3/MCoupe
Send a message via AIM to Oshin02
Auto Trans. Limit
I've heard a lot of draw backs that the step/auto equipped e46's have with major power upgrades. For example, there is no stage 2 SC kit for them due to the tranny not being able to withstand all that extra power......What is it really that can't withstand the power in the trans.? Is it the gears, the torque converter, etc.. Also, is there a way to correct this weakness in step/auto transmissions without swaping on over to a manual? Thanks!
I am, CARBON MAN.....
Oshin02 is offline   Reply With Quote
Old 10-04-2005, 04:39 AM   #2
Oshin02
And yes, I’m unfortunately a step/auto…….
Old 10-04-2005, 11:17 AM   #3
Mr Paddle.Shift
Mr Paddle.Shift's Avatar
My Ride: B3 epsilon
Why is it being unfortunate? I have so much fun at the tracks with an ASA SC and a steptronic.
Technik Engineering ASA Stage 1.
Supercharged E46 M54B25.
2011 NASA TTC So Cal Champion!
Track blog.
Technik Engineering oil cap o-ring maintenance kit available.
Mr Paddle.Shift is offline   Reply With Quote
Old 10-04-2005, 08:56 PM   #4
BMR2NV
My Ride: E46 318I 2002
Well i had a turbo setup on my e46 and the tranny would always go into limp mode at around 3,500rpm when it was reaching max power levels. There is a limit on the tranny but i think its more got to do with the brain controlling it. There must be a certain power (torque) level that the computer has been pre set to before putting the trans into limp mode.
As soon as i took the turbo set up off and left it n/a with exhaust and air intake mods there car and tranny ran perfect... i dont think just "BEEFING UP" the tranny is going to help... Something needs to be done to the computer.
im no expert but thats just comming from experience..
BMR2NV is offline   Reply With Quote
Old 10-05-2005, 03:38 AM   #5
Oshin02
Is there any trans softwares that can do this?....
Old 10-05-2005, 12:46 PM   #6
greenohawk69
My Ride: SCHWINN
I've heard Dinan.
greenohawk69 is offline   Reply With Quote
Old 10-05-2005, 05:44 PM   #7
Oshin02
Originally Posted by greenohawk69
I've heard Dinan.
I just got off the phone with them, it doesn't eliminate the torque sensor..........is there anythign else I can do? Is it a physical sensor in the trans that I can mess around wit hor is it strictly software? Thanks!
Old 10-05-2005, 06:53 PM   #8
BMR2NV
I Think there is an actuall torque sensor.... but u cant just remove it because then u will again have problems with the trans computer. Its a fine line between being ok and being over the limit
Old 10-05-2005, 08:40 PM   #9
Lay2Low
My Ride: Psshht Widebody; M3
Send a message via AIM to Lay2Low
I hope someone can figure out how to make this work. How much can the tranny really hold before it starts to slip? It just seems wierd that they would slip with a "low" HP and torque, when you see things like mercedes' autos holdin 500+
Lay2Low is offline   Reply With Quote
Old 10-05-2005, 08:45 PM   #10
malakia12
My Ride: 05 Xterra, 05 Sentra
Send a message via AIM to malakia12
My tranny is holding up fine up til now, I have AA s/c, headers, cams, exhaust, but my car is a 325. It used to slip in the beginning when I first got the s/c installed, but since then I can basically push the car as hard as I want and then tranny responds just fine. time will tell i guess
Blown by AA :) SOLD!!!!
malakia12 is offline   Reply With Quote
Old 10-05-2005, 09:05 PM   #11
Mr Paddle.Shift
My Ride: B3 epsilon
That's because each transmission has a torque rating. BMW has auto transmissions rated for higher torque, notably those in 7er, 5er, X5 and the Alpina V8 (Z8 based).
Track blog.
Old 10-06-2005, 05:47 AM   #12
Oshin02
So how much can we step/ auto tran.'s really hold till they go into "Limp mode"? Thanks!
Old 10-06-2005, 06:23 PM   #13
tpollard95124
My Ride: X3 3.0i
I know there's been lots of debate in this forum on auto transmissions and I'm not looking to re-create that. It would be interesting to know though what the torque sensor limits are on the GM and ZF transmissions.
tpollard95124 is offline   Reply With Quote
Old 10-06-2005, 06:44 PM   #14
Mr Paddle.Shift
My Ride: B3 epsilon
I have a ZF 5HP19. My last dyno was about 240rw-hp, 210rw-ftlbs. I haven't experienced slippage or going into limp mode ever.
I need a more concrete proof. I know the GT-1 can display the torque rating. Hoping to jump on the dyno soon.
Track blog.
Old 10-07-2005, 07:34 AM   #15
BayerischeMW
Man with No Name
BayerischeMW's Avatar
My Ride: '07 E92 335i
this is nice reading since i am planning on going ESS TX2 next spring on my 330 step, hoping it won't be any trouble.
BBS | ACS
"if you wanna be king of the ring, this is the kind of car you should get" -M3 CSL
"there's no replacement for displacement" - only BMW ///M
BayerischeMW is offline   Reply With Quote
Old 10-09-2005, 05:16 AM   #16
Oshin02
Old 10-09-2005, 05:21 AM   #17
Oshin02
So your doin okiw with your step/auto? Or is it slipping?
Old 10-09-2005, 07:33 AM   #18
malakia12
I am doing fine with my tranny
Old 10-12-2005, 10:16 PM   #19
Oshin02
anyone else?
Old 10-13-2005, 02:48 PM   #20
bengwie
My Ride: 2004 M3 Coupe
From my thought and my friend's experience, it is fine for 325 with supercharger w/ step because the power that SC gives on the 325 engine is right about the boundary of slipping (around 300 crank horse power), but 330 is the problem since the power will be above the boundary (the max limit of step tranny) and it will cause problems.
There was a product in www.levelten.com to upgrade your tranny to handle more horsepower, but I heard it was useless.
So, I think it would be better to just buy an M3 (anyway your car is coupe too, it would be an issue for people who like/want sedan). That's what my friend recommends me (he got SC on his 325). It's all up to you.
2003 330i sold
2004 ///M3 sold
bengwie is offline   Reply With Quote
